kothamamun | 07-11-2019 17:42 | **********j100h dead boot repair step by step today this is number 3 Code:
eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019)
Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385)
Looking for EasyJTAG box...
EasyJTAG API ver. 3307
EasyJTAG Box Serial = 0500D01E3BC5A469
Card Serial = AA1373CD
EasyJTAG Box Firmware = 1.63
Changelog:
30.06.2019 (ver 1.6.1.0)
Fix: Bugs that have been found through your crash report
Setting frequence to 21 MHz
CMD Pullup Level: 2103 mV
CMD Active Level: 2371 mV
EMMC Device Information :
EMMC CID: 90014A4834473262110124135A514242
EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA
EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: 24135A51 , rev. 0x01
EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 4/2015
EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G2b_24135A51_20100428_000337.extcsd
EMMC Init completed.
Scanning soft partitions
Entry count: 29
Partition: BOOT, [000000000000 - 000000080000], size: 000000080000
Partition: BOOT2, [000000000000 - 000000100000], size: 000000100000
Partition: SBOOT, [000000400000 - 000000600000], size: 000000200000
Partition: SBOOT2, [000000600000 - 000000800000], size: 000000200000
Partition: wfixnv1, [000000800000 - 000000900000], size: 000000100000
Partition: wfixnv2, [000000900000 - 000000A00000], size: 000000100000
Partition: tdfixnv1, [000000A00000 - 000000B00000], size: 000000100000
Partition: tdfixnv2, [000000B00000 - 000000C00000], size: 000000100000
Partition: WDSP, [000000C00000 - 000001000000], size: 000000400000
Partition: MODEM, [000001000000 - 000001800000], size: 000000800000
Partition: MODEM2, [000001800000 - 000002000000], size: 000000800000
Partition: TDDSP, [000002000000 - 000002400000], size: 000000400000
Partition: FOTA_SIG, [000002400000 - 000002500000], size: 000000100000
Partition: wruntimenv1, [000002500000 - 000002600000], size: 000000100000
Partition: wruntimenv2, [000002600000 - 000002700000], size: 000000100000
Partition: tdruntimenv1, [000002700000 - 000002800000], size: 000000100000
Partition: tdruntimenv2, [000002800000 - 000002900000], size: 000000100000
Partition: PARAM, [000002900000 - 000002B00000], size: 000000200000
Partition: efs, [000002B00000 - 000003F00000], size: 000001400000
Partition: prodnv, [000003F00000 - 000004400000], size: 000000500000
Partition: RESERVED2, [000004400000 - 000004500000], size: 000000100000
Partition: KERNEL, [000004500000 - 000005500000], size: 000001000000
Partition: RECOVERY, [000005500000 - 000006500000], size: 000001000000
Partition: CSC, [000006500000 - 000012D00000], size: 00000C800000
Partition: system, [000012D00000 - 000053D00000], size: 000041000000
Partition: HIDDEN, [000053D00000 - 000056500000], size: 000002800000
Partition: userdata, [000056500000 - 0000E9000000], size: 000092B00000 Code:
CMD Pullup Level: 2093 mV
CMD Active Level: 2382 mV
Backup saved: H4G2b_24135A51_20100428_000443.extcsd
Operation: Universal Factory Format
Please, wait ...
Successfully Code:
Backup saved: H4G2b_24135A51_20100428_000504.extcsd
Operation: Changing GP sizes (test mode) ...
GP1 size: 0 MB , WR_REL: 1 , ENH 0
GP2 size: 0 MB , WR_REL: 1 , ENH 0
GP3 size: 0 MB , WR_REL: 1 , ENH 0
GP4 size: 0 MB , WR_REL: 1 , ENH 0
Zero sizes. This may damage your eMMC
Do you want to continue?
Successfu
lly Code:
CMD Pullup Level: 2083 mV
CMD Active Level: 2392 mV
Backup saved: H4G2b_24135A51_20100428_000515.extcsd
Successfully
Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0] to cancel the changes Code:
Backup saved: H4G2b_24135A51_20100428_000732.extcsd
Partition table not found
Get firmware version
Firmware info not found Code:
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01
Backup saved: H4G2b_24135A51_20100428_011031.extcsd
Operation: Writing all eMMC Regions...
Operation: Writing BootConfig ...
Reg: 179 Value: 0x08
Reg: 177 Value: 0x00
Reg: 162 Value: 0x00
Done
Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_ROM2_H4G2b_2165950698_00000000_00400000.bin
eMMC switching to ROM2
Writing partition...
Done writing partition. Write speed: 333.26 KB/s
Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000
Filename: EMMC_ROM3_H4G2b_2165950698_00000000_00400000.bin
eMMC switching to ROM3
Done writing partition. Write speed: 333.92 KB/s
Writing to: ROM1 , start: 0x000000000000 , size: 0x000010000000
Filename: EMMC_ROM1_H4G2b_2165950698_00000000_10000000.bin
eMMC switching to ROM1
Done writing partition. Write speed: 523.33 KB/s
All done time: [21:19:25:693]
after repair boot just flash ap,cp,cse. enjoy |
