10-10-2017, 06:48 | #1 (permalink) |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | HTC M9 emmc repair done again before repair emmc log :- Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.60 CMD Pullup Level:1742 mV CMD Active Level:2536 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48424734650507A197907022F2 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 2711064688 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _2711064688_20171008_1700.extcsd Caution: invalid backup GPT header, but valid main header! EFI Table CRC Check FAIL. Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A40000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Found Data areas (firmware parts) count is: 70 Partition info successfully found --------------------------------------------- P0 (BOARD_INFO) [0x4400 0x4000] Size: 16.0KB P1 (PG1FS) [0x8400 0x400000] Size: 4.0MB P2 (SBL1) [0x408400 0x100000] Size: 1.0MB P3 (PMIC) [0x508400 0x100000] Size: 1.0MB P4 (DUMMY) [0x608400 0x2800000] Size: 40.0MB P5 (RESERVE_1) [0x2e08400 0x1f7c00] Size: 1.967MB P6 (MFG) [0x3000000 0x40000] Size: 256.0KB P7 (PG2FS) [0x3040000 0x17afc00] Size: 23.686MB P8 (RPM) [0x47efc00 0x80000] Size: 512.0KB P9 (TZ) [0x486fc00 0x200000] Size: 2.0MB P10 (SDI) [0x4a6fc00 0x18000] Size: 96.0KB P11 (HYP) [0x4a87c00 0x200000] Size: 2.0MB P12 (ABOOT) [0x4c87c00 0x100000] Size: 1.0MB P13 (TOOL_DIAG) [0x4d87c00 0xa00000] Size: 10.0MB P14 (SP1) [0x5787c00 0xa00000] Size: 10.0MB P15 (DDR) [0x6187c00 0x100000] Size: 1.0MB P16 (RFG_0) [0x6287c00 0x100000] Size: 1.0MB P17 (RFG_1) [0x6387c00 0x100000] Size: 1.0MB P18 (RFG_2) [0x6487c00 0x100000] Size: 1.0MB P19 (RFG_3) [0x6587c00 0x100000] Size: 1.0MB P20 (RFG_4) [0x6687c00 0x100000] Size: 1.0MB P21 (RFG_5) [0x6787c00 0x100000] Size: 1.0MB P22 (RFG_6) [0x6887c00 0x100000] Size: 1.0MB P23 (RFG_7) [0x6987c00 0x100000] Size: 1.0MB P24 (FSG) [0x6a87c00 0x180000] Size: 1.500MB P25 (RADIO) [0x6c07c00 0x3b00400] Size: 59.0MB P26 (ADSP) [0xa708000 0x1400000] Size: 20.0MB P27 (LIMITS) [0xbb08000 0x400] Size: 1.0KB P28 (RESERVE_2) [0xbb08400 0x4f7c00] Size: 4.967MB P29 (PERSIST) [0xc000000 0x1600000] Size: 22.0MB P30 (RAMDUMP) [0xd600000 0xa00000] Size: 10.0MB P31 (MISC) [0xe000000 0x100000] Size: 1.0MB P32 (MODEM_ST1) [0xe100000 0x180000] Size: 1.500MB P33 (MODEM_ST2) [0xe280000 0x180000] Size: 1.500MB P34 (FATALDEVLOG) [0xe400000 0x1400000] Size: 20.0MB P35 (DEVLOG) [0xf800000 0x1e00000] Size: 30.0MB P36 (PDATA) [0x11600000 0x40000] Size: 256.0KB P37 (CONTROL) [0x11640000 0x4000] Size: 16.0KB P38 (EXTRA) [0x11644000 0x10000] Size: 64.0KB P39 (CDMA_RECORD) [0x11654000 0x100000] Size: 1.0MB P40 (FSC) [0x11754000 0x400] Size: 1.0KB P41 (SSD) [0x11754400 0x2000] Size: 8.0KB P42 (SENSOR_HUB) [0x11756400 0x80000] Size: 512.0KB P43 (SEC) [0x117d6400 0x20000] Size: 128.0KB P44 (ABOOTBAK) [0x117f6400 0x100000] Size: 1.0MB P45 (CIR_IMG) [0x118f6400 0x2800] Size: 10.0KB P46 (LOCAL) [0x118f8c00 0x140400] Size: 1.250MB P47 (FRP) [0x11a39000 0x80000] Size: 512.0KB P48 (CPE) [0x11ab9000 0x200000] Size: 2.0MB P49 (CARRIER) [0x11cb9000 0x1400000] Size: 20.0MB P50 (SKYLINK) [0x130b9000 0x40000] Size: 256.0KB P51 (RFG_8) [0x130f9000 0x20000] Size: 128.0KB P52 (RFG_9) [0x13119000 0x20000] Size: 128.0KB P53 (RFG_10) [0x13139000 0x20000] Size: 128.0KB P54 (RFG_11) [0x13159000 0x20000] Size: 128.0KB P55 (RFG_12) [0x13179000 0x20000] Size: 128.0KB P56 (RFG_13) [0x13199000 0x20000] Size: 128.0KB P57 (RFG_14) [0x131b9000 0x20000] Size: 128.0KB P58 (RFG_15) [0x131d9000 0x20000] Size: 128.0KB P59 (ABSOLUTE) [0x131f9000 0x1000000] Size: 16.0MB P60 (RESERVE) [0x141f9000 0xe07000] Size: 14.27MB P61 (HOSD) [0x15000000 0x4000000] Size: 64.0MB P62 (BOOT) [0x19000000 0x4000000] Size: 64.0MB P63 (RECOVERY) [0x1d000000 0x4000000] Size: 64.0MB P64 (CACHE) [0x21000000 0x14000000] Size: 320.0MB P65 (SYSTEM) [0x35000000 0x118000000] Size: 4.375GB P66 (USERDATA) [0x14d000000 0x5e0000000] Size: 23.500GB P67 (APPPRELOAD) [0x72d000000 0x12200000] Size: 290.0MB P68 (COTA) [0x73f200000 0x3c00000] Size: 60.0MB P69 (BATTERY) [0x742e00000 0xa00000] Size: 10.