06-13-2015, 20:28 | #46 (permalink) |
Freak Poster Join Date: Aug 2009
Member: 1090661 Status: Offline Thanks Meter: 15 | Thank you |
06-14-2015, 15:38 | #47 (permalink) | |
Freak Poster Join Date: Aug 2010 Location: pakistan
Member: 1383093 Status: Offline Thanks Meter: 52 | Quote:
06-25-2015, 23:03 | #48 (permalink) | |
Insane Poster Join Date: Aug 2012 Location: Uzbekistan Age: 38
Member: 1800327 Status: Offline Thanks Meter: 9 | Quote:
Z3X EasyJtag Software ver. 2.0.2.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0AFF500FEA1EA7EC, ,FW Ver.: 01.52 CMD Pullup Level:2877 mV CMD Active Level:3176 mV eMMC Device Information EMMC CID : 15010056545530304DFC3D39868641FA EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 04/2014 Rev.0xFC EMMC NAME: VTU00M , S/N: 1027180166 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. Backup saved: VTU00M_1027180166_20150505_0300.extcsd Done. Processing file...C:\Users\MATRIX\Desktop\EMMC_ROM2_00000000_ 00200000.bin Z3X EasyJtag Software ver. 2.0.2.0 Skip loading eMMC Addon Firmware CMD Pullup Level:2877 mV CMD Active Level:3176 mV Input file : C:\Users\MATRIX\Desktop\EMMC_ROM2_00000000_0020000 0.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Retry writing adress 0x00000000 (Attempt #1)... Retry Fail! Retry writing adress 0x00000000 (Attempt #2)... Retry Fail! Retry writing adress 0x00000000 (Attempt #3)... Retry Fail! Write Block Failed, Reason: DATA SND CRC Error Done. | |
12-03-2015, 19:32 | #49 (permalink) |
No Life Poster Join Date: Sep 2008 Location: kutch, gujarat, india
Member: 852566 Status: Offline Thanks Meter: 464 | EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:783 mV CMD Active Level:2206 mV Erasing 20000000 bytes from 00000000 ...ROM1 Erase Done. Running:SAMSUNG: MoviNAND Reset + Format... Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:783 mV CMD Active Level:2206 mV EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Sending Internal Reconfiguration Request... Waiting configuration Apply! Restoring configuration... EMMC ROM2/3 (Boot Partitions) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB Wiping Card... Please do not touch it! Please don't forget to repair extCSD from backup! Done. You must select a valid extCSD file first! extCSD file...C:\Program Files\Z3X\EASYJTAG\Backups\VTU00M_2329112007_20151 104_2335.extcsd Running:Repair extCSD... Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:783 mV CMD Active Level:2206 mV Writing... Done. You must select flash file first! You must select flash file first! Checking NAND Image : D:\samsung\EasyJTAG Tool\I9300 emmc\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0020000 0.bin File successefuly loaded! Found ROM2 and automatically selected. Processing file...D:\samsung\EasyJTAG Tool\I9300 emmc\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0020000 0.bin Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:783 mV CMD Active Level:2206 mV Input file : D:\samsung\EasyJTAG Tool\I9300 emmc\EMMC_ROM2_2Mb_BOOT\EMMC_ROM2_00000000_0020000 0.bin Writing 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Done. Write Speed: 902 kB/s Checking NAND Image : D:\samsung\EasyJTAG Tool\I9300 emmc\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000_20000 000.bin File successefuly loaded! Processing