01-30-2021, 08:20 | #1 (permalink) |
Insane Poster Join Date: Sep 2018 Location: India
Member: 2868909 Status: Offline Thanks Meter: 36 | Samsung j600g stuck on logo , can read by vendor but gives error on erasing/writing I have recieved samsung j600g stuck on logo , doesnt boot into recovery and odin stucks on initialization on flashing , so i tried to flash it via isp by easy jtag. I took backup of security partitions without errors and readed small rom1 backup and 2,3 respectively without any issues . After that I factory reset+format and repaired extcsd file successfully but afterwards on writing the dump file it gives error . Emmc health seems fine to me , please guide me what s wrong i have attached logs below . Any kinda guidance is highly appreciated TY. Logs with emmc plus tool- Code: Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 426 mV CMD Active Level: 1187 mV EMMC Device Information : EMMC CID: 150100424A5444345200FE91EA7465F5 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: FE91EA74 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_FE91EA74_20210130_120254.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: DTBO, [000008300000 - 000008500000], size: 000000200000 (2.00 MB) Partition: RADIO, [000008500000 - 00000DD00000], size: 000005800000 (88.0 MB) Partition: PERSISTENT, [00000DD00000 - 00000DD80000], size: 000000080000 (512. KB) Partition: MISC, [00000DD80000 - 00000DE80000], size: 000000100000 (1.00 MB) Partition: STEADY, [00000DE80000 - 00000E280000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) Partition: SYSTEM, [00000E800000 - 0000FC000000], size: 0000ED800000 (3.71 GB) Partition: VENDOR, [0000FC000000 - 000115000000], size: 000019000000 (400. MB) Partition: ODM, [000115000000 - 000124000000], size: 00000F000000 (240. MB) Partition: CACHE, [000124000000 - 000136C00000], size: 000012C00000 (300. MB) Partition: HIDDEN, [000136C00000 - 00013D000000], size: 000006400000 (100. MB) Partition: OMR, [00013D000000 - 00013E400000], size: 000001400000 (20.0 MB) Partition: CP_DEBUG, [00013E400000 - 00013E900000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [00013E900000 - 00013FD00000], size: 000001400000 (20.0 MB) Partition: USERDATA, [00013FD00000 - 000747500000], size: 000607800000 (24.1 GB) GPT header successfully parsed Get firmware version 30-01-2021 11:49:29> Looking for EasyJTAG box... 30-01-2021 11:49:29> EasyJTAG API ver. 3403 30-01-2021 11:49:29> Setting IO Levels to 1.8V 30-01-2021 11:49:29> Setting frequence to 36 MHz 30-01-2021 11:49:29> EasyJTAG Box Serial = FB2B3F6110A543ED 30-01-2021 11:49:29> EasyJTAG Box Firmware = 2.5301 30-01-2021 11:49:31> Setting interface to EasyJtag2/ISP 30-01-2021 11:49:31> Setting bus width to 1 Bit 30-01-2021 11:49:31> Setting frequence to 36 MHz 30-01-2021 11:49:31> CMD Pullup Level: 426 mV 30-01-2021 11:49:31> CMD Active Level: 1185 mV 30-01-2021 11:49:31> eMMC Init returned = 0 30-01-2021 11:49:31> EMMC Device Information : 30-01-2021 11:49:31> EMMC CID: 150100424A5444345200FE91EA7465F5 30-01-2021 11:49:31> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 30-01-2021 11:49:31> EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: FE91EA74 , rev. 0x00 30-01-2021 11:49:31> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 6/2018 30-01-2021 11:49:31> EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) 30-01-2021 11:49:31> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 30-01-2021 11:49:31> EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean 30-01-2021 11:49:31> EMMC Permanent Write Protection: No 30-01-2021 11:49:31> EMMC Temporary Write Protection: No 30-01-2021 11:49:31> Extended CSD Information : 30-01-2021 11:49:31> Extended CSD rev: 1.8 (MMC 5.1) 30-01-2021 11:49:31> Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) 30-01-2021 