06-01-2021, 20:26 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SM-J730F Samsung J7 Pro MDM Lock Removed By Easy Jtag Plus V-Log eMMC_tool Suite ver. 1.6.4.0 (release date: 30.12.2020) Microsoft Windows 7 (32 bit) build 7601 (6.1.7600.16385) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = F6F272D292237F2E Card Serial = AA2778BA EasyJTAG Box Firmware = 2.5301 Changelog: 30.12.2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 457 mV CMD Active Level: 1181 mV Can't init device. Reason: CMD CRC Error Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 456 mV CMD Active Level: 1181 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_005723.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: OTA, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: RADIO, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E400000 - 00000E480000], size: 000000080000 (512. KB) Partition: STEADY, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB) Partition: SYSTEM, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB) Partition: CACHE, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB) Partition: CP_DEBUG, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000E3600000 - 000747600000], size: 000664000000 (25.5 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j7y17lte Model = SM-J730F CPU Abi = armeabi-v7a Android release = 9 Security Patch = 2019-05-01 Firmware version = PPR1.180610.011.J730FXWU4CSF5 Firmware date = Wed Jun 12 14:56:34 KST 2019 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 457 mV CMD Active Level: 1180 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_005746.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Samsung Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank Checking for ROM3 ... ROM3 is not blank GPT header successfully parsed EFS backup is performed. Please wait... EFS saved to: \Backups\EFS\efs_SM-J730F_R58K128QQ2X_20210501_005748.bin \Backups\EFS\efs_for_z3x_oldtype_SM-J730F_R58K128QQ2X_20210501_005748.tar \Backups\EFS\efs_for_z3x_newtype_SM-J730F_R58K128QQ2X_20210501_005748.tar All Done Operation: Read by vendor... Destination dir: C:\Program Files\Z3X\EASYJTAGPLUS\Backups\EFS\J730F U4\ Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 457 mV CMD Active Level: 1182 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_005859.extcsd EMMC Init completed. Pit-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: EFS Address: 000000C00000, size: 000001400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 2791.81 Kb/s All done time: [00:00:12:536] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 454 mV CMD Active Level: 1182 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010015.extcsd EMMC Init completed. Operation: MoviNand Reset ... Sending Smart Wipe Request... Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 456 mV CMD Active Level: 1181 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010033.extcsd EMMC Init completed. Operation: MoviNand Format + Reset ... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 456 mV CMD Active Level: 1181 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010103.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 455 mV CMD Active Level: 1182 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010114.extcsd EMMC Init completed. Filename: BJTD4R_9E3EB274_20210430_222635.extcsd Operation: Repairing ExtCsd ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 455 mV CMD Active Level: 1180 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010145.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 455 mV CMD Active Level: 1182 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010423.extcsd EMMC Init completed. Opening file: J7Y17LTE_EUR_OPEN.pit Pit: J7Y17LTE_EUR_OPEN.pit Entry count: 29 The size of the last section has been updated Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 454 mV CMD Active Level: 1182 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_010429.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2445584 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 796.30 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 823.49 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 1566720 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1447.85 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 19124512 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2715.06 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 23968032 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2690.23 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008B00000 , filesize: 38425264 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2705.92 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000F000000 , filesize: 1017600240 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2445 Done writing partition. Write speed: 2573.32 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000CF000000 , filesize: 5882128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 2608.70 KB/s Partition name: NAD_FW Filename: nad_fw.bin , Offset: 0000E2100000 , filesize: 8916240 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2657.68 KB/s Partition name: NAD_REFER Filename: nad_refer.bin , Offset: 0000E3500000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 855.23 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:08:54:384] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 455 mV CMD Active Level: 1182 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_011337.