file...D:\samsung\EasyJTAG Tool\I9300 emmc\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000_20000 000.bin Z3X EasyJtag Software ver. 2.0.6.0 Skip loading eMMC Addon Firmware CMD Pullup Level:783 mV CMD Active Level:2206 mV Input file : D:\samsung\EasyJTAG Tool\I9300 emmc\EMMC_ROM1_512Mb_USER\EMMC_ROM1_00000000_20000 000.bin Writing 0020000000 bytes to 00000000 ...ROM1 (USER ROM) Done. Write Speed: 2520 kB/s Z3X EasyJtag Software ver. 2.0.6.0 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 00000000000000000, ,FW Ver.: 01.52 CMD Pullup Level:773 mV CMD Active Level:2196 mV eMMC Device Information EMMC CID : 15010056545530304DF18AD36DC77F38 EMMC CSD : D02701320F5903FFF6DBFFFF8E40406C EMMC Manufacturer ID: 0015 , OEM ID: 0100 EMMC Date: 07/2012 Rev.0xF1 EMMC NAME: VTU00M , S/N: 2329112007 EMMC NAME (HEX): 56545530304D00 EMMC ROM1 (Main User Data) Capacity: 15028 MB EMMC ROM2 (Boot Partition 1) Capacity: 2048 kB EMMC ROM3 (Boot Partition 2) Capacity: 2048 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x00 Backup saved: VTU00M_2329112007_20151104_2357.extcsd Done. 100% work i repair 50..pcs........... |
12-07-2015, 19:05 | #50 (permalink) |
No Life Poster Join Date: Sep 2007 Location: PAKISTAN
Member: 585807 Status: Offline Thanks Meter: 781 | http://forum.gsmhosting.com/vbb/f258.../#post11237846 use this methed if not detect emmc........................... |
12-12-2015, 08:21 | #51 (permalink) |
Junior Member Join Date: Mar 2015 Location: india.gujarat Age: 27
Member: 2355964 Status: Offline Thanks Meter: 4 | karbonn titanium s5 boot repair successfull done karbonn titanium s5 boot repair successfull done For support and updates visit EasyJtag ? most powerfull eMMC and JTAG tool on market. | EMMC BOX, JTAG BOX ,Z3X , BOOT REPAIR , FORENSICS TOOL Check security...OK Initialising: KARBON S5 Config ver.:1.00 I/O Level set to : 2200 mV Box S/N: 1717F615772588A9 ,FW Ver.: 01.52 Connecting to Target... JTAG device: MSM8625Q CPU IDCODE : 0x008E00E1 Mfg.: 0x070, Part: 0x08e0, Ver.: 0x0 CPU Manufacturer: QUALCOMM , CPU Name: MSM8225Q Halting CPU... Initialize hardware... Starting target communication... Detecting emmc memory parameters of bank (0) ... EMMC #0 : ID : 0x014A0090 Name : XINYH Size : 3.6 G , (7569408) Blocks EMMC #1 : ID : 0x014A0090 Name : XINYH Size : 2.0 M , (4096) Blocks eMMC flash device(s) found, Device ID : 0x0090004a EMMC Writing MBR... eMMC Write OK! Elapsed time: 0.093750s (5.333 KiB/s) EMMC Writing CFG_DATA... eMMC Write OK! Elapsed time: 0.140625s (142.222 KiB/s) EMMC Writing QCSBL... eMMC Write OK! Elapsed time: 5.171875s (48.338 KiB/s) EMMC Writing EBR... eMMC Write OK! Elapsed time: 0.328125s (195.048 KiB/s) EMMC Writing OEMSBL... eMMC Write OK! Elapsed time: 16.234375s (126.152 KiB/s) EMMC Writing APPSBL... eMMC Write OK! Elapsed time: 9.281250s (82.747 KiB/s) EMMC Writing RECOVERY... eMMC Write OK! Elapsed time: 76.453125s (80.363 KiB/s) EMMC Writing BOOT... eMMC Write OK! Elapsed time: 64.671875s (77.190 KiB/s) All Done. |
08-19-2017, 11:59 | #57 (permalink) |
Freak Poster Join Date: Dec 2014 Location: Savar,Dhaka,Bangladesh.
Member: 2318480 Status: Offline Sonork: 100.1669259 Thanks Meter: 198 | my mission successes to asugonj thanks mr. gsmali40 |
The Following User Says Thank You to shahinbangla For This Useful Post: |
