Old 01-11-2019, 09:08   #1 (permalink)
Member: 1212133
Thanks Meter: 58
Can anyone provide a working EXT CSD for N8000?
I bought eMMC for Samsung N8000 already programmed
EXT CSD looks like this
Access mode: sector mode
Power supply: dual-voltage (1.70-1.95V, 2.7-3.6V)
Card/BGA: BGA (Discrete embedded) - High density MMC
Manufacturer ID: 0x15 (Samsung)
Product name: MAG2GA (0x4d4147324741), rev: 0x15, serial number: 0xB9807EDB
Manufacturing date: May 2013
CID: 1501004D 41473247 4115B980 7EDB50C4
CSD: D0270132 0F5903FF F6DBFFFF 8A404006
EXT_CSD revision: 1.5 (MMC v4.41)
Partition info:
Boot1: 2048 KiB
Boot2: 2048 KiB
RPMB: 128 KiB
User area: 14.56 GiB(15,634,268,160 bytes)
Partition configuration: 0x48
Boot acknowledge is sent during the boot operation
Boot partition 1 is enabled for boot
Partitioning support: 0x03
Device support partitioning feature
Device can have enhanced technological features
Device partitioning possible
Boot configuration protection: 0x00
Boot bus conditions: 0x01
Bus width: x4 (sdr/ddr), boot mode: sdr(default), reset bus width to x1 sdr(default)
Boot area write protection: 0x00
Power-on write protection: possible
Permanent write protection: possible
Lock status: not locked
Is that correct? I found others that are different
see
EXT CSD info:
Partition info:
Boot1: 2048 KiB
Boot2: 2048 KiB
RPMB: 128 KiB
User area: 14.68 GiB(15,758,000,128 bytes)
Partition configuration: 0x00
No boot acknowledge is sent (default)
Device is not boot-enabled (default)
Boot bus conditions: 0x00
and
EXT CSD info:
Partition info:
Boot1: 512 KiB
Boot2: 512 KiB
RPMB: 128 KiB
Which one should I use?
Thanks for help
Old 01-11-2019, 09:53   #2 (permalink)
andrei_d1978's Avatar
Member: 1363017
Thanks Meter: 44
EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 2048 KB (000000200000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 KB (000000020000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
The Following User Says Thank You to andrei_d1978 For This Useful Post:
Old 01-11-2019, 15:09   #3 (permalink)
Member: 1212133
Thanks Meter: 58
Thanks.It seems to be the same as mine
Page generated in 0.14426 seconds with 8 queries
