11-13-2020, 14:41 | #1 (permalink) |
Junior Member Join Date: Aug 2016 Location: Eygpt Age: 44
Member: 2611378 Status: Offline Thanks Meter: 1 | Problem With Classic v3.7.0.20, Unstable while reading the eMMC with 36MHZ |
11-13-2020, 21:07 | #3 (permalink) |
No Life Poster Join Date: Nov 2012 Location: Ek India Happy Wala.. :-)
Member: 1834832 Status: Offline Thanks Meter: 1,450 | Higher Clock Rate Will Not Work Well With ISP Connection Spsly On 1Bit Connection In Older Devices It May Work But In New Devices It Give Error 18Mhz Is Recommended Speed For ISP U Can Try Higher Clock If Give Error Kindly Reduce Speed If U Want To Work With Higher Clock Better Do Chip OFF N Do Operation Spsly For BGA-254 Hope U Got Ur Answer Now |
11-13-2020, 21:22 | #4 (permalink) | |
Member: 2611378 Status: Offline Thanks Meter: 1 | Quote:
brother i wrote "when i downgrade firmware the box is stable in 36mhz" , did you read it ? | |
11-17-2020, 20:47 | #5 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | Quote:
Just send Report and leave it do not ask here itself to reply for u. wait team will take the notes and will fix in next update. Programming is not like cook a hot water to make immediate Tell your issues and Request solve this as soon as possible. This is the way of approaching a make changes in Software. Hope u will understand. Thank you. | |
The Following User Says Thank You to sree krishna For This Useful Post: |
11-18-2020, 12:13 | #6 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | You use incorrect VIO setting and want to normal work? VIO at most devices is 1,8v |
The Following 2 Users Say Thank You to layder For This Useful Post: |
11-19-2020, 01:04 | #7 (permalink) | |
11-19-2020, 10:26 | #9 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
many devices which did not connect by use before, now work. we most to sacrifice one for the other. use 24 MHz or try to put a resistor of 20-30 ohm in series in the CLK line you can also try to "Disable High Speed timing" at settings Last edited by layder; 11-19-2020 at 11:12. | |
