04-02-2017, 19:33 | #17 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1168485 Status: Offline Thanks Meter: 36 | i have the same problem after repair boot still dead eMMC_tool Suite ver. 1.0.0.43 Microsoft Windows 7 (64 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2008 Setting IO Levels to 2.8V Setting frequence to 14 Mhz HiPower mode is OFF EasyJTAG Box Firmware = 01.58 Changelog: 09.03.2017 (ver 1.0.0.43) Fix: Bugs that have been found through your crash report Add: Some improvements Add: Write by vendor "Spreadtrum" (While only SC773X) Add: Search for tables nVidia Tegra Add: Completely rewritten Explorer HiPower mode is OFF CMD Pullup Level: 1784 mV CMD Active Level: 2526 mV EMMC Device Information : EMMC CID: 90014A48344732621101B371CCBE827A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B371CCBE , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_B371CCBE_20170402_194506.extcsd EMMC Init completed. Opening file: J13G.pit Pit: J13G.pit Entry count: 29 The size of the last section has been updated BL_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship.tar.md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin param.lfs HiPower mode is OFF CMD Pullup Level: 1794 mV CMD Active Level: 2536 mV EMMC Device Information : EMMC CID: 90014A48344732621101B371CCBE827A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B371CCBE , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_B371CCBE_20170402_194523.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: param.lfs Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 255.40 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1130.24 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1131.19 Kb/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 753.75 Kb/s All done AP_J100HXXU0AOA2_CL332283_QB3547216_REV01_user_low _ship_.tar.md5 The list of files in the firmware: boot.img recovery.img system.img CP_J100HXXU0AOA3_CL332283_QB3609726_REV01_user_low _ship.tar.md5 The list of files in the firmware: sprdcp.img sprddsp.img nvitem.bin CSC_OJV_J100HOJV0AOA2_CL332283_QB3547216_REV01_use r_low_ship.tar.md5 The list of files in the firmware: j13g.pit cache.img hidden.img HiPower mode is OFF CMD Pullup Level: 2701 mV CMD Active Level: 2825 mV Can't init device. Reason: CMD Timeout Error Error: Previous operation is not finished yet. HiPower mode is OFF CMD Pullup Level: 1794 mV Error: Previous operation is not finished yet. CMD Active Level: 2526 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF CMD Pullup Level: 1784 mV CMD Active Level: 2371 mV Can't init device. Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] HiPower mode is OFF CMD Pullup Level: 1773 mV CMD Active Level: 2557 mV EMMC Device Information : EMMC CID: 90014A48344732621101B371CCBE827A EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: B371CCBE , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_B371CCBE_20170402_194845.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: nvitem.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: param.lfs Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 254.55 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1131.52 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1119.68 Kb/s Partition name: WFIXNV2 Filename: nvitem.bin , Offset: 000000900000 , filesize: 174856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 822.77 Kb/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1968128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1189.88 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 7375844 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 903.74 Kb/s Partition name: PARAM Filename: param.lfs , Offset: 000002900000 , filesize: 634880 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 742.62 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5661696 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 905.77 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 6992896 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 917.51 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006500000 , filesize: 22569232 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1004.38 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000012D00000 , filesize: 986538384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 23 Error writing at address: 000026D00000 ... Retry #1 Done writing partition. Write speed: 869.42 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053D00000 , filesize: 7762160 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 13 Done writing partition. Write speed: 1135.72 Kb/s All done |
04-02-2017, 19:36 | #18 (permalink) |
Member: 1168485 Status: Offline Thanks Meter: 36 | Z3X EasyJtag Software ver. 2.5.0.8 Loading eMMC Addon Firmware... IO: 2800 mV CMD Pullup Level:1773 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48344732621101B371CCBE827A EMMC CSD : D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 08/2015 Rev.0x1 EMMC NAME: H4G2b , S/N: 3010579646 EMMC NAME (HEX): 48344732622000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2b _3010579646_20170402_2035.extcsd Done. Checking NAND Image : C:\Users\abou mhamad\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin File successefuly loaded! Checking NAND Image : C:\Program Files\Z3X\EASYJTAG\Backups\H4G2b _3010579646_20170402_1924.extcsd File successefuly loaded! Processing file...C:\Program Files\Z3X\EASYJTAG\Backups\H4G2b _3010579646_20170402_1924.extcsd ROM1 Are not selected , skip writing ROM1 Processing file...C:\Users\abou mhamad\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin ROM3 Are not selected , skip writing ROM3 Running:Repair extCSD... Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1773 mV CMD Active Level:2567 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:1773 mV CMD Active Level:2567 mV Input file : C:\Users\abou mhamad\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 1184 kB/s |
