06-24-2016, 15:29 | #42 (permalink) |
Freak Poster Join Date: Nov 2012 Location: Born in Syria,Live In Turkey
Member: 1834175 Status: Offline Thanks Meter: 51 | Bad :-( THANKS FIRST Write DONE BUT STILL DEAD YOUR DUMP FOR OLD VERSION OR DAMAGED OR ??? :-) BRO THIS MY LOG: C:\Users\Eng.Salman\Desktop\G530H\EMMC_ROM1_068000 00_00E00000 EFS.bin File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. Processing file...C:\Users\Eng.Salman\Desktop\G530H\EMMC_ROM1 _06800000_00E00000 EFS.bin Processing file...C:\Users\Eng.Salman\Desktop\G530H\EMMC_ROM2 _00000000_00400000.bin Processing file...C:\Users\Eng.Salman\Desktop\G530H\EMMC_ROM3 _00000000_00400000.bin Processing file...C:\Users\Eng.Salman\Desktop\G530H\QNW00M_ 604434101_20151104_2203.extcsd Writing 0000E00000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 1702 kB/s Writing 0000400000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 365 kB/s Writing 0000400000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 364 kB/s What s' wrong ? and this after repair eMMC Device Information EMMC CID : 150100514E5730304D00FB0ACEDAA144 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2014 Rev.0x0 EMMC NAME: QNW00M , S/N: 4211789530 EMMC NAME (HEX): 514E5730304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QNW00M_4211789530_20160624_1725.extcsd Done I TRY ATF AND EASY-Jtag the SAME RESULTs and I try to SET BOOT1 for BOOTING but the same too CLK Rate:3000 khz HiPower™ mode is off! eMMC Device Information EMMC CID : 150100514E5730304D00FB0ACEDAA144 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2014 Rev.0x0 EMMC NAME: QNW00M , S/N: 4211789530 EMMC NAME (HEX): 514E5730304D00 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QNW00M_4211789530_20160624_1733.extcsd Done. |
07-31-2016, 13:57 | #43 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | G530H EMMC done here log:- ---------- eMMC Device Information ----------EMMC CID : 150100513331364D4200DD5BC2D2918E EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2014 Rev.0x0 EMMC NAME: Q316MB , S/N: 3713778386 EMMC NAME (HEX): 513331364D4200 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: Q316MB_3713778386_20160731_1834.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 98101B32-BBE2-4BF2-A06E-2BB33D000C20 Warning: Entries Count = 128 MMCBLK0P0 (APNHLOS) Range: [0X400000,0X12FFE00] ,Len: F00000 MMCBLK0P1 (MODEM) Range: [0X1300000,0X4C6FE00] ,Len: 3970000 MMCBLK0P2 (SBL1) Range: [0X4C70000,0X4CEFE00] ,Len: 80000 MMCBLK0P3 (DDR) Range: [0X4CF0000,0X4CF7E00] ,Len: 8000 MMCBLK0P4 (ABOOT) Range: [0X4CF8000,0X4EF7E00] ,Len: 200000 MMCBLK0P5 (RPM) Range: [0X4EF8000,0X4F77E00] ,Len: 80000 MMCBLK0P6 (QSEE) Range: [0X4F78000,0X4FF7E00] ,Len: 80000 MMCBLK0P7 (QHEE) Range: [0X4FF8000,0X5077E00] ,Len: 80000 MMCBLK0P8 (FSG) Range: [0X5078000,0X5377E00] ,Len: 300000 MMCBLK0P9 (SEC) Range: [0X5378000,0X537BE00] ,Len: 4000 MMCBLK0P10 (PAD) Range: [0X537C000,0X5DFFE00] ,Len: A84000 MMCBLK0P11 (PARAM) Range: [0X5E00000,0X67FFE00] ,Len: A00000 MMCBLK0P12 (EFS) Range: [0X6800000,0X75FFE00] ,Len: E00000 MMCBLK0P13 (MODEMST1) Range: [0X7600000,0X78FFE00] ,Len: 300000 MMCBLK0P14 (MODEMST2) Range: [0X7900000,0X7BFFE00] ,Len: 300000 MMCBLK0P15 (BOOT) Range: [0X7C00000,0X88FFE00] ,Len: D00000 MMCBLK0P16 (RECOVERY) Range: [0X8900000,0X97FFE00] ,Len: F00000 MMCBLK0P17 (FOTA) Range: [0X9800000,0X9D00200] ,Len: 500400 MMCBLK0P18 (BACKUP) Range: [0X9D00400,0XA3FDE00] ,Len: 6FDC00 MMCBLK0P19 (FSC) Range: [0XA3FE000,0XA6FDE00] ,Len: 300000 MMCBLK0P20 (SSD) Range: [0XA6FE000,0XA6FFE00] ,Len: 2000 MMCBLK0P21 (PERSIST) Range: [0XA700000,0XAEFFE00] ,Len: 800000 MMCBLK0P22 (PERSDATA) Range: [0XAF00000,0XB7FFE00] ,Len: 900000 MMCBLK0P23 (SYSTEM) Range: [0XB800000,0X68FFFE00] ,Len: 5D800000 MMCBLK0P24 (CACHE) Range: [0X69000000,0X7BBFFE00] ,Len: 12C00000 MMCBLK0P25 (HIDDEN) Range: [0X7BC00000,0X7C5FFE00] ,Len: A00000 MMCBLK0P26 (USERDATA) Range: [0X7C600000,0X1D1FFAE00] ,Len: 1559FB000 Done...Presets has been updated... Done. |
The Following 6 Users Say Thank You to ALI_MAFIA For This Useful Post: |
08-01-2016, 01:23 | #44 (permalink) |
No Life Poster Join Date: Dec 2014 Location: u.a.e
Member: 2320256 Status: Offline Sonork: 100.1661545 Thanks Meter: 50 | Emmc size in log is 16g. Sm-g530h emmc is 8g Are you sure that's correct log ?? Sent from my GT-N7100 using Tapatalk |
The Following User Says Thank You to mojahed.br For This Useful Post: |
