Old 06-06-2014, 18:55   #31 (permalink)
drjaved_akhter's Avatar
Member: 585807
Thanks Meter: 781
Originally Posted by maplegsm View Post
CMD Active Level:1742 mV
Writing 000000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM)
Access to current partition forbidden ( size=0 )
Done !!!
Z3X EasyJtag Software ver. 1.5.1.0
Loading eMMC Addon Firmware... IO: 1850 mV
Box S/N: 16160C0B8F6638CB, ,FW Ver.: 01.50
CMD Pullup Level:1299 mV
eMMC Device Information
EMMC CID : 15010056545530304DF124152A395FDA
EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 05/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 605366841
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 0 kB
EMMC ROM3 (Boot Partition 2) Capacity: 0 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 kB
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: VTU00M_ 605366841_20140505_2227.extcsd
Done.
Writing file...H:\Z3x\jtag\i9300\dump\EMMC_ROM1_00000000_2 0000000.bin
Skip loading eMMC Addon Firmware
Writing 000020000000 bytes to 00000000 ...ROM1 (USER ROM)
Write Speed: 687 kB/s
Done !!!
after repair emmc name 0000.. ROM2 and ROM3 adress not good
how to resize ?
use search button i upload this video for resize partition
Old 06-06-2014, 19:09   #32 (permalink)
maplegsm's Avatar
Member: 391664
Sonork: Python
Thanks Meter: 1,063
set is dead .............
Old 06-11-2014, 16:29   #33 (permalink)
Member: 585807
Thanks Meter: 781
i request z3x team please add new update emmc tool logs back up in pc............
thanks
Old 06-19-2014, 01:51   #34 (permalink)
Member: 2194348
Thanks Meter: 52
can't repair ,
is this a bad emmc ,or its duo to soldering ,wares connection , hardware...
Z3X EasyJtag Software ver. 1.5.2.3
Box S/N: 0800A006DD1A858D, ,FW Ver.: 01.50
CMD Pullup Level:1928 mV
CMD Active Level:2279 mV
EMMC CID : 15010030303030303333333307265812
EMMC CSD : 902701320F5903FFF6DBFFEF8A404022
EMMC Date: 05/2005 Rev.0x33
EMMC NAME: 000003 , S/N: 858982182
EMMC ROM1 (Main User Data) Capacity: 16384 MB
EMMC ROM2 (Boot Partition 1) Capacity: 512 kB
EMMC ROM3 (Boot Partition 2) Capacity: 512 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)configured.
Backup saved: 000003_ 858982182_20140504_0040.extcsd
Done.
Running:SAMSUNG: MoviNAND VTU00M Name 0000 Repair...
Repair VTU00M eMMC:
Entering repair mode 1...
Erasing repair area...
Success
Writing repair area...
Warning Writing repair area fail
Please, Reconnect eMMC power lines and press 'VTU00M Repair' again
Old 06-23-2014, 14:36   #35 (permalink)
Member: 129486
Thanks Meter: 66
Z3X EasyJtag Software ver. 1.5.5.0
Box S/N: 1414FF0180A9D84A, ,FW Ver.: 01.50
CMD Pullup Level:1381 mV
CMD Active Level:1825 mV
EMMC CID : 1501003030303030305620110726589C
EMMC Date: 05/2005  Rev.0x56
EMMC NAME: <b>000000</b> , S/N:  537986854
Backup saved: 000000_ 537986854_20140501_1627.extcsd
Done.
<br>
Repair VTU00M eMMC:
Success
Success
Success
Exit repair mode 1...
Success
<font color="red">NOTE: This stage was reapir only eMMC NAME , not wear leveling data!!</font>
<font color="red">NOTE: Repair Stage 2 must be done to make eMMC repair completely!</font>
<font color="red">Please, Reconnect eMMC power lines and press 'VTU00M Repair' again</font>
<br>
Repair VTU00M eMMC:
Entering repair mode 2...
Warning Can't enter repair mode 2, Reason: CARD Ready Timeout Error
<br>
Repair VTU00M eMMC:
<br>
Repair VTU00M eMMC:
Success
Success
Success
Exit repair mode 2...
<font color="green">Success</font>
<font color="green">EMMC repair Done , Reconect eMMC and check S.M.A.R.T Report.</font>
<font color="green">Please don't forget to repair <b>extCSD</b> from backup!!!</font>
<font color="green">Please don't forget to configure <b>BOOT</b> sizes!!!</font>
<br>
CMD Active Level:1835 mV
EMMC CID : 15010056545530304DF13A7E479D5F62
EMMC NAME: <b>VTU00M</b> , S/N:  981354397
EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB
EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB
Backup saved: VTU00M_ 981354397_20140501_1630.extcsd
Done.
