05-07-2015, 10:43 | #16 (permalink) |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | i have connected i9000 emmc with easyjtag and saying this is not samsung emmc klmag8dedd ? Detection Code: Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0FFFF01A289C9EC3, ,FW Ver.: 01.52 CMD Pullup Level:2114 mV CMD Active Level:2670 mV eMMC Device Information EMMC CID : 00000000000000000000000000000000 EMMC CSD : 902601320F5903FFF6DB7FFF96404080 EMMC Manufacturer ID: 0000 , OEM ID: 0000 EMMC Date: 00/2013 Rev.0x0 EMMC NAME: , S/N: 0 EMMC NAME (HEX): 20202020202000 EMMC ROM1 (Main User Data) Capacity: 512 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: _ 0_20150404_1436.extcsd ============================================= Extended CSD rev 1.0 (MMC 4.0) ============================================= Searching for partition tables... Read Pages Failed, Reason: CARD Data FIFO Timeout Error Partitioning not detected... Done. Code: Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2114 mV CMD Active Level:2670 mV This eMMC is not Samsung! Done. Code: Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2114 mV CMD Active Level:2670 mV This eMMC is not Samsung! Done. i wana use thid in i9100 may be this will work this was write protected when i removed from m110s question is it work with i9100 or not? |
05-07-2015, 10:47 | #17 (permalink) |
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Hi i have connected i9000 emmc with easyjtag and saying this is not samsung emmc klmag8dedd ? Detection Code: Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 0FFFF01A289C9EC3, ,FW Ver.: 01.52 CMD Pullup Level:2114 mV CMD Active Level:2670 mV eMMC Device Information EMMC CID : 00000000000000000000000000000000 EMMC CSD : 902601320F5903FFF6DB7FFF96404080 EMMC Manufacturer ID: 0000 , OEM ID: 0000 EMMC Date: 00/2013 Rev.0x0 EMMC NAME: , S/N: 0 EMMC NAME (HEX): 20202020202000 EMMC ROM1 (Main User Data) Capacity: 512 MB EMMC ROM2 (Boot Partition 1) Capacity: 0 kB EMMC ROM3 (Boot Partition 2) Capacity: 0 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.0 (MMC 4.0) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: _ 0_20150404_1436.extcsd ============================================= Extended CSD rev 1.0 (MMC 4.0) ============================================= Searching for partition tables... Read Pages Failed, Reason: CARD Data FIFO Timeout Error Partitioning not detected... Done. Code: Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2114 mV CMD Active Level:2670 mV This eMMC is not Samsung! Done. Code: Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2114 mV CMD Active Level:2670 mV This eMMC is not Samsung! Done. i wana use thid in i9100 may be this will work this was write protected when i removed from m110s i am unable to write i9100 bin dump file on ths emmc may be partition problem. question is it work with i9100 or not? |
05-07-2015, 23:21 | #18 (permalink) |
Product Supporter Join Date: May 2011
Member: 1569669 Status: Offline Thanks Meter: 257 | Hi, You can press and hold 'SHIFT' then click eMMC firmware update. Then confirm eMMC part number KMVYL000LM-B503. But not all eMMC problem can be repaired with firmware update. Best Regards |
05-10-2015, 09:42 | #19 (permalink) |
Freak Poster Join Date: Nov 2013 Location: SAUDIA ARABIA
Member: 2065652 Status: Offline Thanks Meter: 60 | EasyJtag Suite ver.: 1.9.1.2 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows XP (build 2600, Service Pack 3). Successfully connected to box on COM6 Box S/N: 00000000000000000, ,FW Ver.: 01.52 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : 0000000000 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 1.9.1.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 00000000000000000, ,FW Ver.: 01.52 CMD Pullup Level:2134 mV CMD Active Level:2217 mV eMMC Device Information EMMC CID : 1501003030303030305620110726589C EMMC CSD : 902701320F5903FFF6DBFFEF8A404022 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2005 Rev.0x56 EMMC NAME: 000000 , S/N: 537986854 EMMC NAME (HEX): 30303030303000 EMMC ROM1 (Main User Data) Capacity: 16384 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. Backup saved: 000000_ 537986854_20150401_0750.extcsd Done. Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVTU000LM-B503 Z3X EasyJtag Software ver. 1.9.1.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 00000000000000000, ,FW Ver.: 01.52 CMD Pullup Level:2722 mV CMD Active Level:2815 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. extCSD file...D:\All Mobaile Pinout\Box Tool\ATF\ATF JTAG\I9300\I9300_ATF_EMMC\S3_BOOT1_0x00000000_0x00 000FFF.bin Running:Repair extCSD... Z3X EasyJtag Software ver. 1.9.1.2 Skip loading eMMC Addon Firmware CMD Pullup Level:2743 mV CMD Active Level:2815 mV Writing... Done. |