04-03-2017, 06:58 | #19 (permalink) |
Freak Poster Join Date: Oct 2011 Location: uf1 b0x land
Member: 1675290 Status: Offline Thanks Meter: 177 | repair via direct is useless .. if you lucky it fixed but problem will come back 1 week-1month... replace with samsung kmkjs kmk7u kmi8 kmk8 etc so many samsung emmc support this spreadtrum chipset |
The Following User Says Thank You to bagus.dps For This Useful Post: |
04-18-2017, 12:21 | #20 (permalink) |
Insane Poster Join Date: Nov 2014
Member: 2290269 Status: Offline Thanks Meter: 14 | erorr cant werit Processing file...C:\Documents and Settings\Administrator\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing as RAW data Z3X EasyJtag Software ver. 2.5.0.8 Skip loading eMMC Addon Firmware CMD Pullup Level:2155 mV CMD Active Level:2908 mV Input file : C:\Documents and Settings\Administrator\Desktop\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. |
The Following 4 Users Say Thank You to mohanad83998 For This Useful Post: |
05-01-2017, 13:54 | #22 (permalink) | |
Freak Poster Join Date: Jul 2015
Member: 2431503 Status: Offline Thanks Meter: 9 | Quote:
ihave j100h dead after flash write by vendor same problem black screen logo [CODE]eMMC_tool Suite ver. 1.0.0.42 HiPower mode is OFF CMD Pullup Level: 1980 mV CMD Active Level: 2444 mV EMMC Device Information : EMMC CID: 90014A483447326211018FEBDEA13270 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: 8FEBDEA1 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_8FEBDEA1_20170501_015436.extcsd EMMC Init completed. HiPower mode is OFF CMD Pullup Level: 1990 mV CMD Active Level: 2444 mV EMMC Device Information : EMMC CID: 90014A483447326211018FEBDEA13270 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: 8FEBDEA1 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_8FEBDEA1_20170501_015453.extcsd EMMC Init completed. Opening file: J13G.pit Pit: J13G.pit Entry count: 29 The size of the last section has been updated J100HDDU0AQA2_J100HODD0AQA2_J100HDDU0APH1_HOME.tar .md5 The list of files in the firmware: spl.img sboot.bin sboot2.bin boot.img recovery.img system.img sprdcp.img sprddsp.img cache.img hidden.img HiPower mode is OFF CMD Pullup Level: 1990 mV CMD Active Level: 2444 mV EMMC Device Information : EMMC CID: 90014A483447326211018FEBDEA13270 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: 8FEBDEA1 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_8FEBDEA1_20170501_015523.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PIT at address: 000000080000 GPT-partitioning done Unpacking file: spl.img Unpacking file: sboot.bin Unpacking file: sboot2.bin Unpacking file: sprddsp.img Unpacking file: sprdcp.img Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: cache.img Unpacking file: system.img Unpacking file: hidden.img Partition name: BOOT Filename: spl.img , Offset: 000000000000 , filesize: 32768 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 429.17 Kb/s Partition name: SBOOT Filename: sboot.bin , Offset: 000000400000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 998.43 Kb/s Partition name: SBOOT2 Filename: sboot2.bin , Offset: 000000600000 , filesize: 1573888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1013.38 Kb/s Partition name: WDSP Filename: sprddsp.img , Offset: 000000C00000 , filesize: 1967104 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1093.97 Kb/s Partition name: MODEM Filename: sprdcp.img , Offset: 000001000000 , filesize: 7391600 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 860.60 Kb/s Partition name: KERNEL Filename: boot.img , Offset: 000004500000 , filesize: 5696512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 912.92 Kb/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005500000 , filesize: 7033856 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1018.45 Kb/s Partition name: CSC Filename: cache.img , Offset: 000006500000 , filesize: 9834768 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 1295.68 Kb/s Partition name: SYSTEM Filename: system.img , Offset: 000012D00000 , filesize: 982149120 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 1662 Done writing partition. Write speed: 937.26 Kb/s Partition name: HIDDEN Filename: hidden.img , Offset: 000053D00000 , filesize: 35643888 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 29 Done writing partition. Write speed: 1055.29 Kb/s All done [/CODE how fix!! | |
The Following 2 Users Say Thank You to majedjefara For This Useful Post: |
05-06-2017, 07:48 | #23 (permalink) |
Freak Poster Join Date: Jul 2011 Location: Dhaka,Uttara.Bangaladash
Member: 1625192 Status: Offline Sonork: 100.1657037 Thanks Meter: 256 | Hi, Sir I am new man Z3X JTAG Easy I am always Emmc Repair Done But Set No Run Plz Help Me........Video Tutorial Fast And Last Tutorial Thanks, Last edited by MyGSM World; 05-06-2017 at 08:52. Reason: Contact Number Removed. |
The Following 4 Users Say Thank You to hasan99 For This Useful Post: |
11-24-2017, 15:08 | #30 (permalink) |
No Life Poster Join Date: Sep 2005 Location: World wide Age: 40
Member: 185854 Status: Offline Sonork: 100.1592083 Thanks Meter: 286 | samsung j100h dump write error Jtags---Box\File\Samsung\J100H\SM-J100h_J100HXCU0AOD4_ROM1_OK\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing as RAW data Z3X EasyJtag Software ver. 2.6.0.1 Skip loading eMMC Addon Firmware CMD Pullup Level:3155 mV CMD Active Level:3238 mV Input file : F:\Easy Jtags---Box\File\Samsung\J100H\SM-J100h_J100HXCU0AOD4_ROM1_OK\SM-J100h_J100HXCU0AOD4_ROM1_OK.bin Writing 0040000000 bytes to 0000000000... ROM1 (USER ROM) Write Block Failed, Reason: Write Block Verify Error Done. Done with error(s) |
