Old 03-08-2022, 13:17   #1 (permalink)
Member: 2170126
Sonork: Whtas & Fb
Thanks Meter: 53
Unhappy easy jtag bga 254 socket error help
Efm Ufs error
UFS: Voltage Info:
Mode: LOW
VCC : 3281 mV, VCCQ2: 1920 mV
3v3 : 3376 mV, 1v2: 1203 mV
UFS: Memory Info:
Connection: Socket BGA-254
Vendor: SAMSUNG
S/N: 450a7bb10b1d
OEM ID: SAMSUNG_OEM_ID
Firm Version: 1.5.0.0
UFS Version: 2.1
Max LUNs: 8
LUNs Cnt: 6
W-LUNs Cnt: 1
LUNs ReConfig: Enabled
UFS RPMB Info:
RPMB Counter: 68984
UFS Health Info:
UFS Life Time A: 0x01 -> 0% - 10% Life Time Used
UFS Life Time B: 0x01 -> 0% - 10% Life Time Used
UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks
UFS: LUNs Info:
LUN 0 -> Size: 30881792 Block(s)/117.80 GB
LUN 1 (Boot A) -> Size: 2048 Block(s)/8.00 MB
LUN 2 (Boot B) -> Size: 2048 Block(s)/8.00 MB
LUN 3 -> Size: 8192 Block(s)/32.00 MB
LUN 4 -> Size: 278528 Block(s)/1.06 GB
LUN 5 -> Size: 65536 Block(s)/256.00 MB
W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16.00 MB
UFS Init OK
Scanning Data From UFS Chip. Please wait..
Scanning GUID Partition Table from LUN 0
Error Reading Sector: 0, Count: 6, Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ
Try Again #1
Try Again #2
Try Again #3
Too Many Errors. Stopped. Err: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ
Error While Reading. Exit. Code: -403/ERROR_UFS_CHIP_HWPART_JEDEC_PSREQ
Error While Scan Partitions. Scanner Shutdown..
Scanner Thread Terminated
Elapsed: 00:00:05:217
Found 0 Partition(s)..
Search Partitions Fail..
Check Socket/UFS Chip and Try Again..
easy jtag error
Chip Info:
Manufacturer: SAMSUNG
ProductName: KM8V8001JM-B813
SerialNumber: 450a7bb10b1d
OemID: SAMSUNG_OEM_ID
Firmware Version: 1.5.0.0
UFS Version: 2.1
Maximum Number of LUs: 8
Number of LUs found: 6
LUN 0:
Block size: 0x1000
Size: 0x1D73800000 / 117,824,000,000B / 117GB
LUN 1 (Boot A):
Block size: 0x1000
Size: 0x800000 / 0,008,000,000B / 8MB
LUN 2 (Boot B):
Block size: 0x1000
LUN 3:
Block size: 0x1000
Size: 0x2000000 / 0,032,000,000B / 32MB
LUN 4:
Block size: 0x1000
Size: 0x44000000 / 1,064,000,000B / 1GB
LUN 5:
Block size: 0x1000
Size: 0x10000000 / 0,256,000,000B / 256MB
Number of W-LUs found: 1
W-LUN 0xC4 (RPMB):
Block size: 0x100
Size: 0x1000000 / 0,016,000,000B / 16MB
Full size: 0x1DCC800000 / 119,200,000,000B / 119GB
RPMB:
Counter: 68984
Health:
Device life time method A: 0x01 (0%-10% device life time used)
Device life time method B: 0x01 (0%-10% device life time used)
Pre End of Life: 0x01 (Used less then 80% of reserved blocks)
Can't stop LU, Code: -406, Reason: UAP SCSI: Command sense: UNIT_ATTENTION
Done.
Easyjtag plus 2
Socket Type: UFS_SOCKET_BGA_254
UFS Power Information :
Mode: Low, VCC: 3260 mV, VCCQ2: 1918 mV
UFS Device Information :
UFS Manufacturer: SAMSUNG, UFS ProductName: KM8V8001JM-B813
UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 450a7bb10b1d
Maximum Number of LUs: 8, Number of LUs found: 6, Number of WLUs found: 1, LUs Re-configure: Enabled
RPMB Counter: 68984
UFS LUN 0 Capacity: 120632 MB (001D73800000)
UFS LUN 1 (Boot A) Capacity: 8 MB (000000800000)
UFS LUN 2 (Boot B) Capacity: 8 MB (000000800000)
UFS LUN 3 Capacity: 32 MB (000002000000)
UFS LUN 4 Capacity: 1088 MB (000044000000)
UFS LUN 5 Capacity: 256 MB (000010000000)
UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000)
Device Life Time Estimation B: 0x01 0% - 10% device life time used
Device Life Time Estimation A: 0x01 0% - 10% device life time used
Pre EOL information: 0x01 Normal (Consumed less then 80% of reserved block)
Do not turn the socket before you press "Close Session" button
Connected successfully
Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write)
Scanning soft partitions from LUN 0
Error reading at address: 000000000000 , error: -403, UAP SCSI: Command sense: MEDIUM_ERROR ... Retry #1
Error reading at address: 000000000000 , error: -403, UAP SCSI: Command sense: MEDIUM_ERROR ... Retry #2
Error reading at address: 000000000000 , error: -403, UAP SCSI: Command sense: MEDIUM_ERROR ... Retry #3
Canceled
Need Solution
Old 03-09-2022, 02:59   #2 (permalink)
Member: 649636
Thanks Meter: 2
Same problem of this chip
Old 03-10-2022, 13:57   #3 (permalink)
Member: 1505730
Sonork: 100.1618029
Thanks Meter: 207
same problem i have also
need solution
Page generated in 0.14102 seconds with 8 queries
