02-17-2022, 02:36 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: Colombia
Member: 575444 Status: Offline Sonork: 100.1618047 Thanks Meter: 15 | Samsung A127M Emmc Damaged By Easy Jtag Microsoft Windows 10 (64 bit) build 19042 (10.0.19041.1526) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 1ACFBB1C6F0******* Card Serial = AA1A**** EasyJTAG Box Firmware = 2.5302 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1807 mV CMD Active Level: 1866 mV EMMC Device Information : EMMC CID: 150100303030303030562016061354D1 EMMC CSD: 902701320F5903FFF6DB7FE08A40403B EMMC Manufacture : SAMSUNG , EMMC NAME: 000000 , HEX: 303030303030 , S/N: 20160613 , rev. 0x56 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2017 EMMC ROM 1 (Main User Data) Capacity: 2095982 MB (01FFB6E00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 512 KB (000000080000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 EMMC Init completed. Warning: Maybe your emmc damaged eMMC are unusable. |
02-17-2022, 04:16 | #2 (permalink) | |
Crazy Poster Join Date: Sep 2013 Location: mooroco
Member: 2024815 Status: Offline Thanks Meter: 6 | Quote:
Try To Update FFU if you have or Dump FFU From Working Phone And Write it to Damaged eMMC | |
The Following User Says Thank You to hiifi For This Useful Post: |
02-17-2022, 07:07 | #3 (permalink) |
Member: 575444 Status: Offline Sonork: 100.1618047 Thanks Meter: 15 | Solved with Dump FFU From Working Phone. COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Easy Jtag Plus Control Port (COM3) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Running:SAMSUNG: eMMC firmware update... Chip Init OK... Downloading FFU:C:\Users\Gapcom\Desktop\eMMC_Firmware_KMDP6001 [email protected] Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Checking firmware type... OK; Skip loading eMMC Addon Firmware Box S/N: 1ACFBB1C6F09****, ,FW Ver.: 02.53 CMD Pullup Level:1864 mV CMD Active Level:1868 mV Box IO Level:1800 mV CLK Rate:14000 kHz Using firmware file : C:\Users\sssrrr\Desktop\[email protected] Update Firmware ID Hash: Setup firmware update mode, wait 2..30 sec... Correcto! Sending eMMC firmware... Correcto! Verifying eMMC firmware... Correcto! Flashing eMMC firmware... Correcto! eMMC CID : 150100303030303030562016061354D1 New CID : 150100445036444142005184D251687D Repairing eMMC CID... eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D New CSD : 902701320F5903FFF6DB7FE08A40403B Repairing eMMC CSD... Correcto! eMMC firmware is updated now! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. |
02-17-2022, 22:37 | #4 (permalink) |
Member: 575444 Status: Offline Sonork: 100.1618047 Thanks Meter: 15 | other Emmc Damaged A217M FFU:C:\Users\rrrsss\Desktop\eMMC_Firmware_KMDH6001 [email protected] Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Checking firmware type... OK; Skip loading eMMC Addon Firmware Box S/N: 1ACFBB1C6F09****, ,FW Ver.: 02.53 CMD Pullup Level:1806 mV CMD Active Level:1866 mV Box IO Level:1800 mV CLK Rate:14000 kHz Using firmware file : C:\Users\rrrsss\Desktop\[email protected] Update Firmware ID Hash: Setup firmware update mode, wait 2..30 sec... Can't setup firmware normal update mode, Reason: CARD Status Error Done. Error with other backup FFU |
02-18-2022, 19:35 | #5 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
