Samsung J7 Prime G6100 Backup Emmc Dump Success Code: HiPower mode is ON https://www.youtube.com/watch?v=WbsxCUgyLqM&t=124s |
need dump file plz share:) |
thanks raisalina Samsung J7 Prime G6100 FRP done Setting frequence to 21 Mhz CMD Pullup Level: 1990 mV CMD Active Level: 2629 mV EMMC Device Information : EMMC CID: 150100525831424D4210F61CC20A836A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: F61CC20A , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_F61CC20A_20190516_170825.extcsd EMMC Init completed. Get firmware version Brand = samsung Manufacturer = samsung Device = on7xltechn Model = SM-G6100 Phone platform = msm8953 CPU Abi = arm64-v8a Android release = 8.0.0 Firmware version = R16NW.G6100ZHU2CRI8 Firmware date = Sun Sep 30 08:52:46 KST 2018 Setting frequence to 21 Mhz CMD Pullup Level: 1980 mV CMD Active Level: 2619 mV EMMC Device Information : EMMC CID: 150100525831424D4210F61CC20A836A EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: F61CC20A , rev. 0x10 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 8/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_F61CC20A_20190516_170838.extcsd EMMC Init completed. Operation: Remove FRP Searching GPT ... GPT header is found and is valid FRP partition found (partname: persistent) Erasing FRP partition ... Done erasing partition. All done |
can you upload dump file ???? |
Can you pleasae give dump? |
sm-G6100 Quote:
Thanks............................................ .......... |
please i need dump sm-g6100 dead boot after write comb file i repair boot from factory file but no power on please dump link ? ? |
Share dump sir,i have dead boot |
hi bro, please shared dump file. |