Running:SAMSUNG: Read S.M.A.R.T Report...
<br>
Reading S.M.A.R.T
S.M.A.R.T Ver. 0 , Card Error mode  : Normal
Super Block size              : 0x00800000 (8388608 bytes)
Super Page size               : 0x00004000 (16384 bytes)
Optimal Write size            : 0x00010000 (65536 bytes)
Read Reclaim count            : 0
Optimal TRIM size             : 0x00002000 (8192 bytes)
Total Number of banks         : 4
Initial bad blocks per bank   : 3,2,1,4
Runtime bad blocks per bank   : 0,0,0,0
Reserved blocks left per bank : 48,49,50,47
All Erase counts (min,avg,max): 0,0,1
SLC Erase counts (min,avg,max): 0,0,1
MLC Erase counts (min,avg,max): 0,0,0
S.M.A.R.T Report Done !!!
Running:Repair extCSD...
<br>
Writing...
Done!
Done.
<font color="red">Please don't forget to repair extCSD from backup!!!</font>
Running:Change BOOT CONFIG...
<br>
Writing eMMC Register...
Written: REG : 179 VAL :48
Done.
Running:Change BOOT WIDTH...
<br>
Written: REG : 177 VAL :1
Done.
<br>
Retry writing adress 0x00014000 (Attempt #1)...
Retry Success !!! Disabling Write Optimistations...
Retry writing adress 0x00025200 (Attempt #1)...
Write Speed: 704 kB/s
Done !!!
<br>
Write Speed: 814 kB/s
Done !!!
<br>
CMD Pullup Level:1371 mV
CMD Active Level:1815 mV
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits  , Partition config [179]: 0x48.
Backup saved: VTU00M_ 981354397_20140501_1646.extcsd
Done.
<br>
Backup saved: VTU00M_ 981354397_20140501_1647.extcsd
Done.
<br>
CMD Pullup Level:1361 mV
Backup saved: VTU00M_ 981354397_20140501_1648.extcsd
Done.
Old 06-23-2014, 14:38   #36 (permalink)
Member: 129486
Thanks Meter: 66
Backup saved: 000000_ 537986854_20140501_1807.extcsd
Done.
<br>
Repair VTU00M eMMC:
Success
Success
Success
Success
<br>
Repair VTU00M eMMC:
<br>
Repair VTU00M eMMC:
<br>
Repair VTU00M eMMC:
<br>
Repair VTU00M eMMC:
Success
Success
Success
<br>
EMMC CID : 15010056545530304DF17AC849465FF2
EMMC NAME: <b>VTU00M</b> , S/N: 2059946310
Backup saved: VTU00M_2059946310_20140501_1809.extcsd
Done.
<br>
Reading S.M.A.R.T
Initial bad blocks per bank   : 2,2,3,6
Reserved blocks left per bank : 49,49,48,45
<br>
Writing...
Done!
Done.
<br>
Done.
<br>
Done.
<br>
Write Speed: 2499 kB/s
Done !!!
<br>
Write Speed: 819 kB/s
Done !!!
Old 08-11-2014, 17:14   #37 (permalink)
Member: 71290
Sonork: 100.1645657
Thanks Meter: 104
thk Z3X
<br>
Z3X EasyJtag Software ver. 1.5.2.0
Box S/N: 161606050BBA9215, ,FW Ver.: 01.50
CMD Pullup Level:1330 mV
CMD Active Level:1753 mV
EMMC CID : 1501003030303030300C201301281062
EMMC Date: 01/2013 Rev.0xc
EMMC NAME: <b>000000</b> , S/N: 538116392
Backup saved: 000000_ 538116392_20140403_1338.extcsd
Done.
<br>
Repair VTU00M eMMC:
Success
Success
Success
Success
<br>
CMD Active Level:1732 mV
EMMC CID : 15010056545530304DF16B75594F4FA4
EMMC Date: 04/2012 Rev.0xf1
EMMC NAME: <b>VTU00M</b> , S/N: 1802852687
Backup saved: VTU00M_1802852687_20140403_1340.extcsd
Done.
