Old 12-03-2018, 14:23   #1 (permalink)
Member: 2874213
Thanks Meter: 9
Cool sm-j600f pinout opration successful
Setting frequence to 21 Mhz
CMD Pullup Level: 928 mV
CMD Active Level: 1959 mV
EMMC Device Information :
EMMC CID: 150100424A5444345200DE0FFE764554
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: DE0FFE76 , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 4/2018
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: BJTD4R_DE0FFE76_20181203_155843.extcsd
EMMC Init completed.
Scanning soft partitions
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB)
Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB)
Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB)
Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB)
Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB)
Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB)
Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB)
Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB)
Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB)
Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB)
Partition: DTBO, [000008300000 - 000008500000], size: 000000200000 (2.00 MB)
Partition: RADIO, [000008500000 - 00000DD00000], size: 000005800000 (88.0 MB)
Partition: PERSISTENT, [00000DD00000 - 00000DD80000], size: 000000080000 (512. KB)
Partition: MISC, [00000DD80000 - 00000DE80000], size: 000000100000 (1.00 MB)
Partition: STEADY, [00000DE80000 - 00000E280000], size: 000000400000 (4.00 MB)
Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB)
Partition: SYSTEM, [00000E800000 - 0000FC000000], size: 0000ED800000 (3.71 GB)
Partition: VENDOR, [0000FC000000 - 000115000000], size: 000019000000 (400. MB)
Partition: ODM, [000115000000 - 000130800000], size: 00001B800000 (440. MB)
Partition: CACHE, [000130800000 - 000143400000], size: 000012C00000 (300. MB)
Partition: HIDDEN, [000143400000 - 000143E00000], size: 000000A00000 (10.0 MB)
Partition: OMR, [000143E00000 - 000145200000], size: 000001400000 (20.0 MB)
Partition: CP_DEBUG, [000145200000 - 000145700000], size: 000000500000 (5.00 MB)
Partition: NAD_FW, [000145700000 - 000146B00000], size: 000001400000 (20.0 MB)
Partition: USERDATA, [000146B00000 - 000747700000], size: 000600C00000 (24.0 GB)
GPT header successfully parsed
Get firmware version
Brand = samsung
Manufacturer = samsung
Model = SM-J600F
CPU Abi = armeabi-v7a
Android release = 8.0.0
Firmware version = R16NW.J600FXXU1ARE2
Firmware date = Wed May 2 20:46:30 KST 2018
CMD Pullup Level: 917 mV
CMD Active Level: 1949 mV
Backup saved: BJTD4R_DE0FFE76_20181203_155902.extcsd
Operation 'Remove FRP'
Searching GPT ...
FRP partition found (partname: PERSISTENT)
Erasing FRP partition ...
Done erasing partition.
All done
Backup saved: BJTD4R_DE0FFE76_20181203_160232.extcsd
Backup partition: PrimaryGPT
Address: 000000000000, size: 000000004400
GPTHeader is valid
Partition name: bootloader_rom2
Address: 000000000000, size: 000000400000
eMMC switching to ROM2
Reading partition...
Done reading partition. Read speed: 961.08 Kb/s
Partition name: BOTA0
Address: 000000400000, size: 000000400000
eMMC switching to ROM1
Done reading partition. Read speed: 1068.96 Kb/s
Partition name: BOTA1
Address: 000000800000, size: 000000400000
Done reading partition. Read speed: 1068.88 Kb/s
Partition name: EFS
Address: 000000C00000, size: 000001400000
Done reading partition. Read speed: 1065.81 Kb/s
Partition name: CPEFS
Address: 000002000000, size: 000000800000
Done reading partition. Read speed: 1066.65 Kb/s
Partition name: m9kefs1
Address: 000002800000, size: 000000400000
Done reading partition. Read speed: 1068.27 Kb/s
Partition name: m9kefs2
Address: 000002C00000, size: 000000400000
Done reading partition. Read speed: 1068.68 Kb/s
Partition name: m9kefs3
Address: 000003000000, size: 000000400000
Done reading partition. Read speed: 1068.55 Kb/s
Partition name: NAD_REFER
Address: 000003400000, size: 000000100000
Done reading partition. Read speed: 1067.95 Kb/s
Partition name: PARAM
Address: 000003500000, size: 000000800000
Done reading partition. Read speed: 1068.28 Kb/s
Partition name: BOOT
Address: 000003D00000, size: 000002000000
Done reading partition. Read speed: 1063.66 Kb/s
Partition name: RECOVERY
Address: 000005D00000, size: 000002600000
Done reading partition. Read speed: 1064.11 Kb/s
Partition name: DTBO
Address: 000008300000, size: 000000200000
Done reading partition. Read speed: 1069.17 Kb/s
Partition name: RADIO
Address: 000008500000, size: 000005800000
Done reading partition. Read speed: 1067.52 Kb/s
Partition name: PERSISTENT
Address: 00000DD00000, size: 000000080000
Done reading partition. Read speed: 1068.22 Kb/s
Partition name: MISC
Address: 00000DD80000, size: 000000100000
Done reading partition. Read speed: 1067.57 Kb/s
Partition name: STEADY
Address: 00000DE80000, size: 000000400000
Done reading partition. Read speed: 1068.19 Kb/s
Partition name: RESERVED2
Address: 00000E280000, size: 000000580000
Done reading partition. Read speed: 1068.86 Kb/s
Partition name: VENDOR
Address: 0000FC000000, size: 000019000000
Done reading partition. Read speed: 1065.61 Kb/s
Partition name: ODM
Address: 000115000000, size: 00001B800000
Done reading partition. Read speed: 1037.62 Kb/s
Partition name: OMR
Address: 000143E00000, size: 000001400000
Done reading partition. Read speed: 946.84 Kb/s
Partition name: CP_DEBUG
Address: 000145200000, size: 000000500000
Done reading partition. Read speed: 1063.57 Kb/s
Partition name: NAD_FW
Address: 000145700000, size: 000001400000
Done reading partition. Read speed: 1065.30 Kb/s
All done time: [00:18:15:509]
Backup saved: BJTD4R_DE0FFE76_20181203_162424.extcsd
Reading from: ROM2 , start: 0x000000000000 , size: 0x000000400000
Output file: D:j600f\r2;3\EMMC_BJTD4R_ROM2_000000000000_0000004 00000.bin
Done reading partition. Read speed: 958.68 Kb/s
All done time: [00:00:05:470]
Backup saved: BJTD4R_DE0FFE76_20181203_162502.extcsd
Reading from: ROM3 , start: 0x000000000000 , size: 0x000000400000
Output file: D:j600f\r2;3\EMMC_BJTD4R_ROM3_000000000000_0000004 00000.bin
eMMC switching to ROM3
Done reading partition. Read speed: 960.41 Kb/s
All done time: [00:00:05:410]
Old 12-03-2018, 22:37   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
GPTHeader is valid
When you run "read by vendor", ROM2/3 is already backuped
No needs to read it
The Following User Says Thank You to layder For This Useful Post:
Page generated in 0.18482 seconds with 8 queries
