12-16-2016, 14:21 | #1 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Samsung J100H/DS Boot Repair Pinout / Dead Boot Repair File Samsung J100H/DS Boot Repair Pinout / Dead Boot Repair File Code: Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: , ,FW Ver.: 01.55 CMD Pullup Level:2031 mV CMD Active Level:2371 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 1501004E4A325A4D42009E73B45192AC EMMC CSD : D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 09/2015 Rev.0x0 EMMC NAME: NJ2ZMB , S/N: 2658382929 EMMC NAME (HEX): 4E4A325A4D4200 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: NJ2ZMB_2658382929_20161009_1201.extcsd Done. Z3X EasyJtag Software ver. 2.4.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2371 mV Input file : E:\JTAG\Z3X Easy-JTAG\J100H\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing 0040000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 941 kB/s Br [/COLOR Suny125 |
The Following 21 Users Say Thank You to Suny125 For This Useful Post: |
01-24-2017, 04:06 | #4 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | this is tested file ... if still dead must replace emmc SM-J100H(KTU84P.J100HXXU0AOC1-4.4.4 by uf1 b0x - Download - 4shared |
The Following 3 Users Say Thank You to bagus.dps For This Useful Post: |
07-27-2017, 13:11 | #5 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Philippines
Member: 302596 Status: Offline Thanks Meter: 784 | there is a way to write the dump file into j100h ds ? i look on sofotware but only boot 1 and boot 2 can write any screen shot how to write a dump file for this model ? |
The Following User Says Thank You to maxieboy For This Useful Post: |
