12-21-2020, 03:24 | #1 (permalink) |
Junior Member Join Date: Mar 2017 Age: 29
Member: 2693967 Status: Offline Thanks Meter: 6 | (ASK) Can i use Emate Socket Emmc tool ??? i want to ask i want to buy easy jtag plus box for working with emmc, im already hv emmc socket, emate pro emmc tool by Moorc. can i use easy jtag plus with this emmc socket ??? |
12-21-2020, 10:00 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | you can use this socket with EsyJTAG plus with e-socket (green) adapter but you may have power problem EasyJTAG Plus use 1 and 17 socket pins to power eMMC chip you need cut track from power stabilizer at emate and sold wire from 1 pin to VCCQ and from 17 pin to VCC eMMC also you need chack 2 gnd connected |
The Following User Says Thank You to layder For This Useful Post: |
12-21-2020, 22:48 | #3 (permalink) | |
Member: 2693967 Status: Offline Thanks Meter: 6 | Quote:
I will report it again when the box arrives. bdw can easy jtag plus use the ufi socket? Sent from my SM-N950N using Tapatalk | |
01-05-2021, 07:50 | #5 (permalink) |
Member: 2693967 Status: Offline Thanks Meter: 6 | Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 0 mV Initial pull results: clock: 146mV pin unconnected command: 155mV pin unconnected data0: 156mV pin unconnected data1: 155mV pin unconnected data2: 156mV pin unconnected data3: 156mV pin unconnected data4: 155mV pin unconnected data5: 155mV pin unconnected data6: 156mV pin unconnected data7: 155mV pin unconnected Box S/N: 0DF1DACCFF222422, ,FW Ver.: 02.53 Box IO Level:0 mV CLK Rate:42000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514536334D4203A26A9BE965F3 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2018 Rev.0x3 eMMC NAME: QE63MB , S/N: 2724895721 eMMC NAME (HEX): 514536334D42 IC Name: Samsung , KMQE60013M-B318/16GB @BGA221 EMMC ROM1 (Main User Data) Capacity: 14910 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 195443 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x02 , width 8bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QE63MB_2724895721_20210105_1447.extcsd Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB Disk identifier (GUID): 00000000-0000-0000-0000-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x007A800000 (2.500GB) Blocks Reading Error (0x7A800400 , 2 , Reason: DATA RCV CRC Error ) Unable to mount SYSTEM , code : 5 --------------------------------------------- Detected USERDATA USERDATA : 0x012B000000 (9.830GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: 68DD5E73 726BBE82 63DA570F 4AB65CF5 68D28893 BB7DF37C 900E8748 DA3FB6A8 hÝ^srk¾‚cÚW.J¶\õhÒ.“»}ó|..‡HÚ?¶¨; E9D49806 E245738C 40333A31 0F6A050A B2AA53DE 7ABE79CB 08B7688E B0F0FF97 éÔ..âEsŒ@3:1.j..²ªSÞz¾yË.·hŽ°ðÿ—; BCD8843E C76BBE27 6FB4C849 20DBB801 B23EDED4 FD148296 1AE652DF B2917D29 ¼Ø„>Çk¾'o´ÈI Û¸.²>ÞÔý.‚–.æRß²‘}); 0D01FAC4 CC42D329 F54A4DE6 4099D9D9 54D6C4CC 9B7A5A35 DE67A2E8 924B94BE ..úÄÌBÓ)õJMæ@.ÙÙTÖÄÌ›zZ5Þg¢è’K”¾; AD2FA2F9 1EC461F4 47EBC034 B99F6435 24CA7B5B 034B3FA0 3381B88D FAF95C1F */¢ù.ÄaôGëÀ4¹Ÿd5$Ê{[.K? 3.¸.úù\.; AC81ACB9 8C20032B 860DE54B 7EDFC4C6 E26FB3CF 65464401 C5CC700B A82A4E16 ¬.¬¹Œ .+†.åK~ßÄÆâo³ÏeFD.ÅÌp.¨*N.; A8FB0B90 E306366B 91BC94E3 2D07DEF5 83129C77 C4A6B453 71F662DC F7F088D7 ¨û..ã.6k‘¼”ã-.Þõƒ.œwĦ´SqöbÜ÷ð.×; 9B024404 A6FD38F6 82FB30BF 09B19F7E CA407A54 3E61736B B22B76F5 D4FC604E ›.D.¦ý8ö‚û0¿ ±Ÿ~Ê@zT>ask²+võÔü`N; Done. |
01-05-2021, 07:56 | #6 (permalink) |
Member: 2693967 Status: Offline Thanks Meter: 6 | Using ufi socket and u adapter, Initial pull results: clock: 146mV unconnected pin command: 155mV pin unconnected data0: 156mV pin unconnected data1: 155mV unconnected pin data2: 156mV pin unconnected data3: 156mV pin unconnected data4: 155mV unconnected pin data5: 155mV unconnected pin data6: 156mV pin unconnected data7: 155mV unconnected pin is it safe? Oh, I have tried to connect to the moorc socket but it can't, I tried using the U socket and the E socket still can't |
01-05-2021, 08:01 | #7 (permalink) | |
and one more thing, I want to ask sir What is the difference between the JTAG Classic Suite and the EMMC Tool Suite? because I see almost the same | |
01-05-2021, 11:10 | #9 (permalink) | |
I buy easy jtag plus with soket ufs 254 only ( for isp ufs only ) So i hope, my new box ( easy jtag plus ) can use this socket to work with emmc Thank you sir Sent from my SM-N950N using Tapatalk | |
01-05-2021, 13:45 | #11 (permalink) | |
sorry sir, I mean, I want to use this moorc socket for my easy jtag, because I bought only 254 bga, so I want it to be easy jtag to be able to connect with bga 221 153 through this moorc socket can you help me to connect sir, please | |
01-05-2021, 17:58 | #12 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
If you want to use socket - you need buy it If you have socket - connect it to box and use it Last edited by layder; 01-05-2021 at 18:40. | |
