11-28-2021, 08:01 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | samsung g532f have samsung ic and ic consummed 70,80 %.help me Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used" then i erase and write dump .mobile working fine but some days after ,mobile again hung on logo.now i want to upgrade samsung emmc but when dump emmc fw, show message "please power cycle emmc chip".what i do.which procedure make mobile alive again eMMC_tool ver. 2.0.0.0 (release date: 30.12.2020) Microsoft Windows 10 (64 bit) build 19041 (10.0.19041.1348) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = 2B82710456C6FC4A Card Serial = AA9FD6F4 EasyJTAG Box Firmware = 2.5302 Changelog: 30/12/2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/ISP Setting Frequence to 18 Mhz Setting BusWidth to 1 Bit CMD Pullup Level: 2105 mV CMD Active Level: 2253 mV Setting HS Timing to Enabled EMMC Device Information : EMMC CID: 150100514E31364242009351EE58C3E3 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D Manufacturer: SAMSUNG , NAME: QN16BB , HEX: 514E31364242 , S/N: 58EE5193 , Rev: 00 Manufacturer ID: 15 , OEM ID: 00 , Device Type: BGA (Discrete embedded) , Date: 12/2016 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0x0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (0x000000400000) EMMC RPMB Capacity: 4096 KB (0x000000400000) , Counter: 0 , Response: Maybe not Clean Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot partition 1 enabled for boot , Boot ACK Boot Bus Config: 0x00 , x1 (sdr) or x4 (ddr) bus width in boot operation mode H/W Reset Function [RST_N_FUNCTION]: 0x01 , RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition settings [PARTITION_SETTING_COMPLETED]: 0x00 EMMC Init completed Backup saved: QN16BB_58EE5193_20211128_115127.extcsd (new backup) Device Life Time Estimation (MLC) [269]: 0x08 70% - 80% device life time used Device Life Time Estimation (SLC) [268]: 0x08 70% - 80% device life time used Pre EOL information [267]: 0x01 Normal Connected successfully Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write) Scanning soft partitions from ROM2 GPT header is not found Scanning soft partitions from ROM3 GPT header is not found Scanning soft partitions from ROM1 GPT header is found Partition: PrimaryGPT, [000000000000 - 000000004400], Size: 000000004400 (17.00 KB), Type: GPT Partition: BOTA0, [000000400000 - 000000800000], Size: 000000400000 (4.00 MB), Type: Blank Partition: nvram, [000000800000 - 000001000000], Size: 000000800000 (8.00 MB), Type: Raw Partition: lk, [000001000000 - 000001200000], Size: 000000200000 (2.00 MB), Type: Raw Partition: BOTA1, [000001200000 - 000001400000], Size: 000000200000 (2.00 MB), Type: Blank Partition: secro, [000001400000 - 000001B00000], Size: 000000700000 (7.00 MB), Type: Raw Partition: seccfg, [000001B00000 - 000001B80000], Size: 000000080000 (512.00 KB), Type: Blank Partition: efuse, [000001B80000 - 000001C00000], Size: 000000080000 (512.00 KB), Type: Raw Partition: tee1, [000001C00000 - 000002200000], Size: 000000600000 (6.00 MB), Type: Raw Partition: BOTA2, [000002200000 - 000002800000], Size: 000000600000 (6.00 MB), Type: Blank Partition: EFS, [000002800000 - 000003000000], Size: 000000800000 (8.00 MB), Type: Linux (/efs) Partition: nvdata, [000003000000 - 000005000000], Size: 000002000000 (32.00 MB), Type: Linux (/nvdata) Partition: PARAM, [000005000000 - 000005800000], Size: 000000800000 (8.00 MB), Type: Raw Partition: recovery, [000005800000 - 000006800000], Size: 000001000000 (16.00 MB), Type: Boot Partition: boot, [000006800000 - 000007800000], Size: 000001000000 (16.00 MB), Type: Boot Partition: md1img, [000007800000 - 000009800000], Size: 000002000000 (32.00 MB), Type: Raw Partition: md1dsp, [000009800000 - 000009C00000], Size: 000000400000 (4.00 MB), Type: Raw Partition: keystore, [000009C00000 - 00000A400000], Size: 000000800000 (8.00 MB), Type: Blank Partition: omekeystore, [00000A400000 - 00000A780000], Size: 000000380000 (3.50 MB), Type: Blank Partition: proinfo, [00000A780000 - 00000AA00000], Size: 000000280000 (2.50 MB), Type: Blank Partition: para, [00000AA00000 - 00000AA80000], Size: 000000080000 (512.00 KB), Type: Blank Partition: PERSISTENT, [00000AA80000 - 00000AB00000], Size: 000000080000 (512.00 KB), Type: FRP Partition: STEADY, [00000AB00000 - 00000AC00000], Size: 000000100000 (1.00 MB), Type: Blank Partition: protect1, [00000AC00000 - 00000B400000], Size: 000000800000 (8.00 MB), Type: Linux (/protect_f) Partition: protect2, [00000B400000 - 00000BC00000], Size: 000000800000 (8.00 MB), Type: Linux (/protect_s) Partition: RESERVE2, [00000BC00000 - 00000C000000], Size: 000000400000 (4.00 MB), Type: Blank Partition: system, [00000C000000 - 0000CC800000], Size: 0000C0800000 (3.01 GB), Type: Linux (/system) Partition: cache, [0000CC800000 - 0000E5800000], Size: 000019000000 (400.00 MB), Type: Linux (/cache) Partition: hidden, [0000E5800000 - 0000E9400000], Size: 000003C00000 (60.00 MB), Type: Linux Partition: userdata, [0000E9400000 - 0001D1C00000], Size: 0000E8800000 (3.63 GB), Type: Raw Partition: BackupGPT, [0001D1FFBE00 - 0001D2000000], Size: 000000004200 (16.50 KB), Type: BackupGPT BackupGPT header is not valid GPT header successfully parsed __________________________________________________ _________ Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: 2B82710456C6FC4A, ,FW Ver.: 02.53 CMD Pullup Level:2113 mV CMD Active Level:2255 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100514E31364242009351EE58C3E3 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 12/2016 Rev.0x0 eMMC NAME: QN16BB , S/N: 2471620184 eMMC NAME (HEX): 514E31364242 IC Name: Samsung , KMQN10006B-B318/8GB @BGA221 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 0 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: QN16BB_2471620184_20211128_1132.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: E90000 sectors 7.3 GiB Soft (Partitioned) Disk/Image size: E8FFBC sectors 7.3 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,15269854 Partition info successfully found ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000C000000 (3.7GB) Short EXT fs info: Size: 2.975GB Block size: 4.0KB Inode size: 256 Inodes: 195072 Short Android info: Build ID: MMB29T Display Build ID: MMB29T.G532FXWU1ASB1 Release Incremental ID: G532FXWU1ASB1 Release Base ID: 6.0.1 Security Path: 2018-08-01 Device Model: SM-G532F Device Manufacturer: samsung Device Name A: grandpplteser Device Name B: grandpplte Device