05-28-2022, 14:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2006 Location: MOSTAGANEM Age: 41
Member: 232928 Status: Offline Thanks Meter: 124 | Samsung t515 help Code: EasyJtag Suite Classic ver.: 3.7.0.24 / wxWidgets 3.1.3-W-U started. OS ver.: Windows 10 (build 19044), 64-bit edition. Admin rights FAIL Autorun Agent ver:1.0.0.0 Crash Reporting ver:1.4.0.3 EasyJTAG SPI Plugin ver:1.1.1.13 Android ADB API ver:2.0.0.0 FTDI API ver:3.2.4.0 LibUSB API ver:1.2.6.0 Visual C++ Runtime ver:10.0.30319.1 Setting box Pinout ... Box Drivers version: 10.0.19041.1202 Z3X Card Serial : AAFD-xxxx , ver: 22 Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED For more information press F1 to open local help or visit our wiki Found 2 serial devices COM1 ACPI\VEN_PNP&DEV_0501 Port de communication (COM1) COM7 USB\VID_1781&PID_AAAC&REV_0100&MI_00 Périphérique série USB (COM7) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2600 mV Box S/N: 67899xxxxxxxxxxx, ,FW Ver.: 02.53 CMD Pullup Level:460 mV CMD Active Level:1533 mV Box IO Level:2600 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 150100424A5444345200856A8FB387D1 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 08/2020 Rev.0x0 eMMC NAME: BJTD4R , S/N: 2238353331 eMMC NAME (HEX): 424A54443452 Possible eMMC NAME Mismatch Possible IC Name[0]: Samsung , KLMBG2JETD-B041/32GB @FBGA169 Rev2 , Firmware is Updatable Possible IC Name[1]: Samsung , KLMBG2JETD-B041/32GB @FBGA169 Rev9 , Firmware is Updatable Can't init EMMC, Reason: DATA RCV Timeout Error Check Data Line! Done. Can't init device, Reason: Initialization failed Done. |