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: CARRIER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: OTA, [000008300000 - 000008B00000], size: 000000800000 (8.00 MB) Partition: RADIO, [000008B00000 - 00000E300000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E300000 - 00000E400000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E400000 - 00000E480000], size: 000000080000 (512. KB) Partition: STEADY, [00000E480000 - 00000E880000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000E880000 - 00000F000000], size: 000000780000 (7.50 MB) Partition: SYSTEM, [00000F000000 - 0000CF000000], size: 0000C0000000 (3.00 GB) Partition: CACHE, [0000CF000000 - 0000DB800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000DB800000 - 0000E1C00000], size: 000006400000 (100. MB) Partition: CP_DEBUG, [0000E1C00000 - 0000E2100000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000E2100000 - 0000E3500000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000E3500000 - 0000E3600000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000E3600000 - 000747BFBE00], size: 0006645FBE00 (25.5 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j7y17lte Model = SM-J730F Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 7.0 Security Patch = 2017-05-01 Firmware version = NRD90M.FA70_J730FXXU4ASE1 Firmware date = Thu May 9 14:32:41 KST 2019 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 455 mV CMD Active Level: 1181 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_011407.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Samsung Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank Checking for ROM3 ... ROM3 is not blank GPT header successfully parsed Missing file for partition: EFS Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 454 mV CMD Active Level: 1180 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_011439.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Partition name: EFS Filename: efs.img , Offset: 000000C00000 , filesize: 20971520 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2357.63 KB/s Check BootConfig for the selected vendor All done time: [00:00:11:463] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 454 mV CMD Active Level: 1181 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_011525.extcsd EMMC Init completed. Opening file: J7Y17LTE_EUR_OPEN.pit Pit: J7Y17LTE_EUR_OPEN.pit Entry count: 29 The size of the last section has been updated BL_J730FXXU4CSF1_CL16068741_QB24097576_REV00_user_ low_ship.tar The list of files in the firmware: sboot.bin.lz4 param.bin.lz4 cm.bin.lz4 AP_J730FXXU4CSF1_CL16068741_QB24097576_REV00_user_ low_ship_meta_OS9.tar The list of files in the firmware: boot.img.lz4 recovery.img.lz4 system.img.lz4 userdata.img.lz4 meta-data/ meta-data/fota.zip CP_J730FXXU4CSED_CP12795613_CL16068741_QB23902069_ REV00_user_low_ship.tar The list of files in the firmware: modem.bin.lz4 CSC_XEO_J730FXEO4CSEE_CL16068741_QB23983022_REV00_ user_low_ship.tar The list of files in the firmware: j7y17lte_eur_open.pit cache.img.lz4 hidden.img.lz4 meta-data/ meta-data/fota.zip Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 24 MHz CMD Pullup Level: 454 mV CMD Active Level: 1181 mV EMMC Device Information : EMMC CID: 150100424A54443452009E3EB274C4A9 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 9E3EB274 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_9E3EB274_20210501_011548.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking Lz4: cm.bin.lz4 Unpacking file: sboot.bin Unpacking Lz4: sboot.bin.lz4 Unpacking file: param.bin Unpacking Lz4: param.bin.lz4 Unpacking file: boot.img Unpacking Lz4: boot.img.lz4 Unpacking file: recovery.img Unpacking Lz4: recovery.img.lz4 Unpacking file: modem.bin Unpacking Lz4: modem.bin.lz4 Unpacking file: system.img Unpacking Lz4: system.img.lz4 Unpacking file: cache.img Unpacking Lz4: cache.img.lz4 Unpacking file: hidden.img Unpacking Lz4: hidden.img.lz4 Unpacking file: userdata.img Unpacking Lz4: userdata.img.lz4 Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2445584 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 792.32 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1728784 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 801.69 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 1505280 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1424.16 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 21829920 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2707.67 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 27599136 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2714.39 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008B00000 , filesize: 38837808 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2706.49 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000F000000 , filesize: 2946711904 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 20 Done writing partition. Write speed: 2713.90 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000CF000000 , filesize: 9810112 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 10 Done writing partition. Write speed: 2640.32 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 0000DB800000 , filesize: 4755632 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 9 Done writing partition. Write speed: 2665.40 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 0000E3600000 , filesize: 287328 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 36 Done writing partition. Write speed: 998.72 KB/s Check BootConfig for the selected vendor All done time: [00:29:24:565] |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
