Old 07-29-2019, 12:59   #1 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
oppo a3s after remove password dead final solution step by step
lot of people face oppo a3s dead after remove password with z3x easy jtag
plus,so who knows proper solution without dead risk post here step by step.
thanks advance.
Old 07-29-2019, 14:58   #2 (permalink)
Member: 993718
Thanks Meter: 91
if phone detect 9008 port then chek CLK resistor
if damage then change same value resistor or short it phone will be alive again
many time CLK resistor damage
The Following 6 Users Say Thank You to dev.saini For This Useful Post:
Old 08-13-2019, 07:19   #3 (permalink)
Member: 920138
Thanks Meter: 97
im looking a solution of these problem, i encountered it twice. handset full dead, not connect to pc, try change clock resistor no luckl, isip and jtag again no luck cant connect emmc, vcc and vccq voltage ok, may be emmc is damage...why got dead after wipe password..
Old 08-13-2019, 20:12   #4 (permalink)
Member: 718338
Sonork: 100.1623688
Thanks Meter: 43
Bug in easy jtag may be
Sent from my Redmi Note 4 using Tapatalk
Old 08-15-2019, 04:21   #5 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
we need clear video step by step otherwise face big problem.customer angry with us
Old 08-20-2019, 11:09   #6 (permalink)
Member: 2288140
Thanks Meter: 46
tested more thann 150 set with easyjtag nocase till date with easy jtag ....................any one facing issue post clear pic and value in cmd clk d0
Old 08-20-2019, 12:23   #7 (permalink)
Member: 375209
Thanks Meter: 14
need to be careful to resoldiring clk and cmd restor....if u find restor damage ...need u replace with same value of restor
Old 09-13-2019, 14:05   #8 (permalink)
Member: 1462778
Need CLK and CMD Resistor Values
Thanks For advanced
Old 09-13-2019, 19:47   #9 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Thanks For advanced
CLK 15-27 R
CMD 10-15k
The Following 8 Users Say Thank You to layder For This Useful Post:
Old 09-14-2019, 03:52   #10 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
dont click wipe userdata just click reset oppo
Old 09-16-2019, 15:44   #11 (permalink)
Member: 1034743
Sonork: 100.1619212
Thanks Meter: 193
yes bro,
it's perfect solution , not risk
Old 09-19-2019, 04:06   #12 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 1,790
If your mobile model oppo a1k then click wipe userdata because this mtk based cpu
Old 10-30-2019, 15:33   #13 (permalink)
Member: 2111064
Thanks Meter: 21
@ALL
what if the VCCQ resistor is damaged? is there any other alternative? iam a newbie in soldering testpoints and the track got cut from the resistor aand now the mobile phone is not switching on! any solution?
wbr
Old 11-02-2019, 13:48   #14 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 253
Originally Posted by atstech View Post
@ALL
wbr
vccq is 1.8volts power to emmc there is no resistor but capacitor..and even without it,it should still work..not unless you connected your vccq to cmd resistor..
The Following User Says Thank You to simpleprince49 For This Useful Post:
Old 11-14-2019, 10:25   #15 (permalink)
Member: 721889
Thanks Meter: 5
Page generated in 0.21044 seconds with 8 queries
