02-24-2017, 09:19 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: Infront Of My Laptop Age: 34
Member: 799558 Status: Offline Thanks Meter: 430 | Samsung B219 Boot Repair with Easy Jtag ?? samsung B219 dead boot reapir with esay jtag but i am noob in jtag box. pinouts connection ok but just this error come EasyJtag Suite Classic ver.: 2.5.0.7 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security... OK Initialising: Samsung SCH-B219 Config ver.:1.00 I/O Level set to : 2600 mV Box S/N: ,FW Ver.: 01.58 Connecting to Target... Done with error(s)... i am doing something wrong pls give me advice Thanks in Advance |
02-26-2017, 08:15 | #2 (permalink) |
Member: 799558 Status: Offline Thanks Meter: 430 | i am try all possible Connection with my box but i can't i think problem with my new box because Jtag 20Pin show all are ok but TDI And TRST Pin show GND without A to B Power cable is It Ok or Problem with my box ?? |
02-26-2017, 10:34 | #3 (permalink) | |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Quote:
Please, measure GND to TDI / TRST resistance directly on the box (without any plugged cable). If you see short, means some internal box problem (solder bridge or damaged IC). If no short, double check your cable, make sure that cable is not plugged in wrong direction. This log means that no JTAG chain detected. Best Regards | |
02-26-2017, 12:07 | #4 (permalink) | |
Member: 799558 Status: Offline Thanks Meter: 430 | Quote:
0 Volt to show but other pins are show voltage. Warranty period cover how many months of new box pls tell me Waiting For Your Replay Thanks Last edited by dey mobiles; 02-26-2017 at 12:16. | |
02-26-2017, 21:33 | #5 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Can you take photo from Soldered Wires to PCB? i want see your soldered wires because 99% i'm sure you have wrong Soldered |
02-27-2017, 22:00 | #7 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Hi You have wrong soldered wires Pin1 is empty pin2 is TMS PIn3 is RTCK Pin4 is TRST Pin5 is TDI Pin6 is TCK Pin7 is TDO Pin8 is NRST SYSRST Pin9 is GND |
03-23-2017, 14:41 | #10 (permalink) |
Member: 799558 Status: Offline Thanks Meter: 430 | Try on eMMC with my new Easy Jtag box and Adopter but not connected Can't init device, Reason: CMD Timeout Error but same connection Adpoter perfect working on ATF box Is there Problem in my EASY JTAG Box ?? |
04-08-2017, 09:18 | #11 (permalink) |
Member: 799558 Status: Offline Thanks Meter: 430 | At Last I have Done Boot Repair B219 Just Change My Easy Jtag H/W now working fine Thanks All Here Is LOG Code: EasyJtag Suite Classic ver.: 2.5.0.8 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7601, Service Pack 1). Admin righ For support and updates visit http://easy-jtag.com Check security...OK Initialising: HUAWEI C2835 Config ver.:1.00 I/O Level set to : 2600 mV Box S/N: 120140154842E868 ,FW Ver.: 01.58 Connecting to Target... JTAG device: QSC1100 CPU IDCODE : 0x122CE0E1 Mfg.: 0x070, Part: 0x22ce, Ver.: 0x1 CPU Manufacturer: QUALCOMM , CPU Name: QSC11x0 Halting CPU... Initialize hardware... Starting target communication... Detecting NOR memory parameters of bank (0) ... NOR FlashID:00EC:227A 'K5L6331CAA 8MB (Samsung)' found NOR Write OK! Elpsed time: 181.924316s (45.030 KiB/s) Br, |
