SM-J100H Dead Boot Repair Fail please HELP J100H was stuck on logo after flash the phone is complete dead . i want to repair Dead boot by Easy Jtag . i did tried by Pit and also by image But the phone still Dead there is some error please Help. Here is info HiPower mode is OFF CMD Pullup Level: 2640 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 90014A48344732621101E6D8BEC04222 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: E6D8BEC0 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_E6D8BEC0_20170619_110424.extcsd EMMC Init completed. Get firmware version Firmware info not found Try to read table form EMMC HiPower mode is OFF CMD Pullup Level: 2640 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 90014A48344732621101E6D8BEC04222 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: E6D8BEC0 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_E6D8BEC0_20170619_110424.extcsd EMMC Init completed. Get firmware version Firmware info not found HiPower mode is OFF CMD Pullup Level: 2640 mV CMD Active Level: 3238 mV EMMC Device Information : EMMC CID: 90014A48344732621101E6D8BEC04222 EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture Name: SKHYNIX EMMC NAME: H4G2b , S/N: E6D8BEC0 , rev. 01 EMMC NAME (HEX): 483447326211 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Backup saved: H4G2b_E6D8BEC0_20170619_111327.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Samsung Searching GPT ... GPT header is not found Partition table not found |
remove all wires and attach again but skhynix emmc is not easy to repaire beter is to replace EMMC |
witch samsung emmc replace with hynix can i use |
u can use any samsung or sandisc EMMC with same size |
So that skynix ic is not repairable by Z3x EASY Jtag |
Hi This mean SW can't find correct partitions,may you need select SPD first then try read Partitions if your phone is spd Anyway,Just try write latest BL+pit if not Power on,Try replace eMMC |
Hv repaired same ,like J200H Via easy jtag.... select SPD first then try read Partitions if your phone is spd Then Erase just write pit then write by vander (use Of Lateset Firmware IS necessery)... i used same steps at J200H WAS Facing problem like you :) |
what means " select spd" ? |
