03-28-2019, 14:18 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: GSM WORLD
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Beta software feauture RPMB status question " EMMC RPMB Status: 7, Reason: RPMB Authentication key not yet programmed " I Tried Many Firmwares But Same Problem Need Help Please Code: ---------- eMMC Device Information ---------- eMMC CID : 150100525836344D4203F5DEC2883413 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 03/2017 Rev.0x3 eMMC NAME: RX64MB , S/N: 4125016712 eMMC NAME (HEX): 525836344D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB Status: 7, Reason: RPMB Authentication key not yet programmed EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX64MB_4125016712_20190328_1533.extcsd Partition info successfully found Found Data areas (firmware parts) count is: 36 --------------------------------------------- P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB P2 (PARA) [0x2108000 0x80000] Size: 512.0KB P3 (RESERVE1) [0x2188000 0x200000] Size: 2.0MB P4 (RESERVE2) [0x2388000 0x1000000] Size: 16.0MB P5 (RESERVE3) [0x3388000 0x200000] Size: 2.0MB P6 (RESERVE4) [0x3588000 0x1000000] Size: 16.0MB P7 (OPPO_CUSTOM) [0x4588000 0x100000] Size: 1.0MB P8 (EXPDB) [0x4688000 0x1400000] Size: 20.0MB P9 (FRP) [0x5a88000 0x100000] Size: 1.0MB P10 (NVCFG) [0x5b88000 0x2000000] Size: 32.0MB P11 (NVDATA) [0x7b88000 0x4000000] Size: 64.0MB P12 (METADATA) [0xbb88000 0x2000000] Size: 32.0MB P13 (PROTECT1) [0xdb88000 0x800000] Size: 8.0MB P14 (PROTECT2) [0xe388000 0xc78000] Size: 12.468MB P15 (SECCFG) [0xf000000 0x800000] Size: 8.0MB P16 (PERSIST) [0xf800000 0x3000000] Size: 48.0MB P17 (SEC1) [0x12800000 0x200000] Size: 2.0MB P18 (PROINFO) [0x12a00000 0x300000] Size: 3.0MB P19 (MD1IMG) [0x12d00000 0x4000000] Size: 64.0MB P20 (MD1DSP) [0x16d00000 0x1000000] Size: 16.0MB P21 (SPMFW) [0x17d00000 0x100000] Size: 1.0MB P22 (SSPM_1) [0x17e00000 0x100000] Size: 1.0MB P23 (SSPM_2) [0x17f00000 0x100000] Size: 1.0MB P24 (GZ1) [0x18000000 0x1000000] Size: 16.0MB P25 (GZ2) [0x19000000 0x1000000] Size: 16.0MB P26 (NVRAM) [0x1a000000 0x4000000] Size: 64.0MB P27 (LK) [0x1e000000 0x100000] Size: 1.0MB P28 (LK2) [0x1e100000 0x100000] Size: 1.0MB P29 (BOOT) [0x1e200000 0x2000000] Size: 32.0MB P30 (LOGO) [0x20200000 0x800000] Size: 8.0MB P31 (TEE1) [0x20a00000 0x500000] Size: 5.0MB P32 (TEE2) [0x20f00000 0x500000] Size: 5.0MB P33 (RESERVE_EXP1) [0x21400000 0x400000] Size: 4.0MB P34 (SYSTEM) [0x21800000 0x158000000] Size: 5.375GB P35 (RESERVE_EXP2) [0x179800000 0x400000] Size: 4.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0021800000 (5.375GB) Build ID: N6F26Q Release Incremental ID: 1510852707 Release Base ID: 7.1.1 Architecture ABI: arm64-v8a Device manufacturer: OPPO Device Platform: mt6763 Build Description: full_oppo6763_17031-user 7.1.1 N6F26Q 1510852707 release-keys Device Model: OPPO CPH1723 Device Name: CPH1723 Product ID: oppo6763_17031 Display Build ID: CPH1723EX_11_A.07_171116 --------------------------------------------- Done. @NoName® Respected Sir Need Help Please Thanks Anticipation Last edited by layder; 03-28-2019 at 22:02. Reason: merge posts |
The Following 2 Users Say Thank You to shoaibrao For This Useful Post: |
03-28-2019, 22:01 | #4 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | please, wait for release verison this message is informed, for RPMB area used it or not, but this message is changed at release RPMB area is need to be non-used for some phones with Exynos CPU, when eMMC is changed (like Samsung N8000 tablets). |
The Following User Says Thank You to layder For This Useful Post: |
03-28-2019, 22:27 | #5 (permalink) | |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Quote:
Mediatek MT6763 Helio I Flashed With Easy Jtag Plus With Option Vendor MTK Scatter | |
03-28-2019, 23:32 | #6 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | something does not work for you? create a topic for a specific problem. This is a test version, and I will not tell you here what and why it displays. If you do not like this writing, use the latest release. |
03-29-2019, 14:43 | #7 (permalink) | |
Product Supporter Join Date: Mar 2005 Location: China
Member: 129885 Status: Offline Sonork: 100:1603514 Thanks Meter: 6,202 | Quote:
Hello , did you found word error in log ? I dont see any error in your logs. Where is a error ? | |
03-29-2019, 16:14 | #8 (permalink) | |
But That's Seems Something Strange In Log I Tried Many Firmwares With Easy Jtag Plus Vendor MTK Scatter Flashing But Couldn't Alive This Subject So I Made This Thread To Learn Need Your Help Please Thanks Anticipation I | |
03-29-2019, 21:24 | #9 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
