10-15-2020, 06:12 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: JSR, BD
Member: 310155 Status: Offline Thanks Meter: 1,313 | UFS not detect via ISP UFS Socket Info. Serial: 01237A24Exxxxxxxx Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 01.07.20 Identify UFS Chip. UFS Chip Voltage: Low Check ISP connect. Can't init device, Code: -113, Reason: UTP: Failed to NOP request VCC: 3306mV VCCQ2: 1904mV Done. ISP connect all are 100% okay but cant detect. i use............. RXOP RXON TXOP TXON RST GND |
10-15-2020, 10:13 | #2 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | if you not use power VCC wires - you need power on board with USB charger |
The Following 2 Users Say Thank You to layder For This Useful Post: |
10-16-2020, 02:02 | #5 (permalink) | |
Freak Poster Join Date: Dec 2006 Location: caribe look, Drunken master II
Member: 410843 Status: Offline Thanks Meter: 28 | Quote:
12-05-2020, 00:30 | #11 (permalink) |
Junior Member Join Date: Feb 2017
Member: 2689595 Status: Offline Thanks Meter: 2 | how if error say this ? UFS: Socket Info: S/N: 0x0123B03F4E8AFC17EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 11.08.20 Type: EasyJtag UFS Socket BGA-254 ID: 2351 Initialize UFS Engine Fail. Code: -56/ERROR_UFS_BOX_INIT_LINK_T0 Scanner Thread Terminated Elapsed: 00:00:00:801 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
12-05-2020, 12:52 | #12 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
01-06-2021, 14:33 | #13 (permalink) |
Freak Poster Join Date: May 2009 Location: bangladesh
Member: 1022144 Status: Offline Sonork: Love in Bangladesh Thanks Meter: 139 | Code: -56, Reason: BOX: Chip not connected Error -56 Meaning Socket damage , when this error show then socket green light no signal . |
01-06-2021, 15:06 | #15 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | some devices sent RST signal to UFS at ISP this need connect RST pin on PCB to VCCQ to enable work with UFS at HiPower mode |