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0035000000 (4.375GB) Device Model: HTC One M9 Build ID: NRD90M Display Build ID: NRD90M release-keys Release ID: 7.0 Device Model: MSM8994 for arm64 Device Name: himauhl_htc_europe Architecture ABI: arm64-v8a Device manufacturer: HTC Device Platform: msm8994 Product ID: htc_himauhl Build Description: 4.28.401.3 CL869604 release-keys Build Description: 4.28.401.3 CL869604 release-keys Build Description: 4.28.401.3 CL869604 release-keys --------------------------------------------- Done. after repair emmc log :- Compression is ON Z3X EasyJtag Software ver. 2.6.0.1 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0B00100EE1608FB2, ,FW Ver.: 01.60 CMD Pullup Level:1268 mV CMD Active Level:2815 mV Box IO Level:3300 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48424734650507A197907022F2 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 2711064688 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x01 --------------------------------------------- Backup saved: HBG4e _2711064688_20171008_1807.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A40000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Found Data areas (firmware parts) count is: 70 Partition info successfully found --------------------------------------------- P0 (BOARD_INFO) [0x4400 0x4000] Size: 16.0KB P1 (PG1FS) [0x8400 0x400000] Size: 4.0MB P2 (SBL1) [0x408400 0x100000] Size: 1.0MB P3 (PMIC) [0x508400 0x100000] Size: 1.0MB P4 (DUMMY) [0x608400 0x2800000] Size: 40.0MB P5 (RESERVE_1) [0x2e08400 0x1f7c00] Size: 1.967MB P6 (MFG) [0x3000000 0x40000] Size: 256.0KB P7 (PG2FS) [0x3040000 0x17afc00] Size: 23.686MB P8 (RPM) [0x47efc00 0x80000] Size: 512.0KB P9 (TZ) [0x486fc00 0x200000] Size: 2.0MB P10 (SDI) [0x4a6fc00 0x18000] Size: 96.0KB P11 (HYP) [0x4a87c00 0x200000] Size: 2.0MB P12 (ABOOT) [0x4c87c00 0x100000] Size: 1.0MB P13 (TOOL_DIAG) [0x4d87c00 0xa00000] Size: 10.0MB P14 (SP1) [0x5787c00 0xa00000] Size: 10.0MB P15 (DDR) [0x6187c00 0x100000] Size: 1.0MB P16 (RFG_0) [0x6287c00 0x100000] Size: 1.0MB P17 (RFG_1) [0x6387c00 0x100000] Size: 1.0MB P18 (RFG_2) [0x6487c00 0x100000] Size: 1.0MB P19 (RFG_3) [0x6587c00 0x100000] Size: 1.0MB P20 (RFG_4) [0x6687c00 0x100000] Size: 1.0MB P21 (RFG_5) [0x6787c00 0x100000] Size: 1.0MB P22 (RFG_6) [0x6887c00 0x100000] Size: 1.0MB P23 (RFG_7) [0x6987c00 0x100000] Size: 1.0MB P24 (FSG) [0x6a87c00 0x180000] Size: 1.500MB P25 (RADIO) [0x6c07c00 0x3b00400] Size: 59.0MB P26 (ADSP) [0xa708000 0x1400000] Size: 20.0MB P27 (LIMITS) [0xbb08000 0x400] Size: 1.0KB P28 (RESERVE_2) [0xbb08400 0x4f7c00] Size: 4.967MB P29 (PERSIST) [0xc000000 0x1600000] Size: 22.0MB P30 (RAMDUMP) [0xd600000 0xa00000] Size: 10.0MB P31 (MISC) [0xe000000 0x100000] Size: 1.0MB P32 (MODEM_ST1) [0xe100000 0x180000] Size: 1.500MB P33 (MODEM_ST2) [0xe280000 0x180000] Size: 1.500MB P34 (FATALDEVLOG) [0xe400000 0x1400000] Size: 20.0MB P35 (DEVLOG) [0xf800000 0x1e00000] Size: 30.0MB P36 (PDATA) [0x11600000 0x40000] Size: 256.0KB P37 (CONTROL) [0x11640000 0x4000] Size: 16.0KB P38 (EXTRA) [0x11644000 0x10000] Size: 64.0KB P39 (CDMA_RECORD) [0x11654000 0x100000] Size: 1.0MB P40 (FSC) [0x11754000 0x400] Size: 1.0KB P41 (SSD) [0x11754400 0x2000] Size: 8.0KB P42 (SENSOR_HUB) [0x11756400 0x80000] Size: 512.0KB P43 (SEC) [0x117d6400 0x20000] Size: 128.0KB P44 (ABOOTBAK) [0x117f6400 0x100000] Size: 1.0MB P45 (CIR_IMG) [0x118f6400 0x2800] Size: 10.0KB P46 (LOCAL) [0x118f8c00 0x140400] Size: 1.250MB P47 (FRP) [0x11a39000 0x80000] Size: 512.0KB P48 (CPE) [0x11ab9000 0x200000] Size: 2.0MB P49 (CARRIER) [0x11cb9000 0x1400000] Size: 20.0MB P50 (SKYLINK) [0x130b9000 0x40000] Size: 256.0KB P51 (RFG_8) [0x130f9000 0x20000] Size: 128.0KB P52 (RFG_9) [0x13119000 0x20000] Size: 128.0KB P53 (RFG_10) [0x13139000 0x20000] Size: 128.0KB P54 (RFG_11) [0x13159000 