You are is not a tester. And you do not need to create on the forum questions on the work of test builds, so as not to create confusion for other users of the program | |
03-30-2019, 10:29 | #10 (permalink) | |
We assuming that error is a situation where something not working or not connection or not starting after operation. If all works and you use leaked beta software I thing you chould not confuse our users. I will rename this topic. Thanks. | |
The Following User Says Thank You to NoName® For This Useful Post: |
03-30-2019, 10:37 | #11 (permalink) | |
Sir If There Is Any Other Version Available For Test I Still Have This Fone In Hands | |
04-01-2019, 16:48 | #13 (permalink) |
Member: 412843 Status: Offline Sonork: 100.1604902 Thanks Meter: 497 | Here Is Full Working/Alive Fone Info @Respected Team Here Is Full Working/Alive Fone Info Code: ---------- eMMC Device Information ---------- eMMC CID : 150100525836344D4203BFE7AAED24A3 eMMC CSD : D02701320F5903FFF6DBFFEF8E40400D eMMC Manufacturer ID: 0015 , OEM ID: 0100 eMMC Date: 02/2017 Rev.0x3 eMMC NAME: RX64MB , S/N: 3219630829 eMMC NAME (HEX): 525836344D42 EMMC ROM1 (Main User Data) Capacity: 29820 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB Counter: 0 EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: RX64MB_3219630829_20190401_2008.extcsd Partition info successfully found Found Data areas (firmware parts) count is: 40 --------------------------------------------- P0 (BOOT_PARA) [0x8000 0x100000] Size: 1.0MB P1 (RECOVERY) [0x108000 0x2000000] Size: 32.0MB P2 (PARA) [0x2108000 0x80000] Size: 512.0KB P3 (RESERVE1) [0x2188000 0x200000] Size: 2.0MB P4 (RESERVE2) [0x2388000 0x1000000] Size: 16.0MB P5 (RESERVE3) [0x3388000 0x200000] Size: 2.0MB P6 (RESERVE4) [0x3588000 0x1000000] Size: 16.0MB P7 (OPPO_CUSTOM) [0x4588000 0x100000] Size: 1.0MB P8 (EXPDB) [0x4688000 0x1400000] Size: 20.0MB P9 (FRP) [0x5a88000 0x100000] Size: 1.0MB P10 (NVCFG) [0x5b88000 0x2000000] Size: 32.0MB P11 (NVDATA) [0x7b88000 0x4000000] Size: 64.0MB P12 (METADATA) [0xbb88000 0x2000000] Size: 32.0MB P13 (PROTECT1) [0xdb88000 0x800000] Size: 8.0MB P14 (PROTECT2) [0xe388000 0xc78000] Size: 12.468MB P15 (SECCFG) [0xf000000 0x800000] Size: 8.0MB P16 (PERSIST) [0xf800000 0x3000000] Size: 48.0MB P17 (SEC1) [0x12800000 0x200000] Size: 2.0MB P18 (PROINFO) [0x12a00000 0x300000] Size: 3.0MB P19 (MD1IMG) [0x12d00000 0x4000000] Size: 64.0MB P20 (MD1DSP) [0x16d00000 0x1000000] Size: 16.0MB P21 (SPMFW) [0x17d00000 0x100000] Size: 1.0MB P22 (SSPM_1) [0x17e00000 0x100000] Size: 1.0MB P23 (SSPM_2) [0x17f00000 0x100000] Size: 1.0MB P24 (GZ1) [0x18000000 0x1000000] Size: 16.0MB P25 (GZ2) [0x19000000 0x1000000] Size: 16.0MB P26 (NVRAM) [0x1a000000 0x4000000] Size: 64.0MB P27 (LK) [0x1e000000 0x100000] Size: 1.0MB P28 (LK2) [0x1e100000 0x100000] Size: 1.0MB P29 (BOOT) [0x1e200000 0x2000000] Size: 32.0MB P30 (LOGO) [0x20200000 0x800000] Size: 8.0MB P31 (TEE1) [0x20a00000 0x500000] Size: 5.0MB P32 (TEE2) [0x20f00000 0x500000] Size: 5.0MB P33 (RESERVE_EXP1) [0x21400000 0x400000] Size: 4.0MB P34 (SYSTEM) [0x21800000 0x158000000] Size: 5.375GB P35 (RESERVE_EXP2) [0x179800000 0x400000] Size: 4.0MB P36 (RESERVE_EXP3) [0x179c00000 0x400000] Size: 4.0MB P37 (CACHE) [0x17a000000 0x1b000000] Size: 432.0MB P38 (USERDATA) [0x195000000 0x5b1bfbe00] Size: 22.776GB P39 (FLASHINFO) [0x746bfbe00 0x1000000] Size: 16.0MB ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x0021800000 (5.375GB) Build ID: N6F26Q Release Incremental ID: 1510852707 Release Base ID: 7.1.1 Architecture ABI: arm64-v8a Device manufacturer: OPPO Device Platform: mt6763 Build Description: full_oppo6763_17031-user 7.1.1 N6F26Q 1510852707 release-keys Device Model: OPPO CPH1723 Device Name: CPH1723 Product ID: oppo6763_17031 Display Build ID: CPH1723EX_11_A.07_171116 Detected USERDATA USERDATA : 0x0195000000 (22.776GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Done. Code: Checking security ... Z3X EasyJtag Software ver. 3.4.0.9 Skip loading eMMC Addon Firmware CMD Pullup Level:1793 mV CMD Active Level:1864 mV Box IO Level:1800 mV CLK Rate:126353 kHz Bus Width:1bit,SDR Access to current partition forbidden ( size=0 ) Done. |
04-01-2019, 23:43 | #14 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | This line in the log is informational. there is no point in posting logs here, for users on the forum, they don’t carry anything away, and they can be misleading This forum is not intended to discuss beta software versions. |
04-13-2019, 13:40 | #15 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Read more at thread: http://forum.gsmhosting.com/vbb/f672...at-do-2587891/ |
