Old 04-11-2020, 02:09   #1 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
Oppo A3s password unlock
After emmc wipe data via my old Jtag box, the unit went rebooting, I tried again seems successful but I noticed some error, now the unit is just vibrating looks dead. Any thoughts?
Here is the log.
EasyJtag Suite Classic ver.: 3.6.1.15 / wxWidgets 3.1.2-W-U started.
OS ver.: Windows 10 (build 17763), 64-bit edition. Admin rights FAIL
Android Explorer ver:1.0.0.13
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.0.6
QUALCOMM Direct ver:1.0.6936.8894
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 10.0.17763.1, are OK
Z3X Card Serial : AA8Exx , ver: 22
Z3X Card Activation [JTAGPLUS] : NOT ACTIVATED
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Found 2 serial devices
COM41 USB\VID_0325&PID_0032&REV_0100&MI_00 USB Serial Device (COM41)
COM1 ACPI\VEN_PNP&DEV_0501 Communications Port (COM1)
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.15
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 02FFA019B6E09005, ,FW Ver.: 01.63
CMD Pullup Level:2433 mV
CMD Active Level:2650 mV
Box IO Level:2800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
eMMC CID : 90014A68423861503E03C79146A8A5C2
eMMC CSD : D02700328F5903FFFFFFFFEF8E400042
eMMC Manufacturer ID: 0090 , OEM ID: 014A
eMMC Date: 10/2018 Rev.0x3
eMMC NAME: hB8aP> , S/N: 3348186792
eMMC NAME (HEX): 68423861503E
EMMC ROM1 (Main User Data) Capacity: 29820 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 kB
RPMB Info mmc_switch_part Error, Reason: CARD Ready Timeout Error
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: hB8aP>_3348186792_20200411_0849.extcsd
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB
Soft (Partitioned) Disk/Image size: 3A3DFBC sectors 29.1 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,61071326
Partition info successfully found
------ Android information ------
Detected LINUX(Android) SYSTEM : 0x003F000000 (3.352GB)
Build ID: OPM1.171019.026
Release Base ID: 8.1.0
Architecture ABI: arm64-v8a
Device manufacturer: OPPO
Build Description: msm8953_64-user 8.1.0 OPM1.171019.026 eng.root.20181103.202305 release-keys
Detected USERDATA USERDATA : 0x0158000000 (23.745GB)
Unable to mount USERDATA , code : 95
Done.
Running:Format FRP Partition...
CMD Active Level:2660 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (23.745GB) , formatting...
Done.
Done.
Done.
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Detected (Android Userdata) USERDATA : 0x0158000000 (23.745GB)
Read EXT fs info
Formatting EXT fs... (may take a while...)
mmc_write_blocks(0x158004000 , 1000 ), Failed: CARD Ready Timeout Error
mmc_write_blocks(0x170005000 , 1000 ), Failed: CMD Timeout Error
Returned 5...
Read EXT fs info
NEW Created filesystem with parameters:
Block size: 21474840576
Blocks per group: 32768
Inodes per group: 8192
Inode size: 256
Ends: 1556480
Label:
Trying to mount FS...
Shutting down EXT4...
Done.
Detected (Android Cache)) CACHE : 0x001FB00000 (256.0MB)
Read EXT fs info
mmc_write_blocks(0x27B00000 , 400 ), Failed: CARD Ready Timeout Error
mmc_write_blocks(0x27B01000 , 1000 ), Failed: CMD Timeout Error
Returned 5...
Read EXT fs info
Block size: 4096
Inode size: 256
Inodes: 16384
Label:
Done.
Done.
CMD Pullup Level:2423 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Erasing...
Done.
Erasing...
Done.
Done.
Old 04-13-2020, 21:28   #2 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 47
Did you solve your problem?
Old 04-14-2020, 10:31   #3 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 718
NO. do you have any solutions?
Old 04-15-2020, 06:44   #4 (permalink)
Member: 2746336
Sonork: NULL
Thanks Meter: 47
I am also asking solution for the same problem but easy jtag team have no response, u try this. First backup security areas, then Write dump file or XML file from below link:
Dump
https://drive.google.com/uc?id=1__EC...xport=download
XML
https://drive.google.com/uc?id=1gROx...xport=download
Then write oppo full factory firmware write by vendor with easy jtag.
After that please tell me if this worked, I also have a3s in same condition, but shop is closed that's y I am not able to try this.
The Following User Says Thank You to Bhagat20 For This Useful Post:
Old 04-17-2020, 16:43   #5 (permalink)
Member: 2332340
Thanks Meter: 8
First check CLK RESISTOR i recommend to short it then test phone if working
Page generated in 0.17593 seconds with 8 queries
