01-21-2021, 06:45 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | S10e problem read backup Identify UFS Chip. UFS Chip Voltage: Low Check ISP connect. Calibrate ISP. VCC: 3247mV VCCQ2: 1912mV Chip Info: Manufacturer: TOSHIBA ProductName: THGAF8T0T43BAIRA SerialNumber: SCLOCN402K00 Firmware Version: 0.0B UFS Version: 2.1 Maximum Number of LUs: 32 Number of LUs found: 4 LUN 0: Block size: 0x1000 Size: 0x1DC5C00000 / 119,092,000,000B / 119GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB LUN 3: Block size: 0x1000 Size: 0x3C00000 / 0,060,000,000B / 60MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x1000000 / 0,016,000,000B / 16MB Full size: 0x1DCC800000 / 119,200,000,000B / 119GB Health: Device life time method A: 0x01 (0%-10% device life time used) Device life time method B: 0x01 (0%-10% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Chip config is OTP Read UFS LUN0, Address: 0x0 ,Length: 0x40000000 Output file :C:\S10e lotmode\UFS_THGAF8T0T43BAIRA_0_00000000_40000000.b in Start Can't read address 0x0, Code: -108, Reason: UTP: response timeout Try to reconnect UFS Reconnected continue read Can't read address 0x0, Code: -2139062144, Reason: Unknown error (-2139062144) Can't read address 0x0, Code: -108, Reason: UTP: response timeout Can't stop LU, Code: -2139062144, Reason: Unknown error (-2139062144) Done. |
