02-06-2023, 20:05 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: In Your Room Age: 47
Member: 97299 Status: Offline Thanks Meter: 43 | Samsung A40 code read or remove trough isp without lose data ? Is there any way to read or remove the user code without Lose the data ? Thanks in advance . |
02-09-2023, 22:20 | #2 (permalink) |
No Life Poster Join Date: Apr 2003 Location: Torun, Poland Age: 40
Member: 25996 Status: Offline Thanks Meter: 253 | No, this device uses FBE (file based encryption). The correct passcode has to be bruteforced, so the phone can correctly decrypt the data. There's no other, magic solution. |
02-10-2023, 09:45 | #3 (permalink) |
Member: 97299 Status: Offline Thanks Meter: 43 | Can't be bruteforced becouse the spl it's: 2022-06-01 , and can't be downgraded with home csc becouse I get: encryption corrupted data need to format. Do you know any solution how to downgrade to spl 3/2022 without data loss ? |
02-10-2023, 15:21 | #4 (permalink) |
Member: 25996 Status: Offline Thanks Meter: 253 | Your screenshot says it's quite an old firmware, and it doesn't matter anyways. Passcode still has to be bruteforced if you want data, no way around that. |
02-11-2023, 00:13 | #6 (permalink) | |
Member: 97299 Status: Offline Thanks Meter: 43 | Quote:
Or anyway to downgrade the spl Or anyway to downgrade the spl | |
