Old 05-28-2021, 22:19   #1 (permalink)
Member: 22284
Thanks Meter: 79
Support help this a530f
This has been long here,I have been asking help but all in vail.
Hello i have A8 2018 sm-a530f which has the emmc files corrupted , i need to revive and when i connect to the Easy Jtag Plus i get the error Partition info not found ,guide repair procedures and below is the log data
Setting interface to EasyJtag2/ISP
Setting bus width to 1 Bit
Setting frequence to 36 MHz
CMD Pullup Level: 445 mV
CMD Active Level: 1192 mV
EMMC Device Information :
EMMC CID: 150100424A5444345200523F424BB5A7
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A544434xx , S/N: 523F42xx , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018
EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Maybe not clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x01 , width 4bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: BJTD4R_523F424B_20210404_201644.extcsd
EMMC Init completed.
Scanning soft partitions
Partition table not found
Get firmware version
Firmware info not found
NOTE: I HAVE THE BACK UP FILE BUT I DO NOT KNOW WHICH FILES TO LOAD , MAY SOMEONE CHECK THE ATTACHMENT AND TELL ME WHICH FILES TO LOAD LIKE (Select eMMC Image file *.bin) from THIS BACK UP.MAY SOMEONE TELL ME FROM THE BACK UP WHICH ONE IS ( eMMC ROM1 Image file, eMMC ROM2 Image file, eMMC ROM3 Image file, eMMC GP1 Image file, eMMC ExtCSD file. IN THEIR ORDER.
I GOT THE DUMP FILE CAN SOMEONE TELL WHICH FILES ARE ROM 1,ROM2,R0M3 and EXS
Powered by Searchlight © 2022 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2022 DragonByte Technologies Ltd.
Page generated in 0.12261 seconds with 8 queries