0x20000] Size: 128.0KB P55 (RFG_12) [0x13179000 0x20000] Size: 128.0KB P56 (RFG_13) [0x13199000 0x20000] Size: 128.0KB P57 (RFG_14) [0x131b9000 0x20000] Size: 128.0KB P58 (RFG_15) [0x131d9000 0x20000] Size: 128.0KB P59 (ABSOLUTE) [0x131f9000 0x1000000] Size: 16.0MB P60 (RESERVE) [0x141f9000 0xe07000] Size: 14.27MB P61 (HOSD) [0x15000000 0x4000000] Size: 64.0MB P62 (BOOT) [0x19000000 0x4000000] Size: 64.0MB P63 (RECOVERY) [0x1d000000 0x4000000] Size: 64.0MB P64 (CACHE) [0x21000000 0x14000000] Size: 320.0MB P65 (SYSTEM) [0x35000000 0x118000000] Size: 4.375GB P66 (USERDATA) [0x14d000000 0x5e0000000] Size: 23.500GB P67 (APPPRELOAD) [0x72d000000 0x12200000] Size: 290.0MB P68 (COTA) [0x73f200000 0x3c00000] Size: 60.0MB P69 (BATTERY) [0x742e00000 0xa00000] Size: 10.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0035000000 (4.375GB) Device Model: HTC One M9 Build ID: LMY47O Display Build ID: LMY47O release-keys Release ID: 5.1 Device Model: MSM8994 for arm64 Device Model: MSM8994 for arm64 Device Name: himauhl_htc_europe Architecture ABI: arm64-v8a Device manufacturer: HTC Device Platform: msm8994 Product ID: htc_himauhl Build Description: 2.10.401.1 CL576582 release-keys Build Description: 2.10.401.1 CL576582 release-keys Build Description: 2.10.401.1 CL576582 release-keys --------------------------------------------- Done. |
The Following 7 Users Say Thank You to ALI_MAFIA For This Useful Post: |
10-19-2017, 10:56 | #3 (permalink) |
No Life Poster Join Date: Apr 2007 Location: India
Member: 481609 Status: Offline Sonork: 100.1659889 Thanks Meter: 367 | how to repair this can u explain it "Caution: invalid backup GPT header, but valid main header! EFI Table CRC Check FAIL. Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged" |
10-19-2017, 12:18 | #4 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Poland Age: 39
Member: 219917 Status: Offline Thanks Meter: 60 | It will back again in next few days. EMMC is probably already dead in this phone. ALWAYS CHECK SMART REPORT of EMMC in M9. Those Hynics chips are piece of sh@$ |
02-26-2018, 15:31 | #5 (permalink) |
Freak Poster Join Date: Apr 2012 Location: Rangpur
Member: 1747434 Status: Offline Sonork: 5400 Thanks Meter: 13 | After Write Done But Not power on eMMC_tool Suite ver. 1.4.9.0 (release date: 12.12.2017) Microsoft Windows 7 (32 bit) build 7600 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 2022 EasyJTAG Box Serial = 0100E01C0451F95B Card Serial = AA2E-6087 EasyJTAG Box Firmware = 1.62 Changelog: 12.12.2017 (ver 1.4.9.0) Fix: Bugs that have been found through your crash report Fix: RandomVerify function Fix: Creation of GPT for Samsung (write by vendor) Fix: Failed to mount large Fat partitions (explorer) Fix: Extraction from contact2.db (explorer) Fix: Error in the "build.prop" parser Fix: CID Parser Add: Support for EasyJtag Plus Box Add: Path for TempDir and InitialDir (option in settings) Add: Unpack Lenovo QSB (utilities) Add: Selecting a PIT file from CSC (write by vendor Samsung) Add: Detect for encrypted dumps from GPG Box Add: Detect for FullDiskEncryption Partition (explorer) Add: LinearVerify of the Partition (read by vendor) Add: Information base about emmc compatibility (thanks to phonemicrodb) Add: Resizing the window (for small screen resolutions) Add: Converting large partitions in SparseImage when reading by vendor (option in settings) Add: Mounting SparseImage (explorer) Add: Automatic backup of the EFS partition for Samsung (read by vendor) Add: Formatting of EFS partition for Samsung on request (write by vendor) Setting frequence to 21 Mhz CMD Pullup Level: 0 mV CMD Active Level: 2010 mV Can't init device. Reason: CMD Timeout Error Setting frequence to 21 Mhz CMD Pullup Level: 1732 mV CMD Active Level: 2320 mV EMMC Device Information : EMMC CID: 90014A484247346505076FB6CC12226C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HBG4e , EMMC NAME (HEX): 484247346500 , S/N: 6FB6CC12 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4e_6FB6CC12_20180226_193544.