08-09-2021, 17:11 | #3 (permalink) |
No Life Poster Join Date: May 2005 Location: UK
Member: 143848 Status: Offline Thanks Meter: 125 | Please check J330FN MDM trying to remove. After following step by step phone shows Samsung Galaxy J3 screnn and goes blank with led backlight on only. The phone still not going in download mode or recovery. PHP Code: |
08-09-2021, 17:33 | #4 (permalink) |
Member: 143848 Status: Offline Thanks Meter: 125 | Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = DCCF25759D76XXXX Card Serial = AA640A9D EasyJTAG Box Firmware = 2.5301 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1411 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_154056.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: PARAM, [000003400000 - 000003C00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003C00000 - 000005C00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005C00000 - 000008200000], size: 000002600000 (38.0 MB) Partition: OTA, [000008200000 - 000008A00000], size: 000000800000 (8.00 MB) Partition: CDMA-RADIO, [000008A00000 - 000008E00000], size: 000000400000 (4.00 MB) Partition: RADIO, [000008E00000 - 00000E600000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E600000 - 00000E700000], size: 000000100000 (1.00 MB) Partition: DNT, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E800000 - 00000E880000], size: 000000080000 (512. KB) Partition: STEADY, [00000E880000 - 00000EC80000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000EC80000 - 00000F000000], size: 000000380000 (3.50 MB) Partition: SYSTEM, [00000F000000 - 0000BB000000], size: 0000AC000000 (2.69 GB) Partition: CACHE, [0000BB000000 - 0000C7800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000C7800000 - 0000CB400000], size: 000003C00000 (60.0 MB) Partition: CP_DEBUG, [0000CB400000 - 0000CB900000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000CB900000 - 0000CCD00000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000CCD00000 - 0000CCE00000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000CCE00000 - 0003AB3FBE00], size: 0002DE5FBE00 (11.4 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j3y17lte Model = SM-J330FN Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 7.0 Security Patch = 2017-05-01 Firmware version = NRD90M.FA70_J330FNXXU3ARB1 Firmware date = Thu Feb 1 15:26:14 KST 2018 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1051 mV CMD Active Level: 1409 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_154151.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Samsung Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank Checking for ROM3 ... ROM3 is not blank GPT header successfully parsed EFS backup is performed. Please wait... EFS saved to: \Backups\EFS\efs_SM-J330FN_R58K628AVXF_20210809_154153.bin \Backups\EFS\efs_for_z3x_oldtype_SM-J330FN_R58K628AVXF_20210809_154153.tar \Backups\EFS\efs_for_z3x_newtype_SM-J330FN_R58K628AVXF_20210809_154153.tar All Done Operation: Read by vendor... Destination dir: C:\Program Files\Z3X\EASYJTAGPLUS\Backups\EFS\J330FN U3\ Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1052 mV CMD Active Level: 1409 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_154512.extcsd EMMC Init completed. Pit-file created successfully Backup partition: PrimaryGPT Address: 000000000000, size: 000000004400 GPTHeader is valid Partition name: EFS Address: 000000C00000, size: 000001400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 3432.64 Kb/s Partition name: CPEFS Address: 000002000000, size: 000000800000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4214.49 Kb/s Partition name: M9KEFS1 Address: 000002800000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4244.14 Kb/s Partition name: M9KEFS2 Address: 000002C00000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4251.76 Kb/s Partition name: M9KEFS3 Address: 000003000000, size: 000000400000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4224.67 Kb/s Partition name: CP_DEBUG Address: 0000CB400000, size: 000000500000 eMMC switching to ROM1 Reading partition... Done reading partition. Read speed: 4214.52 Kb/s All done time: [00:00:18:605] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1412 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_155247.extcsd EMMC Init completed. Operation: MoviNand Reset ... Sending Smart Wipe Request... Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1052 mV CMD Active Level: 1411 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_155311.extcsd EMMC Init completed. Operation: MoviNand Format + Reset ... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB Wiping Card... Please do not touch it! Successfully Please don't forget to repair extCSD from backup! Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1411 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_155337.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1408 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_155348.extcsd EMMC Init completed. Filename: QE63MB_F1C8A843_20210809_155348.extcsd Operation: Repairing ExtCsd ... Successfully Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1054 mV CMD Active Level: 1412 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_155436.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1411 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_160747.extcsd EMMC Init completed. Opening file: J3Y17LTE_CIS_SER.pit Pit: J3Y17LTE_CIS_SER.pit Entry count: 30 The size of the last section has been updated Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1051 mV CMD Active Level: 1412 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_160924.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2183440 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 1038.84 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1601808 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 1045.57 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003400000 , filesize: 921600 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1861.36 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003C00000 , filesize: 17682720 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3885.26 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005C00000 , filesize: 20687136 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3872.74 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008E00000 , filesize: 33610288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 4042.30 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000F000000 , filesize: 1048731472 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 2547 Done writing partition. Write speed: 3527.69 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000BB000000 , filesize: 5882128 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 15 Done writing partition. Write speed: 3593.33 KB/s Partition name: NAD_FW Filename: nad_fw.bin , Offset: 0000CB900000 , filesize: 4652816 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 3679.02 KB/s Partition name: NAD_REFER Filename: nad_refer.bin , Offset: 0000CCD00000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1642.34 KB/s Partition EFS : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:08:38:932] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1052 mV CMD Active Level: 1409 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_161851.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: PARAM, [000003400000 - 000003C00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003C00000 - 000005C00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005C00000 - 000008200000], size: 000002600000 (38.0 MB) Partition: OTA, [000008200000 - 000008A00000], size: 000000800000 (8.00 MB) Partition: CDMA-RADIO, [000008A00000 - 000008E00000], size: 000000400000 (4.00 MB) Partition: RADIO, [000008E00000 - 00000E600000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E600000 - 00000E700000], size: 000000100000 (1.00 MB) Partition: DNT, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E800000 - 00000E880000], size: 000000080000 (512. KB) Partition: STEADY, [00000E880000 - 00000EC80000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000EC80000 - 00000F000000], size: 000000380000 (3.50 MB) Partition: SYSTEM, [00000F000000 - 0000BB000000], size: 0000AC000000 (2.69 GB) Partition: CACHE, [0000BB000000 - 0000C7800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000C7800000 - 0000CB400000], size: 000003C00000 (60.0 MB) Partition: CP_DEBUG, [0000CB400000 - 0000CB900000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000CB900000 - 0000CCD00000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000CCD00000 - 0000CCE00000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000CCE00000 - 0003AB3FBE00], size: 0002DE5FBE00 (11.4 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j3y17lte Model = SM-J330FN Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 7.0 Security Patch = 2017-05-01 Firmware version = NRD90M.FA70_J330FNXXU3ARB1 Firmware date = Thu Feb 1 15:26:14 KST 2018 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1412 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_162001.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Samsung Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is not blank Checking for ROM3 ... ROM3 is not blank GPT header successfully parsed Missing file for partition: EFS Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1411 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_162316.