05-17-2015, 20:03 | #20 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | EasyJtag Suite ver.: 2.0.0.0 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 7 (build 7601, Service Pack 1). Successfully connected to box on COM48 Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.52 Box Working Mode: JTAG Box. Box Drivers version: 3.0.0.0, are OK Z3X Card Serial : AA3B-2511 , ver: 22 Z3X Card Activation [LG] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [SAMS] : NOT ACTIVATED , ACTIVATE NOW Z3X Card Activation [JTAG] : ACTIVATED Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.52 CMD Pullup Level:1815 mV CMD Active Level:1887 mV eMMC Device Information EMMC CID : 15010056594C30304D194DC673092F52 EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 02/2012 Rev.0x19 EMMC NAME: VYL00M , S/N: 1304851209 EMMC NAME (HEX): 56594C30304D00 Can't init EMMC, Reason: CARD Data FIFO Timeout Error Check Data Line! Done. Z3X EasyJtag Software ver. 2.0.0.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.52 CMD Pullup Level:2454 mV CMD Active Level:2536 mV eMMC Device Information EMMC CID : 15010056594C30304D194DC673092F52 EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 02/2012 Rev.0x19 EMMC NAME: VYL00M , S/N: 1304851209 EMMC NAME (HEX): 56594C30304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VYL00M_1304851209_20150400_2200.extcsd Done. Running:SAMSUNG: eMMC firmware update... Can't init device, Reason: CARD Data FIFO Timeout Error Done. always this error..I use working emmc but sam result... |
05-20-2015, 21:33 | #23 (permalink) |
Junior Member Join Date: May 2015
Member: 2389092 Status: Offline Thanks Meter: 2 | Update, and I need HELP!!! Hi all, just a quick update. I have found the location of all the points on my EMMC, but I could really use some pointers for the soldering. Because the short between GND and TP needs to stay on while re-connecting the EMMC again, it seems I have to connect all points by wire. Is this correct? I live in The Netherlands, and what I'm really hoping for is finding someone who has done this before, and is willing to help me do it (absolutely not for free ofcourse). So, if you live anywhere near The Netherlands, and you have experience with this, please send me a PM, and we can work something out! I'll make it worth the effort! Even if that means buying someone a plane ticket |
09-20-2015, 18:24 | #28 (permalink) |
Insane Poster Join Date: Apr 2004 Location: Kuwait Age: 47
Member: 63751 Status: Offline Thanks Meter: 9 | after i followed and finished the procedure, can i put back the mmc again in the board? or do i have to write dump on rom1 and rom2 before fixing it back to the board? |
11-10-2015, 07:07 | #29 (permalink) |
No Life Poster Join Date: Mar 2013 Location: Nepal Age: 41
Member: 1906979 Status: Offline Sonork: 100.1681049 Thanks Meter: 162 | Running:SAMSUNG: eMMC firmware update... Confirmed eMMC Part Number: KMVYL000LM-B503 Z3X EasyJtag Software ver. 1.9.1.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 05050C1F2A20426B, ,FW Ver.: 01.52 CMD Pullup Level:2670 mV CMD Active Level:2753 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. |
03-09-2016, 08:40 | #30 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 859595 Status: Offline Thanks Meter: 40 | Running:SAMSUNG: eMMC firmware update... EMMC NAME: VYL00M Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52 Warning: CMD Pullup Level (639 mV) too low , check cables etc.! CMD Active Level:2732 mV Setup firmware update mode, wait 2..30 sec... Success! Sending eMMC firmware... Success! Verifying eMMC firmware... Success! Flashing eMMC firmware... Success! Repairing eMMC CID... Now Reconnect all eMMC Lines [POWER, CMD, CLK, DAT0]! Do it until progress bar is moving (20 sec timeout)! Success! eMMC firmware is updated now! Please reconnect all eMMC lines before next operation! Please don't forget to repair extCSD from backup! Please don't forget to configure BOOT sizes! Done. Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52 CMD Pullup Level:629 mV CMD Active Level:2743 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 15010056594C303000000000017A11AA EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x0 EMMC NAME: VYL00 , S/N: 378 EMMC NAME (HEX): 56594C30302000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured. Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VYL00 _ 378_20160309_1248.extcsd Searching for partition tables... Partitioning not detected... Done. extCSD file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 EXTCSD.ext_csd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:629 mV CMD Active Level:2743 mV Writing... Done. Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52 CMD Pullup Level:649 mV CMD Active Level:2732 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 15010056594C303000000000017A11AA EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x0 EMMC NAME: VYL00 , S/N: 378 EMMC NAME (HEX): 56594C30302000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VYL00 _ 378_20160309_1249.extcsd Searching for partition tables... Partitioning not detected... Done. Checking NAND Image : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT1.bin File successefuly loaded! Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 BOOT1.bin Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware USB Open Failed, Reason: PORT Open Error Done. Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52 CMD Pullup Level:660 mV CMD Active Level:2732 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 15010056594C303000000000017A11AA EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x0 EMMC NAME: VYL00 , S/N: 378 EMMC NAME (HEX): 56594C30302000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VYL00 _ 378_20160309_1255.extcsd Searching for partition tables... Partitioning not detected... Done. Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 BOOT1.bin Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:660 mV CMD Active Level:2732 mV Input file : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT1.bin Writing 0000080000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 236 kB/s Checking NAND Image : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT2.bin File successefuly loaded! Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\N70 00 BOOT2.bin Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:660 mV CMD Active Level:2732 mV Input file : C:\Users\H.V.HARPALANI\Desktop\922\7000\N7000 BOOT2.bin Writing 0000080000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Done. Write Speed: 377 kB/s Checking NAND Image : C:\Users\H.V.HARPALANI\Desktop\922\7000\USERAREA\N 7000 USERAREA.bin File successefuly loaded! Processing file...C:\Users\H.V.HARPALANI\Desktop\922\7000\USE RAREA\N7000 USERAREA.bin Z3X EasyJtag Software ver. 2.0.7.0 Skip loading eMMC Addon Firmware CMD Pullup Level:660 mV CMD Active Level:2732 mV Input file : C:\Users\H.V.HARPALANI\Desktop\922\7000\USERAREA\N 7000 USERAREA.bin Writing 0004000000 bytes to 00000000 ...ROM1 (USER ROM) Retry writing adress 0x00008C00 (Attempt #1)... Retry Fail! Retry writing adress 0x00008C00 (Attempt #2)... Retry Fail! Retry writing adress 0x00008C00 (Attempt #3)... Retry Fail! Write Block Failed, Reason: DATA Status Error Done. Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52 CMD Pullup Level:639 mV CMD Active Level:2402 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 15010056594C303000000000017A11AA EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x0 EMMC NAME: VYL00 , S/N: 378 EMMC NAME (HEX): 56594C30302000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VYL00 _ 378_20160309_1258.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (EFS) Range: [0X400000,0X17FFE00] ,Len: 1400000 MMCBLK0P1 (SBL1) Range: [0X1800000,0X193FE00] ,Len: 140000 MMCBLK0P2 (SBL2) Range: [0X1A00000,0X1B3FE00] ,Len: 140000 MMCBLK0P3 (PARAM) Range: [0X1C00000,0X23FFE00] ,Len: 800000 MMCBLK0P4 (KERNEL) Range: [0X2400000,0X2BFFE00] ,Len: 800000 MMCBLK0P5 (RECOVERY) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P6 (CACHE) Range: [0X3400000,0XFBFFE00] ,Len: C800000 MMCBLK0P7 (MODEM) Range: [0XFC00000,0X10BFFE00] ,Len: 1000000 MMCBLK0P8 (FACTORYFS) Range: [0X10C00000,0X45FFFE00] ,Len: 35400000 MMCBLK0P9 (DATAFS) Range: [0X46000000,0XC5FFFE00] ,Len: 80000000 MMCBLK0P10 (UMS) Range: [0XC6000000,0X38AFFFE00] ,Len: 2C5000000 MMCBLK0P11 (HIDDEN) Range: [0X38B000000,0X3AAFFFE00] ,Len: 20000000 Done...Presets has been updated... Done. Z3X EasyJtag Software ver. 2.0.7.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0707091FE8F7F85A, ,FW Ver.: 01.52 CMD Pullup Level:629 mV CMD Active Level:2732 mV HiPower™ mode is ON! eMMC Device Information EMMC CID : 15010056594C303000000000017A11AA EMMC CSD : D02701320F5903FFF6DBFFEF8A404066 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 01/2014 Rev.0x0 EMMC NAME: VYL00 , S/N: 378 EMMC NAME (HEX): 56594C30302000 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 512 kB EMMC ROM3 (Boot Partition 2) Capacity: 512 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VYL00 _ 378_20160309_1258.extcsd Searching for partition tables... Detected GPT over MBR... Medium UUID: 52444E41-494F-2044-4D4D-43204449534B Warning: Entries Count = 128 MMCBLK0P0 (EFS) Range: [0X400000,0X17FFE00] ,Len: 1400000 MMCBLK0P1 (SBL1) Range: [0X1800000,0X193FE00] ,Len: 140000 MMCBLK0P2 (SBL2) Range: [0X1A00000,0X1B3FE00] ,Len: 140000 MMCBLK0P3 (PARAM) Range: [0X1C00000,0X23FFE00] ,Len: 800000 MMCBLK0P4 (KERNEL) Range: [0X2400000,0X2BFFE00] ,Len: 800000 MMCBLK0P5 (RECOVERY) Range: [0X2C00000,0X33FFE00] ,Len: 800000 MMCBLK0P6 (CACHE) Range: [0X3400000,0XFBFFE00] ,Len: C800000 MMCBLK0P7 (MODEM) Range: [0XFC00000,0X10BFFE00] ,Len: 1000000 MMCBLK0P8 (FACTORYFS) Range: [0X10C00000,0X45FFFE00] ,Len: 35400000 MMCBLK0P9 (DATAFS) Range: [0X46000000,0XC5FFFE00] ,Len: 80000000 MMCBLK0P10 (UMS) Range: [0XC6000000,0X38AFFFE00] ,Len: 2C5000000 MMCBLK0P11 (HIDDEN) Range: [0X38B000000,0X3AAFFFE00] ,Len: 20000000 Done...Presets has been updated... Done. After all these still set is dead sir |