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Scanning soft partitions Partition table not found Setting frequence to 21 Mhz CMD Pullup Level: 1722 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 90014A484247346505076FB6CC12226C EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture Name: SKHYNIX , EMMC NAME: HBG4e , EMMC NAME (HEX): 484247346500 , S/N: 6FB6CC12 , rev. 0x07 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Manufacture Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4e_6FB6CC12_20180226_193613.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Operation: Write Dump Writing to: ROM1 , start: 0x000000000000 , size: 0x00004D800000 Input file: C:\Users\Software Point\Downloads\Compressed\HTC_M9_BGND3R_ROM1_OK\H TC_M9_BGND3R_ROM1_OK.bin eMMC switching to ROM1 Writing partition... Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #1 Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #2 Error writing at address: 000000000000 , error: 512, 512 Unknown error ... Retry #3 Done writing partition. Write speed: 511.75 KB/s All done time: [00:41:21:645] |
02-26-2018, 17:43 | #7 (permalink) |
Freak Poster Join Date: Feb 2004 Location: Romania Age: 48
Member: 52722 Status: Offline Thanks Meter: 18 | Hello I have fix same problem EMMC ROM 1 (Main User Data) Capacity: 29824 MB (000748000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Extended CSD Information : Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) Supported partition features [PARTITIONING_SUPPORT]: 0x07 Backup saved: HBG4e_19B4CC84_20180226_183820.extcsd EMMC Init completed. Warning: Health report is very BAD Device Life Time Estimation (MLC) [269]: 0x0B Exceeded its maximum estimated device life time Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x03 Urgent Do you solved this problem??? BR mihnea |
The Following User Says Thank You to Mihnea For This Useful Post: |
02-27-2018, 06:45 | #8 (permalink) | |
Member: 1747434 Status: Offline Sonork: 5400 Thanks Meter: 13 | Quote:
i am a new user how tot solve ? And help me bro | |
02-28-2018, 03:33 | #9 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
The Following User Says Thank You to NoName® For This Useful Post: |
04-14-2018, 17:44 | #11 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 306659 Status: Offline Sonork: 100.1608493 Thanks Meter: 32 | Gpt not present help me Z3X EasyJtag Software ver. 2.9.0.2 Loading eMMC GEN1 Firmware... IO: 2800 mV Box S/N: 01FFD004D9F5A02E, ,FW Ver.: 01.62 CMD Pullup Level:1784 mV CMD Active Level:2330 mV Box IO Level:2800 mV CLK Rate:14000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A484247346505072F44C873421E EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 04/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 793036915 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _ 793036915_20180413_2139.extcsd Partition table scan: GPT: not present Done. |
04-24-2018, 12:17 | #12 (permalink) |
No Life Poster Join Date: Nov 2005 Location: morrocco
Member: 201359 Status: Offline Sonork: 100.1607870 Thanks Meter: 128 | ---------- eMMC Device Information ---------- EMMC CID : 90014A48424734650507A5B49CDF22B4 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 2780077279 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _2780077279_20180424_0940.