Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: India
Member: 2421242 Status: Offline Sonork: 100.1614558 Thanks Meter: 697 ![]() | Strange Problem KMDP60018M i updated the FFU 64 gb eMMC After Update ffu showing 32 gb Now what can happen that the same situation comes again Before update firmware Code: Looking for EasyJTAG box... EasyJTAG API ver. 3403 Setting IO Levels to 1.8V Setting frequence to 36 MHz EasyJTAG Box Serial = A974901B7FD37CCE EasyJTAG Box Firmware = 2.5302 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 36 MHz CMD Pullup Level: 1802 mV CMD Active Level: 1854 mV eMMC Init returned = 0 EMMC Device Information : EMMC CID: 150100445036384D4202E3C290FAC89B EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: DP68MB , HEX: 445036384D42 , S/N: E3C290FA , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2021 EMMC ROM 1 (Main User Data) Capacity: 59640 MB (000E8F800000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DP68MB_E3C290FA_20230120_164536.extcsd EMMC Init completed. after update firmware logs..... Code: Looking for EasyJTAG box... EasyJTAG API ver. 3403 Setting IO Levels to 1.8V Setting frequence to 36 MHz EasyJTAG Box Serial = A974901B7FD37CCE EasyJTAG Box Firmware = 2.5302 Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON CMD Pullup Level: 1802 mV CMD Active Level: 1854 mV eMMC Init returned = 0 EMMC Device Information : EMMC CID: 150100445036384D4202E3C290FAC89B EMMC CSD: 902701320F5903FFF6DB7FE08A40403B EMMC Manufacture : SAMSUNG , EMMC NAME: DP68MB , HEX: 445036384D42 , S/N: E3C290FA , rev. 0x02 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 12/2021 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: DP68MB_E3C290FA_20230120_170845.extcsd EMMC Init completed. Any solution? Z3x Team |
