Old 05-07-2015, 10:43   #16 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Hi
i have connected i9000 emmc with easyjtag and saying this is not samsung emmc klmag8dedd ?
Detection
Z3X EasyJtag Software ver. 2.0.0.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0FFFF01A289C9EC3, ,FW Ver.: 01.52
CMD Pullup Level:2114 mV
CMD Active Level:2670 mV
eMMC Device Information
EMMC CID : 00000000000000000000000000000000
EMMC CSD : 902601320F5903FFF6DB7FFF96404080
EMMC Manufacturer ID: 0000 , OEM ID: 0000
EMMC Date: 00/2013 Rev.0x0
EMMC NAME: , S/N: 0
EMMC NAME (HEX): 20202020202000
EMMC ROM1 (Main User Data) Capacity: 512 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.0 (MMC 4.0)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: _ 0_20150404_1436.extcsd
Searching for partition tables...
Read Pages Failed, Reason: CARD Data FIFO Timeout Error
Partitioning not detected...
Done.
Running:SAMSUNG: Read S.M.A.R.T Report...
Skip loading eMMC Addon Firmware
This eMMC is not Samsung!
Done.
Running:SAMSUNG: MoviNAND Reset + Format...
Done.
i wana use thid in i9100 may be this will work this was write protected when i removed from m110s
question is it work with i9100 or not?
Old 05-07-2015, 10:47   #17 (permalink)
>>PakFones<<'s Avatar
Member: 553178
Sonork: 100.1592454
Thanks Meter: 957
Hi
Detection
EMMC NAME: , S/N: 0
Done.
Done.
Done.
i am unable to write i9100 bin dump file on ths emmc may be partition problem.
Old 05-07-2015, 23:21   #18 (permalink)
Member: 1569669
Thanks Meter: 257
Hi,
You can press and hold 'SHIFT' then click eMMC firmware update.
Then confirm eMMC part number KMVYL000LM-B503.
But not all eMMC problem can be repaired with firmware update.
Best Regards
Old 05-10-2015, 09:42   #19 (permalink)
HaSHaM3001's Avatar
Member: 2065652
Thanks Meter: 60
EasyJtag Suite ver.: 1.9.1.2 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows XP (build 2600, Service Pack 3).
Successfully connected to box on COM6
Box S/N: 00000000000000000, ,FW Ver.: 01.52
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.0.0, are OK
Z3X Card Serial : 0000000000 , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 1.9.1.2
CMD Pullup Level:2134 mV
CMD Active Level:2217 mV
EMMC CID : 1501003030303030305620110726589C
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2005 Rev.0x56
EMMC NAME: 000000 , S/N: 537986854
EMMC NAME (HEX): 30303030303000
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.5 (MMC 4.41)
Backup saved: 000000_ 537986854_20150401_0750.extcsd
Done.
Running:SAMSUNG: eMMC firmware update...
Confirmed eMMC Part Number: KMVTU000LM-B503
CMD Pullup Level:2722 mV
CMD Active Level:2815 mV
Setup firmware update mode, wait 2..30 sec...
Success!
Sending eMMC firmware...
Success!
Verifying eMMC firmware...
Success!
Flashing eMMC firmware...
Success!
Repairing eMMC CID...
Success!
eMMC firmware is updated now!
Please reconnect all eMMC lines before next operation!
Please don't forget to repair extCSD from backup!
Please don't forget to configure BOOT sizes!
Done.
extCSD file...D:\All Mobaile Pinout\Box Tool\ATF\ATF JTAG\I9300\I9300_ATF_EMMC\S3_BOOT1_0x00000000_0x00 000FFF.bin
Running:Repair extCSD...
CMD Pullup Level:2743 mV
Writing...
Done.
Old 05-17-2015, 20:03   #20 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
EasyJtag Suite ver.: 2.0.0.0 / wxWidgets 3.1.0-W-U started.
Operating system ver.: Windows 7 (build 7601, Service Pack 1).
Successfully connected to box on COM48
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.52
Z3X Card Serial : AA3B-2511 , ver: 22
CMD Pullup Level:1815 mV
CMD Active Level:1887 mV
EMMC CID : 15010056594C30304D194DC673092F52
EMMC CSD : D02701320F5903FFF6DBFFEF8A404066
EMMC Date: 02/2012 Rev.0x19
EMMC NAME: VYL00M , S/N: 1304851209
EMMC NAME (HEX): 56594C30304D00
Can't init EMMC, Reason: CARD Data FIFO Timeout Error
Check Data Line!
Done.
CMD Pullup Level:2454 mV
CMD Active Level:2536 mV
EMMC ROM1 (Main User Data) Capacity: 15028 MB
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
Backup saved: VYL00M_1304851209_20150400_2200.extcsd
Done.
Can't init device, Reason: CARD Data FIFO Timeout Error
Done.
always this error..I use working emmc but sam result...
Old 05-17-2015, 20:44   #21 (permalink)
cdma-india's Avatar
Member: 98139
Thanks Meter: 126
its big problem VYL00M to write emmc firmware never succss on this emmc only
Old 05-19-2015, 09:54   #22 (permalink)
Member: 2361859
I have two 9100s with same problem and same EMMC, does this procedure kill client data?
Old 05-20-2015, 21:33   #23 (permalink)
Member: 2389092
Thanks Meter: 2
Question Update, and I need HELP!!!
Hi all, just a quick update. I have found the location of all the points on my EMMC, but I could really use some pointers for the soldering. Because the short between GND and TP needs to stay on while re-connecting the EMMC again, it seems I have to connect all points by wire. Is this correct?
