06-23-2020, 03:22 | #1 (permalink) |
No Life Poster Join Date: Jan 2005 Location: the earth Age: 41
Member: 103024 Status: Offline Thanks Meter: 616 | Note 10+ sm-n975f cannot programm I NEED TO RESET AND DELETE SOME PARTITIONS FOR MAKE THE JOB I AM USING IC FRIENDS SOCKET AND THE BGA SEEMS TO BE A BGA 153 UFS 3.0 THE UFS PACKAGE IS " KLUEG8UHDB-C2D1 " CAN YOU CONFIRM IF BGA TYPE IS ALREADY SUPPORTED CAUSE I HAVE Can't open link, Code: -507, Reason: UIC: Link initialization fail WHEN TRY TO READ / WRITE |
06-29-2020, 16:00 | #7 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Easy JTAG plus 2.51 firmware is speed optimized firmware. May be Moorc socket have problem with it Try to this patch to Moork sockets it's my photo https://www.facebook.com/Mipitester/...pe=3&__tn__=-R |
06-30-2020, 03:58 | #8 (permalink) | |
Member: 103024 Status: Offline Thanks Meter: 616 | Quote:
Can't open link, Code: -507, Reason: UIC: Link initialization fail WHEN TRY TO READ / WRITE i will try tomorrow with the lastest update and lastest box firmware and let you know , thanks for answer | |
06-30-2020, 04:24 | #9 (permalink) | |
Insane Poster Join Date: Sep 2011 Location: Viet Nam
Member: 1654760 Status: Offline Thanks Meter: 21 | Quote:
. . . not this | |
06-30-2020, 11:14 | #11 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | We make some fixes to UFS core at next version. It's may be help If you want to use old Classic software - run it with "Left Ctrl" pressed Last edited by layder; 07-01-2020 at 00:40. |
07-06-2020, 23:59 | #14 (permalink) |
Freak Poster Join Date: Jul 2006 Location: sprinfield usa. Age: 36
Member: 309769 Status: Offline Thanks Meter: 50 | I have two easy jtag, a few days ago I tried to update the fw of a box and after that it does not detect ufs n975f by ufs piount, but the other box with the old fw if it detects it, is there any possibility of dowgrade the fw of my box ? tks same problem, test 1 easy jtag without update FW and connect OK, other box with update fw, and not connect PD. i use UFS BGA-153 adapter Z3X ... Last edited by layder; 08-18-2020 at 07:40. Reason: merge posts |
07-08-2020, 19:13 | #15 (permalink) |
Member: 309769 Status: Offline Thanks Meter: 50 | eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 18363 (10.0.18362.900) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = Card Serial = AAC96A09 EasyJTAG Box Firmware = 2.52 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/UFS UFS Init Failed, error: 0 Setting interface to EasyJtag2/UFS UFS Init Failed, error: 0 |
The Following User Says Thank You to ktienda For This Useful Post: |