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A40000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Found Data areas (firmware parts) count is: 70 Partition info successfully found --------------------------------------------- P0 (BOARD_INFO) [0x4400 0x4000] Size: 16.0KB P1 (PG1FS) [0x8400 0x400000] Size: 4.0MB P2 (SBL1) [0x408400 0x100000] Size: 1.0MB P3 (PMIC) [0x508400 0x100000] Size: 1.0MB P4 (DUMMY) [0x608400 0x2800000] Size: 40.0MB P5 (RESERVE_1) [0x2e08400 0x1f7c00] Size: 1.967MB P6 (MFG) [0x3000000 0x40000] Size: 256.0KB P7 (PG2FS) [0x3040000 0x17afc00] Size: 23.686MB P8 (RPM) [0x47efc00 0x80000] Size: 512.0KB P9 (TZ) [0x486fc00 0x200000] Size: 2.0MB P10 (SDI) [0x4a6fc00 0x18000] Size: 96.0KB P11 (HYP) [0x4a87c00 0x200000] Size: 2.0MB P12 (ABOOT) [0x4c87c00 0x100000] Size: 1.0MB P13 (TOOL_DIAG) [0x4d87c00 0xa00000] Size: 10.0MB P14 (SP1) [0x5787c00 0xa00000] Size: 10.0MB P15 (DDR) [0x6187c00 0x100000] Size: 1.0MB P16 (RFG_0) [0x6287c00 0x100000] Size: 1.0MB P17 (RFG_1) [0x6387c00 0x100000] Size: 1.0MB P18 (RFG_2) [0x6487c00 0x100000] Size: 1.0MB P19 (RFG_3) [0x6587c00 0x100000] Size: 1.0MB P20 (RFG_4) [0x6687c00 0x100000] Size: 1.0MB P21 (RFG_5) [0x6787c00 0x100000] Size: 1.0MB P22 (RFG_6) [0x6887c00 0x100000] Size: 1.0MB P23 (RFG_7) [0x6987c00 0x100000] Size: 1.0MB P24 (FSG) [0x6a87c00 0x180000] Size: 1.500MB P25 (RADIO) [0x6c07c00 0x3b00400] Size: 59.0MB P26 (ADSP) [0xa708000 0x1400000] Size: 20.0MB P27 (LIMITS) [0xbb08000 0x400] Size: 1.0KB P28 (RESERVE_2) [0xbb08400 0x4f7c00] Size: 4.967MB P29 (PERSIST) [0xc000000 0x1600000] Size: 22.0MB P30 (RAMDUMP) [0xd600000 0xa00000] Size: 10.0MB P31 (MISC) [0xe000000 0x100000] Size: 1.0MB P32 (MODEM_ST1) [0xe100000 0x180000] Size: 1.500MB P33 (MODEM_ST2) [0xe280000 0x180000] Size: 1.500MB P34 (FATALDEVLOG) [0xe400000 0x1400000] Size: 20.0MB P35 (DEVLOG) [0xf800000 0x1e00000] Size: 30.0MB P36 (PDATA) [0x11600000 0x40000] Size: 256.0KB P37 (CONTROL) [0x11640000 0x4000] Size: 16.0KB P38 (EXTRA) [0x11644000 0x10000] Size: 64.0KB P39 (CDMA_RECORD) [0x11654000 0x100000] Size: 1.0MB P40 (FSC) [0x11754000 0x400] Size: 1.0KB P41 (SSD) [0x11754400 0x2000] Size: 8.0KB P42 (SENSOR_HUB) [0x11756400 0x80000] Size: 512.0KB P43 (SEC) [0x117d6400 0x20000] Size: 128.0KB P44 (ABOOTBAK) [0x117f6400 0x100000] Size: 1.0MB P45 (CIR_IMG) [0x118f6400 0x2800] Size: 10.0KB P46 (LOCAL) [0x118f8c00 0x140400] Size: 1.250MB P47 (FRP) [0x11a39000 0x80000] Size: 512.0KB P48 (CPE) [0x11ab9000 0x200000] Size: 2.0MB P49 (CARRIER) [0x11cb9000 0x1400000] Size: 20.0MB P50 (SKYLINK) [0x130b9000 0x40000] Size: 256.0KB P51 (RFG_8) [0x130f9000 0x20000] Size: 128.0KB P52 (RFG_9) [0x13119000 0x20000] Size: 128.0KB P53 (RFG_10) [0x13139000 0x20000] Size: 128.0KB P54 (RFG_11) [0x13159000 0x20000] Size: 128.0KB P55 (RFG_12) [0x13179000 0x20000] Size: 128.0KB P56 (RFG_13) [0x13199000 0x20000] Size: 128.0KB P57 (RFG_14) [0x131b9000 0x20000] Size: 128.0KB P58 (RFG_15) [0x131d9000 0x20000] Size: 128.0KB P59 (ABSOLUTE) [0x131f9000 0x1000000] Size: 16.0MB P60 (RESERVE) [0x141f9000 0xe07000] Size: 14.27MB P61 (HOSD) [0x15000000 0x4000000] Size: 64.0MB P62 (BOOT) [0x19000000 0x4000000] Size: 64.0MB P63 (RECOVERY) [0x1d000000 0x4000000] Size: 64.0MB P64 (CACHE) [0x21000000 0x14000000] Size: 320.0MB P65 (SYSTEM) [0x35000000 0x118000000] Size: 4.375GB P66 (USERDATA) [0x14d000000 0x5e0000000] Size: 23.500GB P67 (APPPRELOAD) [0x72d000000 0x12200000] Size: 290.0MB P68 (COTA) [0x73f200000 0x3c00000] Size: 60.0MB P69 (BATTERY) [0x742e00000 0xa00000] Size: 10.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0035000000 (4.375GB) Device Model: HTC One M9 Build ID: MRA58K Display Build ID: MRA58K release-keys Release ID: 6.0 Device Model: MSM8994 for arm64 Device Name: himauhl_htc_europe Architecture ABI: arm64-v8a Device manufacturer: HTC Device Platform: msm8994 Product ID: htc_himauhl Build Description: 3.35.401.12 CL671758 release-keys Build Description: 3.35.401.12 CL671758 release-keys Build Description: 3.35.401.12 CL671758 release-keys --------------------------------------------- Done. Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2464 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR Reading 0x000020000000 (512.0MB) from 0x000000000000 ...ROM1 ( USER ROM) Output file :C:\Program Files\Z3X\9. Easy Jtag files\HTC\ONE_M9_OPJA100\Dumps\EMMC_ROM1_HBG4e_278 0077279_00000000_20000000.bin Done, time taken: 922 sec. Average Read Speed: 582 kB/s Running:Sandisk: SmartReport... Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2464 mV Box IO Level:3300 mV CLK Rate:21000 kHz This eMMC is not Sandisk! Hold Shift during operation to skip this check Done. Running:eMMC: Factory Format... Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2464 mV Box IO Level:3300 mV CLK Rate:21000 kHz Formatting eMMC card, please wait up to 3 min... Setting Service Mode... eMMC Format Done. Done. extCSD file...C:\ProgramData\Z3XAppsData\Backups\HBG4e _2780077279_20180424_0940.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2464 mV Box IO Level:3300 mV CLK Rate:21000 kHz ------------Parsing extCSD------------ ============================================= Extended CSD rev 1.7 (MMC 5.0) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x01] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x17] FFU Argument [FFU_ARG: 0x00006600] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x5e [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x5e [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x5e [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x5e [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x0b] i.e. Exceeded its maximum estimated device life time _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x40] Optimal write size [OPTIMAL_WRITE_SIZE: 0x40] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x07] Device version [DEVICE_VERSION: 0x42 - 0x05] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0x07 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x05] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x10] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x03a40000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x0a] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x00] Not boot enabled No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x05 Enable background operations handshake [BKOPS_EN]: 0x01 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000748 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 ------------Done parsing------------ Writing as extCSD 5.0 Done. Checking NAND Image : C:\Program Files\Z3X\9. Easy Jtag files\HTC\ONE_M9_OPJA100\Dumps\HTC_M9_BGND3R_ROM1_ OK.bin Autodetected RAW data Warning! Disk size is smaller than the main header indicates! Loading Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Partition info successfully found Linux partitions is not found in image... File successefuly loaded! Real (Hardware) Disk/Image size: 26C000 sectors 1.2 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Processing file...C:\Program Files\Z3X\9. Easy Jtag files\HTC\ONE_M9_OPJA100\Dumps\HTC_M9_BGND3R_ROM1_ OK.bin Writing as RAW data Z3X EasyJtag Software ver. 2.9.0.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2031 mV CMD Active Level:2464 mV Input file : C:\Program Files\Z3X\9. Easy Jtag files\HTC\ONE_M9_OPJA100\Dumps\HTC_M9_BGND3R_ROM1_ OK.bin Writing 004D800000 bytes to 0000000000... ROM1 (USER ROM) Done, time taken: 1802 sec. Average Write Speed: 721 kB/s Compression is ON Z3X EasyJtag Software ver. 2.9.0.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0F00E00C0D23EDA9, ,FW Ver.: 01.62 CMD Pullup Level:2031 mV CMD Active Level:2536 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48424734650507A5B49CDF22B4 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 2780077279 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _2780077279_20180424_1044.