Board Name: MT6737T Architecture ABI: armeabi-v7a Device manufacturer: samsung Device Platform: mt6737t Product ID: grandpplte Build Description: grandpplteser-user 6.0.1 MMB29T G532FXWU1ASB1 release-keys PDA ver.: G532FXWU1ASB1 Hidden ver.: G532FXWU1ASB1 Samsung CPU: MT6737T MTK SOC Version: S01 MTK Platform: MT6737T MTK Branch: alps-mp-m1.mp8.tc10sp MTK Version: alps-mp-m1.mp8.tc10sp MTK SDK Version: 4 FRP Partition Path: /dev/block/persistent Backup saved: BuildProp_20211128_1132.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00E9400000 (3.632GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: CE8C56E8 46F62B3C BBF1EE3B D139E36C E7567D55 49DD3425 DAAAEEF7 BD8E59A2 ÎŒVèFö+<»ñî;Ñ9ãlçV}UIÝ4%Úªî÷½ŽY¢; E13117A6 1CC1D620 F4CFDABB 15497309 7FFAFA25 E0F5C827 CF2A47CD 027595ED á1.¦.ÁÖ ôÏÚ».Is .úú%àõÈ'Ï*GÍ.u•í; 88C01C1D 907B0843 E13FA8CF 24EAB312 57C84A21 94E2A8B1 425369C2 6E8574BC .À...{.Cá?¨Ï$ê³.WÈJ!”⨱BSiÂn…t¼; 5A6FB711 38F4DEC6 DBFCA6AD EA9A19A4 94EECED7 D935E101 76C5D759 07D1C569 Zo·.8ôÞÆÛü¦*êš.¤”îÎ×Ù5á.vÅ×Y.ÑÅi; 032300B1 B9D021A0 94EA9526 842BBC77 7282B09C BB24C1CB 83028D2F DEAA3150 .#.±¹Ð!*”ê•&„+¼wr‚°œ»$Á˃../Þª1P; CC9C82CA 6B67AD5B 56CFE63C 98E7AF16 2EA8A2E1 ECE2F7E7 FAB9ED76 49CB3C4D Ìœ‚Êkg*[VÏæ<.ç¯..¨¢áìâ÷çú¹ívIË<M; 318DD0B4 FB64D402 4833F982 552FD944 B721D9B0 90D2034C 0DAF78D8 EA81EAE7 1.дûdÔ.H3ù‚U/ÙD·!Ù°.Ò.L.¯xØê.êç; 3C8A6DFC A94ABBDE 4CFD6DFF E33B1498 62599D3D 55EDCC97 E7BBE5FD 6D71F291 <Šmü©J»ÞLýmÿã;..bY.=UíÌ—ç»åýmqò‘; Done. Running:SAMSUNG: eMMC firmware dump... Init OK... Firmware file...C:\Program Files\Z3X\EASYJTAG\g532f hayat\emmc fw\New folder\[email protected] Checking security ... Running:SAMSUNG: MoviNAND Firmware extraction... Z3X EasyJtag Software ver. 3.7.0.24 Skip loading eMMC Addon Firmware CMD Pullup Level:2113 mV CMD Active Level:2258 mV Box IO Level:2800 mV CLK Rate:24000 kHz Checking eMMC BootROM mode Skip loading eMMC Addon Firmware CMD Pullup Level:2111 mV CMD Active Level:2257 mV Box IO Level:2800 mV CLK Rate:24000 kHz --- EasyJTAG Samsung eMMC Backup Tool --- EMMC CID : 150100514E31364242009351EE58C3E3 EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 12/2016 Rev.0x0 EMMC NAME: QN16BB , S/N: 2471620184 EMMC Part Number: KMQN10006B-B318/8GB @BGA221 IC Name: Samsung , KMQN10006B-B318/8GB @BGA221 , Firmware is Updatable EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1/2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB Setup firmware read mode, wait 2..30 sec... Reading eMMC NAND... Trying Block 100000 Trying Block 80000 Trying Block 40000 Trying Block 20000 Trying Block 30000 Trying Block 38000 Trying Block 3c000 Trying Block 3e000 Trying Block 3f000 Trying Block 3f800 Trying Block 3f000 Read Block 3f000 Firmware Dump Success at 3f800 Firmware Hash:19505652A9A128F00D97D067085E2DD6 Firmware already exist in base as:KMFN10012A-B214/8GB @BGA221 Saving eMMC CID Data... Reading eMMC NAND Done. |
11-28-2021, 12:20 | #2 (permalink) | |
Freak Poster Join Date: Dec 2014 Location: nepal,lalitpur
Member: 2306223 Status: Offline Sonork: 1660968:1234 Thanks Meter: 117 | Quote:
2=Then make zero sizes gp partions.. 3=Write dump with org imei data 4=Write firmware .pit+bootloader... 5=Flash full firmware via odin Sent from my SM-A305F using Tapatalk | |