I live in The Netherlands, and what I'm really hoping for is finding someone who has done this before, and is willing to help me do it (absolutely not for free ofcourse). So, if you live anywhere near The Netherlands, and you have experience with this, please send me a PM, and we can work something out! I'll make it worth the effort! Even if that means buying someone a plane ticket
Old 05-21-2015, 17:50   #24 (permalink)
Member: 1771629
Thanks Meter: 3
I hope next update support others eMMC. (Sk hynix,Kingston,etc)
Old 05-26-2015, 10:38   #25 (permalink)
Member: 2361859
Anybody? Even a theoretical answer would be appreciated
Old 05-27-2015, 22:15   #26 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,091
yes...same here...test more than 20pcs emmc.....all not done....hope team will check this....
Nizda Mobile
Old 06-28-2015, 14:54   #27 (permalink)
Member: 1966255
Sonork: Davidlab
Thanks Meter: 10
Each emmc have tp short to gnd.there is in picture of easy jtag
The Following User Says Thank You to okensie For This Useful Post:
Old 09-20-2015, 18:24   #28 (permalink)
Member: 63751
Thanks Meter: 9
after i followed and finished the procedure, can i put back the mmc again in the board? or do i have to write dump on rom1 and rom2 before fixing it back to the board?
Old 11-10-2015, 07:07   #29 (permalink)
Member: 1906979
Sonork: 100.1681049
Thanks Meter: 162
Confirmed eMMC Part Number: KMVYL000LM-B503
Z3X EasyJtag Software ver. 1.9.1.0
Box S/N: 05050C1F2A20426B, ,FW Ver.: 01.52
CMD Pullup Level:2670 mV
CMD Active Level:2753 mV
Success!
Success!
Success!
Success!
Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]!
Do it until progress bar is moving (20 sec timeout)!
Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD]
Done.
Old 03-09-2016, 08:40   #30 (permalink)
Member: 859595
Thanks Meter: 40
EMMC NAME: VYL00M
Z3X EasyJtag Software ver. 2.0.7.0
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52
Warning: CMD Pullup Level (639 mV) too low , check cables etc.!
CMD Active Level:2732 mV
Success!
Success!
Success!
Success!
Success!
Done.
CMD Pullup Level:629 mV
CMD Active Level:2743 mV
HiPower™ mode is ON!
EMMC CID : 15010056594C303000000000017A11AA
EMMC Date: 01/2014 Rev.0x0
EMMC NAME: VYL00 , S/N: 378
EMMC NAME (HEX): 56594C30302000
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: VYL00 _ 378_20160309_1248.extcsd
Done.
extCSD file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 EXTCSD.ext_csd
Writing...
Done.
CMD Pullup Level:649 mV
Backup saved: VYL00 _ 378_20160309_1249.extcsd
Done.
Checking NAND Image : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT1.bin
File successefuly loaded!
Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 BOOT1.bin
USB Open Failed, Reason: PORT Open Error
Done.
CMD Pullup Level:660 mV
Backup saved: VYL00 _ 378_20160309_1255.extcsd
Done.
Input file : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT1.bin
Writing 0000080000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 236 kB/s
Checking NAND Image : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT2.bin
Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 BOOT2.bin
Input file : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT2.bin
Writing 0000080000 bytes to 00000000 ...ROM3 (BOOT2 ROM)
Done. Write Speed: 377 kB/s
Checking NAND Image : C:\Users\H.V.HARPALANI\Desktop\922\7000\USERAREA\N 7000 USERAREA.bin
Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\USE RAREA\N7000 USERAREA.bin
Input file : C:\Users\H.V.HARPALANI\Desktop\922\7000\USERAREA\N 7000 USERAREA.bin
Writing 0004000000 bytes to 00000000 ...ROM1 (USER ROM)
Retry writing adress 0x00008C00 (Attempt #1)...
Retry Fail!
Retry writing adress 0x00008C00 (Attempt #2)...
Retry Fail!
Retry writing adress 0x00008C00 (Attempt #3)...
Retry Fail!
Write Block Failed, Reason: DATA Status Error
Done.
CMD Pullup Level:639 mV
CMD Active Level:2402 mV
Backup saved: VYL00 _ 378_20160309_1258.extcsd
Detected GPT over MBR...
Medium UUID: 52444E41-494F-2044-4D4D-43204449534B
Warning: Entries Count = 128
MMCBLK0P0 (EFS) Range: [0X400000,0X17FFE00] ,Len: 1400000
MMCBLK0P1 (SBL1) Range: [0X1800000,0X193FE00] ,Len: 140000
MMCBLK0P2 (SBL2) Range: [0X1A00000,0X1B3FE00] ,Len: 140000
MMCBLK0P3 (PARAM) Range: [0X1C00000,0X23FFE00] ,Len: 800000
MMCBLK0P4 (KERNEL) Range: [0X2400000,0X2BFFE00] ,Len: 800000
MMCBLK0P5 (RECOVERY) Range: [0X2C00000,0X33FFE00] ,Len: 800000
MMCBLK0P6 (CACHE) Range: [0X3400000,0XFBFFE00] ,Len: C800000
MMCBLK0P7 (MODEM) Range: [0XFC00000,0X10BFFE00] ,Len: 1000000
MMCBLK0P8 (FACTORYFS) Range: [0X10C00000,0X45FFFE00] ,Len: 35400000
MMCBLK0P9 (DATAFS) Range: [0X46000000,0XC5FFFE00] ,Len: 80000000
MMCBLK0P10 (UMS) Range: [0XC6000000,0X38AFFFE00] ,Len: 2C5000000
MMCBLK0P11 (HIDDEN) Range: [0X38B000000,0X3AAFFFE00] ,Len: 20000000
Done...Presets has been updated...
Done.
Done.
After all these still set is dead sir
Page generated in 0.26286 seconds with 9 queries