11:49:31> Boot Bus Config: 0x01 , width 4bit 30-01-2021 11:49:31> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 30-01-2021 11:49:31> Supported partition features [PARTITIONING_SUPPORT]: 0x07 30-01-2021 11:49:31> Device supports partitioning features 30-01-2021 11:49:31> Device can have enhanced technological features in partitions and user data area 30-01-2021 11:49:31> Device can have extended partitions attribute 30-01-2021 11:49:31> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 30-01-2021 11:49:32> Backup saved: BJTD4R_FE91EA74_20210130_114932.extcsd 30-01-2021 11:49:32> EMMC Init completed. 30-01-2021 11:49:32> 30-01-2021 11:49:32> Operation: Writing all eMMC Regions... 30-01-2021 11:49:32> 30-01-2021 11:49:32> Operation: Writing BootConfig ... 30-01-2021 11:49:32> Reg: 179 Value: 0x48 30-01-2021 11:49:32> Reg: 177 Value: 0x01 30-01-2021 11:49:33> Reg: 162 Value: 0x00 30-01-2021 11:49:33> Done 30-01-2021 11:49:33> 30-01-2021 11:49:34> Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 30-01-2021 11:49:34> Filename: EMMC_BJTD4R_ROM2_000000000000_000000400000.bin 30-01-2021 11:49:34> eMMC switching to ROM2 30-01-2021 11:49:34> Writing partition... 30-01-2021 11:50:05> Error writing at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1 Code: Found 1 serial devices COM3 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM3) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: FB2B3F6110A543ED, ,FW Ver.: 02.53 CMD Pullup Level:948 mV CMD Active Level:1534 mV Box IO Level:1800 mV CLK Rate:36000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A5444345200FE91EA7465F5 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 06/2018 Rev.0x0 eMMC NAME: BJTD4R , S/N: 4270975604 eMMC NAME (HEX): 424A54443452 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB EMMC RPMB is programmed and written 2 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: BJTD4R_4270975604_20210130_1223.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 Warning! One or more CRCs don't match. You should repair the disk! Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB Disk identifier (GUID): 52444E41-494F-2044-4D4D-43204449534B Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326 Partition info successfully found ------ Detected 26 partitions ------ P0 (BOTA0) [0x400000 0x400000] Size: 4.0MB P1 (BOTA1) [0x800000 0x400000] Size: 4.0MB P2 (EFS) [0xc00000 0x1400000] Size: 20.0MB P3 (CPEFS) [0x2000000 0x800000] Size: 8.0MB P4 (M9KEFS1) [0x2800000 0x400000] Size: 4.0MB P5 (M9KEFS2) [0x2c00000 0x400000] Size: 4.0MB P6 (M9KEFS3) [0x3000000 0x400000] Size: 4.0MB P7 (NAD_REFER) [0x3400000 0x100000] Size: 1.0MB P8 (PARAM) [0x3500000 0x800000] Size: 8.0MB P9 (BOOT) [0x3d00000 0x2000000] Size: 32.0MB P10 (RECOVERY) [0x5d00000 0x2600000] Size: 38.0MB P11 (DTBO) [0x8300000 0x200000] Size: 2.0MB P12 (RADIO) [0x8500000 0x5800000] Size: 88.0MB P13 (PERSISTENT) [0xdd00000 0x80000] Size: 512.0KB P14 (MISC) [0xdd80000 0x100000] Size: 1.0MB P15 (STEADY) [0xde80000 0x400000] Size: 4.0MB P16 (RESERVED2) [0xe280000 0x580000] Size: 5.500MB P17 (SYSTEM) [0xe800000 0xed800000] Size: 3.710GB P18 (VENDOR) [0xfc000000 0x19000000] Size: 400.0MB P19 (ODM) [0x115000000 0xf000000] Size: 240.0MB P20 (CACHE) [0x124000000 0x12c00000] Size: 300.0MB P21 (HIDDEN) [0x136c00000 0x6400000] Size: 100.0MB P22 (OMR) [0x13d000000 0x1400000] Size: 20.0MB P23 (CP_DEBUG) [0x13e400000 0x500000] Size: 5.0MB P24 (NAD_FW) [0x13e900000 0x1400000] Size: 20.0MB P25 (USERDATA) [0x13fd00000 0x607800000] Size: 24.117GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000E800000 (3.710GB) Short EXT fs info: Size: 3.678GB Block size: 4.0KB Inode size: 256 Inodes: 241440 Short Android info: Unable to read prop.plist , code : 2 --------------------------------------------- Detected USERDATA USERDATA : 0x013FD00000 (24.117GB) Unable to mount USERDATA , code : 95 Userdata Superblock contents:: E41B1006 CC6B8812 4E99CC0C 65B5D0A1 069473FE 3FB1855F 3A99AA09 0218CE4E ä...