11-24-2014, 23:36 | #4 (permalink) |
Junior Member Join Date: Jul 2009
Member: 1080305 Status: Offline Sonork: 16000 Thanks Meter: 4 | this emmc for i9100 not i9300 for repair your phone must E-MATE box http://forum.gsmhosting.com/vbb/f672...moorc-1805878/ or remplace emmc i9300 |
11-25-2014, 11:38 | #6 (permalink) |
No Life Poster Join Date: Apr 2006 Location: APPLE i Center Age: 39
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | i have the following error i think it is related to data0 point Code: Z3X EasyJtag Software ver. 1.6.6.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 0E0EF514204F97C3, ,FW Ver.: 01.50 CMD Pullup Level:1443 mV CMD Active Level:1732 mV eMMC Device Information EMMC CID : 15010056594C30304D19D2F361B7AE58 EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 10/2011 Rev.0x19 EMMC NAME: VYL00M , S/N: 3539165623 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line !!! |
11-26-2014, 05:13 | #7 (permalink) |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | any one have no idea about it????? @supporters are you sleeping or what?or you have no such knowledge about this issue?? |
11-27-2014, 03:12 | #9 (permalink) |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | This eMMC are larger data pins and resistors are UNDER eMMC. You can unsolder it and see by yourself. Chinese work ;-) Secret in attached image ->> Last edited by NoName®; 11-27-2014 at 17:31. |
11-29-2014, 00:45 | #10 (permalink) |
Freak Poster Join Date: Aug 2006 Location: ALGERIA
Member: 334901 Status: Offline Thanks Meter: 28 | [QUOTE=NoName®;10702604]This eMMC are larger data pins and resistors are UNDER eMMC. You can unsolder it and see by yourself. Chinese work ;-) Secret in attached image ->>[ i don't understand |
11-29-2014, 07:43 | #11 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Oued zenati Algeria Age: 44
Member: 266158 Status: Offline Sonork: 131654654654 Thanks Meter: 198 | i have removed this emmc after i sloder to Bga2 FORM EASY JTAG adapter and i programed it with eazy jtag Z3X EasyJtag Software ver. 1.6.6.0 Loading eMMC Addon Firmware... IO: 1850 mV Box S/N: 15nn8nnn30n2, ,FW Ver.: 01.50 CMD Pullup Level:2083 mV CMD Active Level:2206 mV eMMC Device Information EMMC CID : 15010056594C30304D19854D136A8EFC EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 08/2011 Rev.0x19 EMMC NAME: VYL00M , S/N: 2236420970 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VYL00M_2236420970_20141006_0124.extcsd Done. Z3X EasyJtag Software ver. 1.6.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2206 mV Input file : D:\e\fateh\Mobile\box\eazy jtag\i9300\EMMC_ROM2_2Mb_BOOT_2\EMMC_ROM2_00000000 _00200000.bin Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Length has been corrected to 0x000000080000 bytes... Write Speed: 250 kB/s Done !!! Z3X EasyJtag Software ver. 1.6.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2206 mV Input file : D:\e\fateh\Mobile\box\eazy jtag\i9300\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000 _20000000.bin Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM) Write Speed: 2381 kB/s Done !!! Running:Change BOOT CONFIG... Z3X EasyJtag Software ver. 1.6.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2206 mV Writing eMMC Register... Written: REG : 179 VAL :48 Done. Running:Change BOOT WIDTH... Z3X EasyJtag Software ver. 1.6.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2206 mV Writing eMMC Register... Written: REG : 177 VAL :1 Done. Z3X EasyJtag Software ver. 1.6.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2083 mV CMD Active Level:2206 mV Input file : D:\e\fateh\Mobile\box\eazy jtag\i9300\EMMC_ROM2_2Mb_BOOT_2\EMMC_ROM2_00000000 _00200000.bin Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Write Length has been corrected to 0x000000080000 bytes... Write Speed: 250 kB/s Done !!! |
12-01-2014, 14:10 | #12 (permalink) | |
Member: 264667 Status: Offline Sonork: 100.105892 Thanks Meter: 481 | Code:
did you use wire for connection to BGA EMMC Chip???? | |
