Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #16 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 234 ![]() | Quote:
this is my 1st time to use spi flasher..im confused in 3.3v of this pinouts in bios chip WP VCC HOLD..i tried to connect all of them at same pin in rj45 but its not working also tried to connect WP to pin 17 with resistor i also tried to put 1.8v 2.8v 3.3v in software but when i put tester in vcc pin voltage is not changing..always at 4.2v Last edited by simpleprince49; 02-13-2019 at 15:05. | |
![]() | #17 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2002 Location: Belarus Age: 46
Member: 13148 Status: Offline Thanks Meter: 2,836 | Quote:
PIN 17 - 1.8 - 3.3V (power from box) You doun't need use RJ45!!!!! | |
The Following User Says Thank You to layder For This Useful Post: |
![]() | #18 (permalink) |
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 234 ![]() | finaly able to connect to the chip and its detected as w25Q64V...but i used external 2.5v power suply i dont have this capacitors and 1k resistor the problem now is when i try to do job the software crashes.. after the read function the file is saved and then crashes also when i try the unlock also crashes |
![]() | #19 (permalink) | |
If it's sended, we try to fix it at next updates | |
![]() | #30 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,836 | connection for SPI chips is simply - only 4 data wires, and power for EasyJTAG Plus box chips is powered from box and you need select correct VCC from software (1.8 or 3,3v) For old box you need use external switching power supply |