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A40000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Found Data areas (firmware parts) count is: 70 Partition info successfully found --------------------------------------------- P0 (BOARD_INFO) [0x4400 0x4000] Size: 16.0KB P1 (PG1FS) [0x8400 0x400000] Size: 4.0MB P2 (SBL1) [0x408400 0x100000] Size: 1.0MB P3 (PMIC) [0x508400 0x100000] Size: 1.0MB P4 (DUMMY) [0x608400 0x2800000] Size: 40.0MB P5 (RESERVE_1) [0x2e08400 0x1f7c00] Size: 1.967MB P6 (MFG) [0x3000000 0x40000] Size: 256.0KB P7 (PG2FS) [0x3040000 0x17afc00] Size: 23.686MB P8 (RPM) [0x47efc00 0x80000] Size: 512.0KB P9 (TZ) [0x486fc00 0x200000] Size: 2.0MB P10 (SDI) [0x4a6fc00 0x18000] Size: 96.0KB P11 (HYP) [0x4a87c00 0x200000] Size: 2.0MB P12 (ABOOT) [0x4c87c00 0x100000] Size: 1.0MB P13 (TOOL_DIAG) [0x4d87c00 0xa00000] Size: 10.0MB P14 (SP1) [0x5787c00 0xa00000] Size: 10.0MB P15 (DDR) [0x6187c00 0x100000] Size: 1.0MB P16 (RFG_0) [0x6287c00 0x100000] Size: 1.0MB P17 (RFG_1) [0x6387c00 0x100000] Size: 1.0MB P18 (RFG_2) [0x6487c00 0x100000] Size: 1.0MB P19 (RFG_3) [0x6587c00 0x100000] Size: 1.0MB P20 (RFG_4) [0x6687c00 0x100000] Size: 1.0MB P21 (RFG_5) [0x6787c00 0x100000] Size: 1.0MB P22 (RFG_6) [0x6887c00 0x100000] Size: 1.0MB P23 (RFG_7) [0x6987c00 0x100000] Size: 1.0MB P24 (FSG) [0x6a87c00 0x180000] Size: 1.500MB P25 (RADIO) [0x6c07c00 0x3b00400] Size: 59.0MB P26 (ADSP) [0xa708000 0x1400000] Size: 20.0MB P27 (LIMITS) [0xbb08000 0x400] Size: 1.0KB P28 (RESERVE_2) [0xbb08400 0x4f7c00] Size: 4.967MB P29 (PERSIST) [0xc000000 0x1600000] Size: 22.0MB P30 (RAMDUMP) [0xd600000 0xa00000] Size: 10.0MB P31 (MISC) [0xe000000 0x100000] Size: 1.0MB P32 (MODEM_ST1) [0xe100000 0x180000] Size: 1.500MB P33 (MODEM_ST2) [0xe280000 0x180000] Size: 1.500MB P34 (FATALDEVLOG) [0xe400000 0x1400000] Size: 20.0MB P35 (DEVLOG) [0xf800000 0x1e00000] Size: 30.0MB P36 (PDATA) [0x11600000 0x40000] Size: 256.0KB P37 (CONTROL) [0x11640000 0x4000] Size: 16.0KB P38 (EXTRA) [0x11644000 0x10000] Size: 64.0KB P39 (CDMA_RECORD) [0x11654000 0x100000] Size: 1.0MB P40 (FSC) [0x11754000 0x400] Size: 1.0KB P41 (SSD) [0x11754400 0x2000] Size: 8.0KB P42 (SENSOR_HUB) [0x11756400 0x80000] Size: 512.0KB P43 (SEC) [0x117d6400 0x20000] Size: 128.0KB P44 (ABOOTBAK) [0x117f6400 0x100000] Size: 1.0MB P45 (CIR_IMG) [0x118f6400 0x2800] Size: 10.0KB P46 (LOCAL) [0x118f8c00 0x140400] Size: 1.250MB P47 (FRP) [0x11a39000 0x80000] Size: 512.0KB P48 (CPE) [0x11ab9000 0x200000] Size: 2.0MB P49 (CARRIER) [0x11cb9000 0x1400000] Size: 20.0MB P50 (SKYLINK) [0x130b9000 0x40000] Size: 256.0KB P51 (RFG_8) [0x130f9000 0x20000] Size: 128.0KB P52 (RFG_9) [0x13119000 0x20000] Size: 128.0KB P53 (RFG_10) [0x13139000 0x20000] Size: 128.0KB P54 (RFG_11) [0x13159000 0x20000] Size: 128.0KB P55 (RFG_12) [0x13179000 0x20000] Size: 128.0KB P56 (RFG_13) [0x13199000 0x20000] Size: 128.0KB P57 (RFG_14) [0x131b9000 0x20000] Size: 128.0KB P58 (RFG_15) [0x131d9000 0x20000] Size: 128.0KB P59 (ABSOLUTE) [0x131f9000 0x1000000] Size: 16.0MB P60 (RESERVE) [0x141f9000 0xe07000] Size: 14.27MB P61 (HOSD) [0x15000000 0x4000000] Size: 64.0MB P62 (BOOT) [0x19000000 0x4000000] Size: 64.0MB P63 (RECOVERY) [0x1d000000 0x4000000] Size: 64.0MB P64 (CACHE) [0x21000000 0x14000000] Size: 320.0MB P65 (SYSTEM) [0x35000000 0x118000000] Size: 4.375GB P66 (USERDATA) [0x14d000000 0x5e0000000] Size: 23.500GB P67 (APPPRELOAD) [0x72d000000 0x12200000] Size: 290.0MB P68 (COTA) [0x73f200000 0x3c00000] Size: 60.0MB P69 (BATTERY) [0x742e00000 0xa00000] Size: 10.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0035000000 (4.375GB) --------------------------------------------- Done. Compression is ON Z3X EasyJtag Software ver. 2.9.0.2 Loading eMMC GEN1 Firmware... IO: 3300 mV Box S/N: 0F00E00C0D23EDA9, ,FW Ver.: 01.62 CMD Pullup Level:2041 mV CMD Active Level:2526 mV Box IO Level:3300 mV CLK Rate:21000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- EMMC CID : 90014A48424734650507A5B49CDF22B4 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 02/2015 Rev.0x7 EMMC NAME: HBG4e , S/N: 2780077279 EMMC NAME (HEX): 48424734652000 EMMC ROM1 (Main User Data) Capacity: 29824 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.7 (MMC 5.