03-24-2015, 20:19 | #1 (permalink) |
Freak Poster Join Date: Dec 2012 Location: UFI#Wellcome Worlwide UFiXers
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | SUCCESS Lumia 520 WPLock EMMC Error "Unable to Find a Bootable option" Today I got Lumia 520 "ERROR : Unable to find a bootable option. press any key to shutdown". This ia common trouble when upgrading WP 8.0 to 8.1, and this is very easy to Fix, by EasyJTAG While other box failed to detect "ivalid blablabla", Easy Jtag show the power Here's step by step how to: 1.) Solder only 4 wire : CMD, CLK, DAT0, and GND 2.) Open Easyjtag Emmc tool, n connet usb directly to pcb as power of Vcc&vccq 3. Click Emmc Tool, set eMMC Voltage to : 3,3v Detect eMMC card, you will see in log "Emmc Permanent Write Protection : YES" This is the problem, just click on Advanced Opt, select "SAMSUNG : remove write protection" and execute by Custom Operation --> 4. Detect Emmc Card again to see the result, the trouble maker is remove Now , .. 5. Assemble phone, and flash normally with any box u have. And, just it, you just revive your phone back to live... Don't forget to Thanks to EasyJTAG |
The Following 37 Users Say Thank You to madgoeslim For This Useful Post: |
04-01-2015, 15:14 | #9 (permalink) | |
Member: 1853929 Status: Offline Sonork: 1653495 Thanks Meter: 426 | Quote:
The Following User Says Thank You to madgoeslim For This Useful Post: |
04-02-2015, 09:06 | #10 (permalink) | |
Freak Poster Join Date: Aug 2006
Member: 330960 Status: Offline Thanks Meter: 54 | Quote:
04-02-2015, 11:02 | #12 (permalink) | |
Z3X EasyJtag Software ver. 1.8.1.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0E01000xxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:1433 mV CMD Active Level:1711 mV eMMC Device Information EMMC CID : 1501004D3847325943004E10455250F4 EMMC CSD : D02701320F5903FFF6DBFFEF96406006 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2013 Rev.0x0 EMMC NAME: <b>M8G2YC</b> , S/N: 1309689170 EMMC NAME (HEX): 4D384732594300 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: <b>Yes<b> EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. Backup saved: M8G2YC_1309689170_20150201_1655.extcsd Done. --------- Running:SAMSUNG: Remove Write Protection... Z3X EasyJtag Software ver. 1.8.1.1 Skip loading eMMC Addon Firmware CMD Pullup Level:1433 mV CMD Active Level:1711 mV Removing write protection... Done. Z3X EasyJtag Software ver. 1.8.1.1 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0E01000xxxxxxxxx, ,FW Ver.: 01.52 CMD Pullup Level:2072 mV CMD Active Level:2681 mV eMMC Device Information EMMC CID : 1501004D3847325943004E10455250F4 EMMC CSD : D02701320F5903FFF6DBFFEF96404062 EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 05/2013 Rev.0x0 EMMC NAME: <b>M8G2YC</b> , S/N: 1309689170 EMMC NAME (HEX): 4D384732594300 EMMC ROM1 (Main User Data) Capacity: 7456 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.5 (MMC 4.41) | |
04-03-2015, 04:34 | #14 (permalink) | ||
No Life Poster Join Date: Jan 2013 Location: India
Member: 1873645 Status: Offline Thanks Meter: 977 | Bro. when you detect emmc card.show emmc is write protected. Quote:
now you need to detect emmc again. if again come in write protection then have 2 ways. 1. emmc are killed/corrupted. 2.try with letest version of easy jtag(1.9) BR | ||
The Following User Says Thank You to laxmi kamlesh For This Useful Post: |
