Old 04-15-2016, 16:55   #1 (permalink)
Member: 182
asus T100ta tablet pc bios help needed
Hi. I have a problem. My asus t100ta tablet pc bios deleted. It couldn't boot. I must write it again. I found dump. But need spi flasher. I think we can write bios chip with z3x jtag. It's winbond W25Q64 8m chip. i found on board tp points but they are called DO, DI, CS. How can we do it with Z3X jtag? Any opinion?
Old 01-06-2017, 00:15   #2 (permalink)
Member: 2668847
Sonork: www.sonork.com
Exclamation how i programmer spi ic or any memory with easy-jtag ?
Old 09-21-2017, 13:01   #3 (permalink)
Member: 2383669
Thanks Meter: 10
SPI Connect Error
Hello
I Have Macbook Air and am trying to remove EFI I connect like in pinout shown on SPI flasher program but not detected by program
so what is the problem ??
the Vcc and GND I use an ethernet cable and dissemble and connect first line and last
I try also 2 different SPI one across battery and one in the back both not working
Can anyone help me ??
Old 09-21-2017, 14:39   #4 (permalink)
Member: 32168
Thanks Meter: 183
Hi
try to use short cables and not so thin...
regards
Old 10-22-2017, 21:33   #5 (permalink)
Member: 124147
Thanks Meter: 20
Log of flashing Winbond 25Q64BV (for Susra stv-lc22t860fl) today
EasyJTAG SPI Flasher v 1.0.0.0
Action: Initialize programmer
Info: Programmer initialization is successful.
Action: Auto identification.
Info: Found Winbond flash chip "W25Q64.V" (8192 kB, SPI) on easyjtag_spi.
Info: Device is auto selected and confirmed.
Action: Check Programmer
Action: Check Device
Action: Action start:
Action: Unlock flash.
Action: Read flash.
Info: Action is SUCCESSFUL.
Info: Time spent 0:25
Info: Reading flash chip contents.
Info: Reading contents from file.
Action: Write to flash.
Info: Reading new flash chip contents.
Action: Verifying flash.
Info: VERIFIED.
Info: Time spent 1:00
The Following User Says Thank You to mcalister1972 For This Useful Post:
Old 10-23-2017, 12:33   #6 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,558
Action: Read flash.
Info: VERIFIED.
hello. Did you remove IC from board or use wires connected to board?
Old 12-07-2017, 08:23   #7 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 161
i could detect and operate flash ic on tp-link router on board
Old 01-01-2018, 18:45   #8 (permalink)
tattoum's Avatar
Member: 16625
Sonork: 1578753
Thanks Meter: 161
Originally Posted by MoazMod View Post
Hello
i think you do not need to use the adapter use the jtag cable directly and if you use the adapter you do no need to supply it with power
Old 03-18-2018, 12:02   #9 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
spi flasher not found chip
Info: Starting programmer with device on port COM32
Info: Found Macronix flash chip "MX25L3205(A)" (4096 kB, SPI) on easyjtag_spi.
Info: Found Macronix flash chip "MX25L3205D/MX25L3208D" (4096 kB, SPI) on easyjtag_spi.
Info: Found Macronix flash chip "MX25L3206E/MX25L3208E" (4096 kB, SPI) on easyjtag_spi.
Info: Found Macronix flash chip "MX25L3273E" (4096 kB, SPI) on easyjtag_spi.
Info: Multiple flash chip definitions match.
Info: Please specify which chip to use.
flash chip mx25l3236f
please update
Old 06-01-2018, 01:41   #10 (permalink)
Member: 39679
Thanks Meter: 41
Spi programming failed Need Help
Info: Starting programmer with device on port COM18
Info: Clock rate ~ 16MHz
Action: Check device configuration.
Info: Found Winbond flash chip "W25Q64.W" (8192 kB, SPI) on easyjtag_spi.
Error: FAILED at 0x00000288! Expected=0xff, Found=0xfe, failed byte count from 0x00000000-0x007fffff: 0xa8b
Info: DISPROVE.
Error: Unexpected exception...Action is FAILED.
Info: Time spent 1:46
Is this error due to bad ic or easy jtag software
Old 09-03-2018, 12:28   #11 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
where are spi pinouts
i want to program bios in EasyJTAG SPI Flasher but dont know how attach
there are pinuts on easy jtag TDI ,TCK ,TMS ,TDO, SRST, AND TRST
BUT ON BIOS IC PINOUT NEED DO ,WP , DI ,CLK AND IO
Old 09-03-2018, 18:56   #12 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
EasyJTAG box (color box) - at attach photo:
1 = MOSI (SI)
3 = SCK
5 = MISO (SO)
15 = #CS
20 = GND
VCC - RJ45 pin 1
HOLD - RJ45 pin 1
WP - 100 Omh to RJ45 pin 1 (VCC)
EasyJTAG PLUS box (b/w box)
1 = MOSI (SI)
3 = SCK
5 = MISO (SO)
15 = #CS
17+19 = VCC
20 = GND
HOLD+WP - 1k resistor to PIN 17+19 (VCC)
The Following 2 Users Say Thank You to layder For This Useful Post:
Old 09-07-2018, 12:20   #13 (permalink)
Member: 1630066
Sonork: 520074
Thanks Meter: 215
Originally Posted by layder View Post
EasyJTAG box (color box) - at atach
1 = MOSI (SI)
3 = SCK
5 = MISO (SO)
15 = #CS
20 = GND
VCC - RJ45 pin 1
HOLD - RJ45 pin 1
1 = MOSI (SI)
3 = SCK
5 = MISO (SO)
15 = #CS
17 = VCC+HOLD
20 = GND
WP - 100 Omh to PIN 17 (VCC)
thank u boss it is done
Info: Starting programmer with device on port COM16
Action: Registering device insert notification...
Info: Success register device notification #box gen 0
Action: Registering device insert notification is finished
Info: Found GigaDevice flash chip "GD25Q64(B)" (8192 kB, SPI) on easyjtag_spi.
Action: Erase flash.
Info: Time spent 1:56
Info: Flash is blank.
Info: Time spent 0:29
Info: VERIFIED.
Info: Time spent 1:52
Old 02-11-2019, 21:52   #14 (permalink)
Member: 975554
Sonork: KG state:prenormal
Thanks Meter: 253
spi flasher help
i want to unlock bios from macbook
chip is winbond 25q64fv
is this supported?
logs
EasyJTAG SPI Flasher v 1.1.0.0
Info: Starting programmer with device on port COM05
Info: Clock rate ~ 14MHz
Info: Device not found.
tried to select
w25q64v
and
w25q64w
but both of thim is not detected
Old 02-12-2019, 17:11   #15 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
If you use EasyJTAG box 1-st generation (old box), you need make 1,8/3.3 power supply adapter (from RJ45 or USB)
Page generated in 0.31699 seconds with 10 queries