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4e _2780077279_20180424_1046.extcsd Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A40000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: 3A1BFDD sectors 29.1 GiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 60932095 Found Data areas (firmware parts) count is: 70 Partition info successfully found --------------------------------------------- P0 (BOARD_INFO) [0x4400 0x4000] Size: 16.0KB P1 (PG1FS) [0x8400 0x400000] Size: 4.0MB P2 (SBL1) [0x408400 0x100000] Size: 1.0MB P3 (PMIC) [0x508400 0x100000] Size: 1.0MB P4 (DUMMY) [0x608400 0x2800000] Size: 40.0MB P5 (RESERVE_1) [0x2e08400 0x1f7c00] Size: 1.967MB P6 (MFG) [0x3000000 0x40000] Size: 256.0KB P7 (PG2FS) [0x3040000 0x17afc00] Size: 23.686MB P8 (RPM) [0x47efc00 0x80000] Size: 512.0KB P9 (TZ) [0x486fc00 0x200000] Size: 2.0MB P10 (SDI) [0x4a6fc00 0x18000] Size: 96.0KB P11 (HYP) [0x4a87c00 0x200000] Size: 2.0MB P12 (ABOOT) [0x4c87c00 0x100000] Size: 1.0MB P13 (TOOL_DIAG) [0x4d87c00 0xa00000] Size: 10.0MB P14 (SP1) [0x5787c00 0xa00000] Size: 10.0MB P15 (DDR) [0x6187c00 0x100000] Size: 1.0MB P16 (RFG_0) [0x6287c00 0x100000] Size: 1.0MB P17 (RFG_1) [0x6387c00 0x100000] Size: 1.0MB P18 (RFG_2) [0x6487c00 0x100000] Size: 1.0MB P19 (RFG_3) [0x6587c00 0x100000] Size: 1.0MB P20 (RFG_4) [0x6687c00 0x100000] Size: 1.0MB P21 (RFG_5) [0x6787c00 0x100000] Size: 1.0MB P22 (RFG_6) [0x6887c00 0x100000] Size: 1.0MB P23 (RFG_7) [0x6987c00 0x100000] Size: 1.0MB P24 (FSG) [0x6a87c00 0x180000] Size: 1.500MB P25 (RADIO) [0x6c07c00 0x3b00400] Size: 59.0MB P26 (ADSP) [0xa708000 0x1400000] Size: 20.0MB P27 (LIMITS) [0xbb08000 0x400] Size: 1.0KB P28 (RESERVE_2) [0xbb08400 0x4f7c00] Size: 4.967MB P29 (PERSIST) [0xc000000 0x1600000] Size: 22.0MB P30 (RAMDUMP) [0xd600000 0xa00000] Size: 10.0MB P31 (MISC) [0xe000000 0x100000] Size: 1.0MB P32 (MODEM_ST1) [0xe100000 0x180000] Size: 1.500MB P33 (MODEM_ST2) [0xe280000 0x180000] Size: 1.500MB P34 (FATALDEVLOG) [0xe400000 0x1400000] Size: 20.0MB P35 (DEVLOG) [0xf800000 0x1e00000] Size: 30.0MB P36 (PDATA) [0x11600000 0x40000] Size: 256.0KB P37 (CONTROL) [0x11640000 0x4000] Size: 16.0KB P38 (EXTRA) [0x11644000 0x10000] Size: 64.0KB P39 (CDMA_RECORD) [0x11654000 0x100000] Size: 1.0MB P40 (FSC) [0x11754000 0x400] Size: 1.0KB P41 (SSD) [0x11754400 0x2000] Size: 8.0KB P42 (SENSOR_HUB) [0x11756400 0x80000] Size: 512.0KB P43 (SEC) [0x117d6400 0x20000] Size: 128.0KB P44 (ABOOTBAK) [0x117f6400 0x100000] Size: 1.0MB P45 (CIR_IMG) [0x118f6400 0x2800] Size: 10.0KB P46 (LOCAL) [0x118f8c00 0x140400] Size: 1.250MB P47 (FRP) [0x11a39000 0x80000] Size: 512.0KB P48 (CPE) [0x11ab9000 0x200000] Size: 2.0MB P49 (CARRIER) [0x11cb9000 0x1400000] Size: 20.0MB P50 (SKYLINK) [0x130b9000 0x40000] Size: 256.0KB P51 (RFG_8) [0x130f9000 0x20000] Size: 128.0KB P52 (RFG_9) [0x13119000 0x20000] Size: 128.0KB P53 (RFG_10) [0x13139000 0x20000] Size: 128.0KB P54 (RFG_11) [0x13159000 0x20000] Size: 128.0KB P55 (RFG_12) [0x13179000 0x20000] Size: 128.0KB P56 (RFG_13) [0x13199000 0x20000] Size: 128.0KB P57 (RFG_14) [0x131b9000 0x20000] Size: 128.0KB P58 (RFG_15) [0x131d9000 0x20000] Size: 128.0KB P59 (ABSOLUTE) [0x131f9000 0x1000000] Size: 16.0MB P60 (RESERVE) [0x141f9000 0xe07000] Size: 14.27MB P61 (HOSD) [0x15000000 0x4000000] Size: 64.0MB P62 (BOOT) [0x19000000 0x4000000] Size: 64.0MB P63 (RECOVERY) [0x1d000000 0x4000000] Size: 64.0MB P64 (CACHE) [0x21000000 0x14000000] Size: 320.0MB P65 (SYSTEM) [0x35000000 0x118000000] Size: 4.375GB P66 (USERDATA) [0x14d000000 0x5e0000000] Size: 23.500GB P67 (APPPRELOAD) [0x72d000000 0x12200000] Size: 290.0MB P68 (COTA) [0x73f200000 0x3c00000] Size: 60.0MB P69 (BATTERY) [0x742e00000 0xa00000] Size: 10.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0035000000 (4.375GB) Device Model: HTC One M9 Build ID: LMY47O Display Build ID: LMY47O release-keys Release ID: 5.1 Device Model: MSM8994 for arm64 Device Model: MSM8994 for arm64 Device Name: himauhl_htc_europe Architecture ABI: arm64-v8a Device manufacturer: HTC Device Platform: msm8994 Product ID: htc_himauhl Build Description: 2.10.401.1 CL576582 release-keys Build Description: 2.10.401.1 CL576582 release-keys Build Description: 2.10.401.1 CL576582 release-keys --------------------------------------------- Done. |
