Old 06-19-2020, 23:36   #1 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 54
samsung a530f dead after update ota
after repair boot with pit bootloader u11 phone restart on logo and rmm state broken itry many firmware same problem
Old 06-20-2020, 08:09   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,487
You need post logs of you actions to analize you actions
Old 06-22-2020, 21:45   #3 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 54
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
HiPower mode is ON
Setting frequence to 21 MHz
CMD Pullup Level: 3361 mV
CMD Active Level: 3279 mV
EMMC Device Information :
EMMC CID: 150100434B544D34520078F948E0A466
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: CKTM4R , HEX: 434B544D3452 , S/N: 78F948E0 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 10/2017
EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 19 , Response: Not Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CKTM4R_78F948E0_20200622_234311.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: NA, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB)
Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB)
Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB)
Partition: CM, [000002800000 - 000003000000], size: 000000800000 (8.00 MB)
Partition: M9KEFS1, [000003000000 - 000003400000], size: 000000400000 (4.00 MB)
Partition: M9KEFS2, [000003400000 - 000003800000], size: 000000400000 (4.00 MB)
Partition: M9KEFS3, [000003800000 - 000003C00000], size: 000000400000 (4.00 MB)
Partition: NAD_REFER, [000003C00000 - 000003D00000], size: 000000100000 (1.00 MB)
Partition: PARAM, [000003D00000 - 000004500000], size: 000000800000 (8.00 MB)
Partition: MISC, [000004500000 - 000004700000], size: 000000200000 (2.00 MB)
Partition: BOOT, [000004700000 - 000006700000], size: 000002000000 (32.0 MB)
Partition: RECOVERY, [000006700000 - 000008D00000], size: 000002600000 (38.0 MB)
Partition: BOTA1, [000008D00000 - 000009500000], size: 000000800000 (8.00 MB)
Partition: RADIO, [000009500000 - 00000C200000], size: 000002D00000 (45.0 MB)
Partition: PERSISTENT, [00000C200000 - 00000C280000], size: 000000080000 (512. KB)
Partition: STEADY, [00000C280000 - 00000C680000], size: 000000400000 (4.00 MB)
Partition: RESERVED2, [00000C680000 - 00000C800000], size: 000000180000 (1.50 MB)
Partition: SYSTEM, [00000C800000 - 000104800000], size: 0000F8000000 (3.88 GB)
Partition: CACHE, [000104800000 - 000114200000], size: 00000FA00000 (250. MB)
Partition: HIDDEN, [000114200000 - 000114700000], size: 000000500000 (5.00 MB)
Partition: OMR, [000114700000 - 000117900000], size: 000003200000 (50.0 MB)
Partition: CP_DEBUG, [000117900000 - 000117E00000], size: 000000500000 (5.00 MB)
Partition: NAD_FW, [000117E00000 - 000119200000], size: 000001400000 (20.0 MB)
Partition: USERDATA, [000119200000 - 000E8F7FBE00], size: 000D765FBE00 (53.8 GB)
GPT header successfully parsed
Old 06-22-2020, 21:46   #4 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 54
---------- eMMC Device Information ----------
eMMC CID : 150100434B544D34520078F948E0A466
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 10/2017 Rev.0x0
eMMC NAME: CKTM4R , S/N: 2029603040
eMMC NAME (HEX): 434B544D3452
EMMC ROM1 (Main User Data) Capacity: 59640 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
EMMC RPMB is programmed and written 19 times
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: CKTM4R_2029603040_20200622_2344.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 747C000 sectors 58.2 GiB
Soft (Partitioned) Disk/Image size: 747BFBC sectors 58.2 GiB
Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,122142686
Partition info successfully found
------ Detected 25 partitions ------
P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB
P1 (NA) [0x800000 0x400000] Size: 4.0MB
P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB
P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB
P4 (CM) [0x2800000 0x800000] Size: 8.0MB
P5 (M9KEFS1) [0x3000000 0x400000] Size: 4.0MB
P6 (M9KEFS2) [0x3400000 0x400000] Size: 4.0MB
P7 (M9KEFS3) [0x3800000 0x400000] Size: 4.0MB
P8 (NAD_REFER) [0x3c00000 0x100000] Size: 1.0MB
P9 (PARAM) [0x3d00000 0x800000] Size: 8.0MB
P10 (MISC) [0x4500000 0x200000] Size: 2.0MB
P11 (BOOT) [0x4700000 0x2000000] Size: 32.0MB
P12 (RECOVERY) [0x6700000 0x2600000] Size: 38.0MB
P13 (BOTA1) [0x8d00000 0x800000] Size: 8.0MB
P14 (RADIO) [0x9500000 0x2d00000] Size: 45.0MB
P15 (PERSISTENT) [0xc200000 0x80000] Size: 512.0KB
P16 (STEADY) [0xc280000 0x400000] Size: 4.0MB
P17 (RESERVED2) [0xc680000 0x180000] Size: 1.500MB
P18 (SYSTEM) [0xc800000 0xf8000000] Size: 3.875GB
P19 (CACHE) [0x104800000 0xfa00000] Size: 250.0MB
P20 (HIDDEN) [0x114200000 0x500000] Size: 5.0MB
P21 (OMR) [0x114700000 0x3200000] Size: 50.0MB
P22 (CP_DEBUG) [0x117900000 0x500000] Size: 5.0MB
P23 (NAD_FW) [0x117e00000 0x1400000] Size: 20.0MB
P24 (USERDATA) [0x119200000 0xd765fbe00] Size: 53.848GB
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x000C800000 (3.875GB)
Unable to mount SYSTEM , code : 95
Detected USERDATA USERDATA : 0x0119200000 (53.848GB)
Short EXT fs info:
Block size: 4.0KB
Inode size: 256
Inodes: 3530752
Short userdata info:
Unable to read gesture.key , code 2
Done.
Old 06-22-2020, 21:48   #5 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 54
this is orignal emmc i repair boot only on download rmm state broken and phone restart on logo
Old 06-23-2020, 07:09   #6 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,487
this is detect log - it have basic info, and can't help to problem
I need log of you ACTIONS (how you write data to eMMC)
You can find it at "Log" derectory of Program
Old 06-25-2020, 09:31   #7 (permalink)
Member: 257716
Sonork: 1650684
Thanks Meter: 54
sorry icant find log but i write only pit+bootloader from firmware u11 then write firmware by z3x
Old 06-25-2020, 11:29   #8 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,487
sometime device need write AP file (may be without system partition)
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.14269 seconds with 7 queries