The Following User Says Thank You to francoo For This Useful Post:
Old 10-06-2014, 18:14   #38 (permalink)
unlock in nepal's Avatar
Member: 1686564
Sonork: PM me
Thanks Meter: 157
EMMC NAME:0000000000 repair ok but no power on
VTU00M Name 0000 Repair ok
Z3X EasyJtag Software ver. 1.6.3.0
Repair VTU00M eMMC:
Success
Success
Success
Success
<br>
Repair VTU00M eMMC:
Success
Success
Success
<br>
S.M.A.R.T Report
Initial bad blocks per bank : 4,2,3,3
Reserved blocks left per bank : 47,49,48,48
SAMSUNG: MoviNAND Reset + Format
EMMC CID : 15010056545530304DF1090542D05F28
EMMC NAME: <b>VTU00M</b> , S/N: 151339728
Backup saved: VTU00M_ 151339728_20140901_1827.extcsd
Done.
Running:SAMSUNG: MoviNAND Reset + Format...
SAMSUNG: MoviNAND Factory Reset
Sending Internal Reconfiguration Request...
Waiting configuration Apply!!!
Restoring configuration...
EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB
Wiping Card... Please do not touch it!!!
Done.
Running:SAMSUNG: MoviNAND Factory Reset...
CMD Pullup Level:1289 mV
Sending Smart Wipe Request...
Done.
ROM2
All Erase counts (min,avg,max): 0,1,3
SLC Erase counts (min,avg,max): 0,0,2
MLC Erase counts (min,avg,max): 1,1,3
<br>
CMD Active Level:1711 mV
Input file : D:\JTAG Box\EasyJTAG Tool\S3 error\File\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0 0200000.bin
Write Speed: 844 kB/s
Done !!!
ROM1
CMD Pullup Level:1268 mV
CMD Active Level:1722 mV
Input file : D:\JTAG Box\EasyJTAG Tool\S3 error\File\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000 _20000000.bin
Write Speed: 2595 kB/s
Done !!!
<br>
at last info lick this
Backup saved: VTU00M_ 151339728_20140901_1900.extcsd
Done.
But no power on
Old 10-06-2014, 18:21   #39 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 157
which backuo file use to to repair extCSD
Old 10-07-2014, 15:43   #40 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 157
Originally Posted by drjaved_akhter View Post
one more gt-i9300 repair
CMD Pullup Level:1237 mV
CMD Active Level:1608 mV
Repair VTU00M eMMC:
Success
Success
Success
Reading S.M.A.R.T
Initial bad blocks per bank : 2,2,2,2
Reserved blocks left per bank : 49,49,49,49
Success
EMMC repair Done
Please don't forget to configure BOOT sizes!!!
extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\000000_ 537986854_20140403_1228.extcsd
Writing...
Done!
Done.
Written: REG : 179 VAL :8
Done.
Box S/N: 1717160DCD0D8A9F, ,FW Ver.: 01.50
CMD Pullup Level:1216 mV
CMD Active Level:1598 mV
EMMC CID : 15010056545530304DF1E9AC06326F48
EMMC Date: 06/2012 Rev.0xf1
EMMC NAME: VTU00M , S/N: 3920365106
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08.
Backup saved: VTU00M_3920365106_20140403_1236.extcsd
Done.
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM2_00000000_00200000.bin
Done !!!
Writing file...E:\ALL DEVISES\z3x\9. Easy Jtag files\Samsung\GT-I9300\Dump\EMMC_ROM1_00000000_20000000.bin
Write Speed: 836 kB/s
Done !!!
Healp sir 2 pone in hand repair ok but no power on
Done !!!
Ploz healp me fore this stapes
were found this file
Old 10-08-2014, 08:58   #41 (permalink)
Member: 585807
Thanks Meter: 781
Done !!!
check clk regestor or direct it with jumper.....
Old 10-09-2014, 19:04   #42 (permalink)
Member: 1686564
Sonork: PM me
Thanks Meter: 157
Healp me fore working file
Support file is always no power on i nead tasted rom & working VTU00M_ 792068627_20140103_1914.extcsd file Healp me fore all working file
I have same running phone how to read file from ruanning phone healp me
Old 05-15-2015, 14:15   #43 (permalink)
Member: 585807
Thanks Meter: 781
select rom 1 size 512 and read.select rom 2 size 2mb and rom 3 2mb read.................
Old 06-11-2015, 22:57   #44 (permalink)
Member: 1800327
Thanks Meter: 9
how to repair this eror
Z3X EasyJtag Software ver. 1.9.0.5
CMD Active Level:3083 mV
Repair VTU00M eMMC:
Success!
Done.
Old 06-12-2015, 16:15   #45 (permalink)
Member: 585807
Thanks Meter: 781
Repair VTU00M eMMC:
Success!
Done.
always use update exe.emmc tool now v2.02 .use update emmc firmware your problem solved........................
The Following User Says Thank You to drjaved_akhter For This Useful Post:
Page generated in 0.30821 seconds with 8 queries