Ìk..N.Ì.eµÐ¡.”sþ?±…_:.ª ..ÎN; DF63D9F1 068B55D3 310A97BA 29457B63 DD647AF6 C7804571 EFF52739 5EC36809 ßcÙñ.‹UÓ1.—º)E{cÝdzöÇ.Eqïõ'9^Ãh ; 4FA11EE9 CD9E6964 1400435B DDA585E8 1EFD0F06 A7938570 39136DC9 9782715C O¡.éÍžid..C[Ý¥…è.ý..§“…p9.mÉ—‚q\; 461281A2 9D3A12AF 202D9D77 0ADADF64 0C3039DF 2E2461A5 291EC88E 9764C707 F..¢.:.¯ -.w.Úßd.09ß.$a¥).ÈŽ—dÇ.; 41A3D050 F7748E26 44442D60 99805636 EEB197EB 220E1F41 FDA9B603 078FFB21 A£ÐP÷tŽ&DD-`..V6î±—ë"..Aý©¶...û!; 70B9A82A 84708FCA 46559C84 B4D77E66 9808321D 43F2318E 5A10CE80 89634A28 p¹¨*„p.ÊFUœ„´×~f..2.Cò1ŽZ.Î.‰cJ(; FE538732 E4675F4B 400D62F5 E3402732 1A6479C7 CA71439F 31518B1F 154B5705 þS‡2ä[email protected]õã@'2.dyÇÊqCŸ1Q‹..KW.; 9C4B35E5 54139885 34E9FD9B 40169555 0A5FFDB7 75F48A15 AE510AC8 4B7E21BF œK5åT..…4éý›@.•U._ý·uôŠ.®Q.ÈK~!¿; Done. Checking NAND Image : C:\Users\TARIQ\Desktop\j600g\EMMC_BJTD4R_ROM1_000000000000_000020000000.bin Autodetected RAW data Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Found ROM2 and automatically selected. Found ROM3 and automatically selected. Found EXT CSD and automatically selected. Processing file...C:\Users\TARIQ\Desktop\j600g\BJTD4R_FE91EA74_20210129_182833.extcsd Processing file...C:\Users\TARIQ\Desktop\j600g\EMMC_BJTD4R_ROM1_000000000000_000020000000.bin Processing file...C:\Users\TARIQ\Desktop\j600g\EMMC_BJTD4R_ROM2_000000000000_000000400000.bin Processing file...C:\Users\TARIQ\Desktop\j600g\EMMC_BJTD4R_ROM3_000000000000_000000400000.bin Checking security ... Running:Repair extCSD... Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:451 mV CMD Active Level:1180 mV Box IO Level:1800 mV CLK Rate:14000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xc7810000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x03] i.e. 20% - 30% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x03] i.e. 20% - 30% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x10] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x03 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x4b] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x07] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x01] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x03a3e000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x4c] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x47] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x2b] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x02] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x48] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x01] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x80 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x14 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x00 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000747 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 5.1 Done. Checking security ... Z3X EasyJtag Software ver. 3.7.0.20 Skip loading eMMC Addon Firmware CMD Pullup Level:451 mV CMD Active Level:1196 mV Input file : C:\Users\TARIQ\Desktop\j600g\EMMC_BJTD4R_ROM1_000000000000_000020000000.bin Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM) Error writing address 0x00000000 Error Code:-4 Reason :DATA RCV CRC Error Retry writing address 0x0000000000 (Attempt #1)... |
02-04-2021, 11:13 | #3 (permalink) | |
Member: 2868909 Status: Offline Thanks Meter: 36 | Quote:
1- Tried all combination of voltages and frequency but same issue. 2- Cross checked isp connection , medium length wire (around 5-6 cm) plus thick connection for ground 3- Even if i write by vendor on ROM 1 it yields same error 4- If its read only memory , can it be fixed ? Any kinda guidance is highly appreciated TY. | |