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Partition name: EFS Filename: efs.img , Offset: 000000C00000 , filesize: 20971520 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 3255.89 KB/s Check BootConfig for the selected vendor All done time: [00:00:07:080] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1411 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_162637.extcsd EMMC Init completed. Opening file: J3Y17LTE_CIS_SER.pit Pit: J3Y17LTE_CIS_SER.pit Entry count: 30 The size of the last section has been updated BL_J330FNXXU3ARB1_CL12611565_QB16770646_REV00_user _low_ship.tar.md5 The list of files in the firmware: sboot.bin param.bin cm.bin AP_J330FNXXU3ARB1_CL12611565_QB16770646_REV00_user _low_ship_meta.tar.md5 The list of files in the firmware: boot.img recovery.img system.img userdata.img meta-data/ meta-data/fota.zip CP_J330FNXXU3ARA1_CL687063_QB8652130_SIGNED.tar.md 5 The list of files in the firmware: modem.bin CSC_O2U_J330FNO2U3ARA1_CL12886565_QB16548040_REV00 _user_low_ship.tar.md5 The list of files in the firmware: j3y17lte_cis_ser_hidden200m.pit cache.img hidden.img Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1053 mV CMD Active Level: 1413 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_163037.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 0003AB3FBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking file: sboot.bin Unpacking file: param.bin Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: modem.bin Unpacking file: system.img Unpacking file: cache.img Unpacking file: hidden.img Unpacking file: userdata.img Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2183440 bytes eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 1044.44 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1601808 bytes eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 1032.65 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003400000 , filesize: 921600 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 1810.84 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003C00000 , filesize: 17918240 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 3848.10 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005C00000 , filesize: 20773152 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 3976.10 KB/s Partition name: RADIO Filename: modem.bin , Offset: 000008E00000 , filesize: 33623952 bytes eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 3849.30 KB/s Partition name: SYSTEM Filename: system.img , Offset: 00000F000000 , filesize: 2646765120 bytes eMMC switching to ROM1 Writing partition... Sparse image found v.1.0 Total chunks: 3298 Done writing partition. Write speed: 3751.27 KB/s Partition name: CACHE Filename: cache.img , Offset: 0000BB000000 , filesize: 43737376 bytes eMMC switching to ROM1 Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 4027.31 KB/s Partition name: HIDDEN Filename: hidden.img , Offset: 0000C7800000 , filesize: 104358272 bytes eMMC switching to ROM1 Writing partition... Sparse image found v.1.0 Total chunks: 22 Done writing partition. Write speed: 3983.62 KB/s Partition name: USERDATA Filename: userdata.img , Offset: 0000CCE00000 , filesize: 922091888 bytes eMMC switching to ROM1 Writing partition... Sparse image found v.1.0 Total chunks: 277 Done writing partition. Write speed: 3889.17 KB/s Check BootConfig for the selected vendor All done time: [00:16:22:882] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 1052 mV CMD Active Level: 1412 mV EMMC Device Information : EMMC CID: 150100514536334D4200F1C8A8432531 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: F1C8A843 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 2/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 2 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_F1C8A843_20210809_165225.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: M9KEFS1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: M9KEFS2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: M9KEFS3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: PARAM, [000003400000 - 000003C00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003C00000 - 000005C00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005C00000 - 000008200000], size: 000002600000 (38.0 MB) Partition: OTA, [000008200000 - 000008A00000], size: 000000800000 (8.00 MB) Partition: CDMA-RADIO, [000008A00000 - 000008E00000], size: 000000400000 (4.00 MB) Partition: RADIO, [000008E00000 - 00000E600000], size: 000005800000 (88.0 MB) Partition: TOMBSTONES, [00000E600000 - 00000E700000], size: 000000100000 (1.00 MB) Partition: DNT, [00000E700000 - 00000E800000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000E800000 - 00000E880000], size: 000000080000 (512. KB) Partition: STEADY, [00000E880000 - 00000EC80000], size: 000000400000 (4.00 MB) Partition: RESERVED2, [00000EC80000 - 00000F000000], size: 000000380000 (3.50 MB) Partition: SYSTEM, [00000F000000 - 0000BB000000], size: 0000AC000000 (2.69 GB) Partition: CACHE, [0000BB000000 - 0000C7800000], size: 00000C800000 (200. MB) Partition: HIDDEN, [0000C7800000 - 0000CB400000], size: 000003C00000 (60.0 MB) Partition: CP_DEBUG, [0000CB400000 - 0000CB900000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000CB900000 - 0000CCD00000], size: 000001400000 (20.0 MB) Partition: NAD_REFER, [0000CCD00000 - 0000CCE00000], size: 000000100000 (1.00 MB) Partition: USERDATA, [0000CCE00000 - 0003AB3FBE00], size: 0002DE5FBE00 (11.4 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Device = j3y17lte Model = SM-J330FN Phone platform = exynos5 CPU Abi = armeabi-v7a Android release = 7.0 Security Patch = 2018-02-01 Firmware version = NRD90M.J330FNXXU3ARB1 Firmware date = Thu Feb 1 22:27:04 KST 2018 |
