05-20-2014, 19:53 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | Successfully repaired VTU00M name 00000000, for GT-i9300 EasyJtag Suite ver.: 1.5.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). Successefuly connected to box on COM3Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA3B-2511 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 1.5.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50 CMD Pullup Level:1825 mV CMD Active Level:1897 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 537986854 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537986854_20140402_1105.extcsd Done. Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1825 mV CMD Active Level:1897 mV Start EMMC repair: Entering repair mode 1... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 1... Success =================================== Init EMMC... Can't init EMMC, Reason: CARD Ready Timeout Error Please, Reconnect EMMC power lines and press 'VTU00M Repair' again =================================== Successefuly connected to box on COM3Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA3B-2511 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 1.5.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50 CMD Pullup Level:1815 mV CMD Active Level:1887 mV eMMC Device Information EMMC CID : 15010056545530304DF17AA34B12AFCA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 2057521938 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2057521938_20140402_1107.extcsd Done. Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2660 mV CMD Active Level:2722 mV Start EMMC repair: Entering repair mode 2... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 2... Reading S.M.A.R.T Can't init EMMC, Reason: CMD Timeout Error =================================== Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2660 mV CMD Active Level:2722 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 1,1,2,15 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 50,50,49,36 All Erase counts (min,avg,max): 0,0,1 SLC Erase counts (min,avg,max): 0,0,1 MLC Erase counts (min,avg,max): 0,0,0 S.M.A.R.T Report Done !!! EMMC CID : 15010056545530304DF17AA34B12AFCA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 537986854 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_2057521938_20140402_1138.extcsd Done. Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2660 mV CMD Active Level:2722 mV Start EMMC repair: Entering repair mode 2... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 2... Reading S.M.A.R.T Can't init EMMC, Reason: CMD Timeout Error =================================== Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2660 mV CMD Active Level:2722 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 1,1,2,15 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 50,50,49,36 All Erase counts (min,avg,max): 0,0,1 SLC Erase counts (min,avg,max): 0,0,1 MLC Erase counts (min,avg,max): 0,0,0 S.M.A.R.T Report Done !!! Z3X EasyJtag Software ver. 1.5.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50 CMD Pullup Level:1804 mV CMD Active Level:1887 mV eMMC Device Information EMMC CID : 15010056545530304DF17AA34B12AFCA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 537986854 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_2057521938_20140402_1139.extcsd Done. Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:1887 mV Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 819 kB/s Done !!! Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1804 mV CMD Active Level:1887 mV Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 836 kB/s Done !!! thanks z3x team.best in the world |
The Following 7 Users Say Thank You to drjaved_akhter For This Useful Post: |
05-20-2014, 20:15 | #2 (permalink) |
Member: 585807 Status: Offline Thanks Meter: 781 | one more EasyJtag Suite ver.: 1.5.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). Successefuly connected to box on COM3Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50Box Working Mode: JTAG Box.Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA3B-2511 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 1.5.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50 CMD Pullup Level:1815 mV CMD Active Level:1887 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 537986854 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537986854_20140402_1157.extcsd Done. Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:1887 mV Start EMMC repair: Entering repair mode 1... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 1... Success =================================== Init EMMC... Success Entering repair mode 2... Warning Can't enter repair mode 2, Reason: CARD Ready Timeout Error Please, Reconnect EMMC power lines and press 'VTU00M Repair' again ================================== Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1825 mV CMD Active Level:1887 mV Start EMMC repair: Entering repair mode 2... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 2... Reading S.M.A.R.T Can't init EMMC, Reason: CMD Timeout Error =================================== Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1825 mV CMD Active Level:1887 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 3,2,2,6 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 48,49,49,45 All Erase counts (min,avg,max): 0,0,1 SLC Erase counts (min,avg,max): 0,0,1 MLC Erase counts (min,avg,max): 0,0,0 S.M.A.R.T Report Done !!! Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1825 mV CMD Active Level:1887 mV Start EMMC repair: Entering repair mode 2... Success Erasing repair area... Success Writing repair area... Success Exit repair mode 2... Reading S.M.A.R.T Can't init EMMC, Reason: CMD Timeout Error =================================== Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1825 mV CMD Active Level:1887 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 3,2,2,6 Runtime bad blocks per bank : 0,0,0,0 Reserved blocks left per bank : 48,49,49,45 All Erase counts (min,avg,max): 0,0,1 SLC Erase counts (min,avg,max): 0,0,1 MLC Erase counts (min,avg,max): 0,0,0 S.M.A.R.T Report Done !!! Z3X EasyJtag Software ver. 1.5.0.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50 CMD Pullup Level:1815 mV CMD Active Level:1897 mV eMMC Device Information EMMC CID : 15010056545530304DF15F0D25A19F68 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2012 Rev.0xf1 EMMC NAME: VTU00M , S/N: 1594697121 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: VTU00M_1594697121_20140402_1201.extcsd Done. Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:1897 mV Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Speed: 824 kB/s Done !!! Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin Z3X EasyJtag Software ver. 1.5.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1815 mV CMD Active Level:1897 mV Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 836 kB/s Done !!! |
The Following 5 Users Say Thank You to drjaved_akhter For This Useful Post: |
05-21-2014, 05:25 | #4 (permalink) |
Freak Poster Join Date: May 2014
Member: 2186335 Status: Offline Thanks Meter: 44 | you can read sterp by step in update threath forum.gsmhosting.com/vbb/f672/easy-jtag-update-1-5-0-0-easy-jtag-1-year-birthday-update-boom-exclusive-update-1816784/ |
05-24-2014, 07:31 | #12 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,558 | Quote:
05-24-2014, 14:35 | #15 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Ha Noi - Viet Nam Age: 18
Member: 207400 Status: Offline Sonork: 100.1582556 Thanks Meter: 262 | I'm not luck, always get dead emmc . Try 20 pcs not ok, tommorrow try more. Quote:
The Following User Says Thank You to ..::Thanh_gsm::.. For This Useful Post: |
