06-02-2020, 20:17 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 49
Member: 81868 Status: Offline Thanks Meter: 9 | samsung i9195 no partition not possible read user data Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 18 MHz CMD Pullup Level: 1741 mV CMD Active Level: 1856 mV EMMC Device Information : EMMC CID: 45010053454D3038479021AF20E6B073 EMMC CSD: D00F00320F5903FFFFFFFFFF92404011 EMMC Manufacture : SANDISK , EMMC NAME: SEM08G , HEX: 53454D303847 , S/N: 21AF20E6 , rev. 0x90 EMMC Manufacture ID: 0x45 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2013 EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000) EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x03 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: SEM08G_21AF20E6_20200602_211332.extcsd EMMC Init completed. Operation: File Explorer... Scan from: SEM08G Vendor: Qualcomm Searching GPT ... GPT header is not found Searching MBR ... MBR header is not found Partition table not found Scan done |
06-07-2020, 22:55 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
