02-07-2018, 00:17 | #1 (permalink) |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | I9082 Still has Flashing Problem After boot repair. I have a I9082. Came in with flashing error. i have tried to flash with different files. and i get this. File analysis... OK Total file size: 0x600A960B (1536 Mb) Searching USB Flash interface... COM64 detected Setup connection... OK Reading PIT from phone... OK Sending vc-firmware.img... OK Sending boot.img... OK Sending recovery.img... OK Sending BcmCP.img... error timeout Done with Samsung Tool PRO v.30.7 I have managed to do the jtag boot repair with easy jtag box. Using EasyRepair Mode... Checking repair data... EasyJtag Suite Classic ver.: 2.9.0.1 / wxWidgets 3.1.0-W-U started. OS ver.: Windows 7 (build 7600). Admin rights OK For support and updates visit http://easy-jtag.com Check security... OK Initialising: SAMSUNG GT-I9082 Config ver.:1.00 Connecting to Target... JTAG device: BCM28155 CPU IDCODE : 0x4BA00477 Mfg.: 0x23b, Part: 0xba00, Ver.: 0x4 CPU Manufacturer: QUALCOMM , CPU Name: CORTEX A9 Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x01000015 Name : AW1G8M Size : 7.3 G , (15269888) Blocks EMMC #1 : ID : 0x01000015 Name : AW1G8M Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x00150000 NAND Writing BOOT, PIT, MD5... eMMC Write OK! Elapsed time: 24.726414s (41.413 KiB/s) NAND Writing CAL... eMMC Write OK! Elapsed time: 23.610352s (43.371 KiB/s) NAND Writing SYSPARAM... eMMC Write OK! Elapsed time: 11.069633s (23.126 KiB/s) NAND Writing PARM_SPML... eMMC Write OK! Elapsed time: 6.018344s (42.537 KiB/s) NAND Writing RF_CAL... eMMC Write OK! Elapsed time: 6.087349s (42.054 KiB/s) NAND Writing SBL1... eMMC Write OK! Elapsed time: 51.785961s (39.547 KiB/s) NAND Writing PARAM... eMMC Write OK! Elapsed time: 19.136093s (33.445 KiB/s) NAND Writing DTS... eMMC Write OK! Elapsed time: 11.791675s (43.420 KiB/s) All Done. However Flashing errors are still there. Sending BcmCP.img... error timeout Any expert help would be much appreciated. |
02-07-2018, 02:48 | #2 (permalink) |
Freak Poster Join Date: Sep 2009 Location: Indonesia
Member: 1112585 Status: Offline Sonork: 100.1645028 Thanks Meter: 91 | Try eMMC connection. if SAMSUNG IC "maybe" it write protect, & remove WriteProtect. or if SANDISK & other, "maybe" you have to replace the eMMC. |
02-07-2018, 21:09 | #4 (permalink) |
Member: 143848 Status: Offline Thanks Meter: 125 | With ISP adaptor i m getting this error without pullup resistors. Box Drivers version: 3.0.0.0 Z3X Card Serial : AA64-0A9D , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED Z3X Card Activation [SAMS] : NOT ACTIVATED Z3X Card Activation [JTAGPLUS] : ACTIVATED Z3X Card Activation [JTAG] : ACTIVATED Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Compression if OFF Z3X EasyJtag Software ver. 2.9.0.1 Loading eMMC GEN2 Firmware... IO: 2800 mV Box S/N: XXXXX, ,FW Ver.: 02.21 CMD Pullup Level:1145 mV CMD Active Level:2589 mV Box IO Level:2800 mV CLK Rate:24000 kHz Bus Width:1bit,SDR HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. |
