10-14-2021, 17:19 | #1 (permalink) |
Freak Poster Join Date: Feb 2013 Location: algeria
Member: 1882912 Status: Offline Sonork: 100.1677703 Thanks Meter: 263 | TA-1204 Restart problem solved with Easy-Jtag Plus Code: ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: CCM4B8_ 45090048_20211014_1600.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x03] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x05] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x07] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x03] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0x00000000] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x00] _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x00] Optimal write size [OPTIMAL_WRITE_SIZE: 0x20] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x01] Device version [DEVICE_VERSION: 0x00 - 0x00] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x02 [FIRMWARE_VERSION[255]]: 0x02 [FIRMWARE_VERSION[254]]: 0x0a Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x00] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x3c] Cache Size [CACHE_SIZE] is 65536 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x1e] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x00] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x00] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x00] [MIN_PERF_DDR_R_8_52: 0x00] TRIM Multiplier [TRIM_MULT: 0x05] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x05] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x10] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x16] Sector Count [SEC_COUNT: 0x01ce8000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x00] [MIN_PERF_R_8_52: 0x00] [MIN_PERF_W_8_26_4_52: 0x00] [MIN_PERF_R_8_26_4_52: 0x00] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x00] [MIN_PERF_R_4_26: 0x00] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x0a] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x08] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x00 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x15 Enable background operations handshake [BKOPS_EN]: 0x00 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000268 Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x01 Native sector size [NATIVE_SECTOR_SIZE]: 0x00 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x00 Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Found valid GPT with protective MBR; using GPT. Real (Hardware) Disk/Image size: 1CE8000 sectors 14.5 GiB Soft (Partitioned) Disk/Image size: 1CE7FBC sectors 14.5 GiB Disk identifier (GUID): 11111111-2222-3333-4444-000000000000 Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30310366 Partition info successfully found ------ Detected 38 partitions ------ P0 (PRODNV) [0x100000 0xa00000] Size: 10.0MB P1 (MISCDATA) [0xb00000 0x100000] Size: 1.0MB P2 (RECOVERY) [0xc00000 0x2300000] Size: 35.0MB P3 (MISC) [0x2f00000 0x100000] Size: 1.0MB P4 (MISCAUTH) [0x3000000 0x300000] Size: 3.0MB P5 (TRUSTOS) [0x3300000 0x600000] Size: 6.0MB P6 (TRUSTOS_BAK) [0x3900000 0x600000] Size: 6.0MB P7 (SML) [0x3f00000 0x100000] Size: 1.0MB P8 (SML_BAK) [0x4000000 0x100000] Size: 1.0MB P9 (UBOOT) [0x4100000 0x100000] Size: 1.0MB P10 (UBOOT_BAK) [0x4200000 0x100000] Size: 1.0MB P11 (UBOOT_LOG) [0x4300000 0x400000] Size: 4.0MB P12 (LOGO) [0x4700000 0x100000] Size: 1.0MB P13 (FBOOTLOGO) [0x4800000 0x100000] Size: 1.0MB P14 (L_FIXNV1) [0x4900000 0x100000] Size: 1.0MB P15 (L_FIXNV2) [0x4a00000 0x100000] Size: 1.0MB P16 (L_RUNTIMENV1) [0x4b00000 0x100000] Size: 1.0MB P17 (L_RUNTIMENV2) [0x4c00000 0x100000] Size: 1.0MB P18 (GPSGL) [0x4d00000 0x100000] Size: 1.0MB P19 (GPSBD) [0x4e00000 0x100000] Size: 1.0MB P20 (WCNMODEM) [0x4f00000 0xa00000] Size: 10.0MB P21 (PERSIST) [0x5900000 0x200000] Size: 2.0MB P22 (L_MODEM) [0x5b00000 0x1900000] Size: 25.0MB P23 (L_DELTANV) [0x7400000 0x100000] Size: 1.0MB P24 (L_GDSP) [0x7500000 0xa00000] Size: 10.0MB P25 (L_LDSP) [0x7f00000 0x1400000] Size: 20.0MB P26 (PM_SYS) [0x9300000 0x100000] Size: 1.0MB P27 (BOOT) [0x9400000 0x2300000] Size: 35.0MB P28 (DTB) [0xb700000 0x800000] Size: 8.0MB P29 (DTBO) [0xbf00000 0x800000] Size: 8.0MB P30 (SYSTEM) [0xc700000 0x76c00000] Size: 1.855GB P31 (CACHE) [0x83300000 0x9600000] Size: 150.0MB P32 (VENDOR) [0x8c900000 0x12c00000] Size: 300.0MB P33 (PRODUCT) [0x9f500000 0x6400000] Size: 100.0MB P34 (ELABLE) [0xa5900000 0x1400000] Size: 20.0MB P35 (VBMETA) [0xa6d00000 0x100000] Size: 1.0MB P36 (VBMETA_BAK) [0xa6e00000 0x100000] Size: 1.0MB P37 (USERDATA) [0xa6f00000 0x2f60fbe00] Size: 11.843GB ------------------------------------ ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000C700000 (1.855GB) Short EXT fs info: Size: 1.825GB Block size: 4.0KB Inode size: 256 Inodes: 119760 Short Android info: Build ID: PPR1.180610.011 Display Build ID: 00WW_1_100 Release Incremental ID: 00WW_1_100 Release Base ID: 9 Security Path: 2020-10-05 Architecture ABI: armeabi-v7a Product ID: NBL Build Description: k550-user 9 PPR1.180610.011 00WW_1_100 release-keys FRP Partition Path: /dev/block/platform/soc/soc:ap-ahb/20600000.sdio/by-name/persist Device Model: Nokia C2 Device Manufacturer: Nokia Device Name A: Nebula_00WW Device Name B: NBL Device manufacturer: HMD Global Backup saved: BuildProp_20211014_1600.txt --------------------------------------------- Detected USERDATA USERDATA : 0x00A6F00000 (11.843GB) Short EXT fs info: Size: 11.843GB Block size: 4.0KB Inode size: 256 Inodes: 776720 Short userdata info: Unable to read gesture.key , code 2 Done. Partition BOOT: File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\boot.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2174 mV CMD Active Level:2270 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2174 mV CMD Active Level:2270 mV Length limit is enabled! Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\boot.img Writing 0002300000 bytes to 0009400000... ROM1 (USER ROM) Done, time taken: 26 sec. Average Write Speed: 1407 kB/s Partition CACHE: Autodetected SPARSE compressed data File size is lower then partition size. Write size is correct to 0x8f0d000 bytes! File C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\cache.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2172 mV CMD Active Level:2271 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. Write Android Sparse file Address: 0x83300000 ,Length: 0x8F0D000 Input file :C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\cache.img Header major ver. 00000001 Header minor ver. 00000000 Header header sz. 0000001C Header chunk hdr. 0000000C Header block size. 00001000 Header total blk 00008F0D Header total chunks 0000000A Begin writing sparse... Writing 0x8002000 packed bytes Partition DTBO: File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\dtbo.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2171 mV CMD Active Level:2270 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2171 mV CMD Active Level:2270 mV Length limit is enabled! Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\dtbo.img Writing 0000800000 bytes to 000BF00000... ROM1 (USER ROM) Done, time taken: 6 sec. Average Write Speed: 1369 kB/s Partition PRODUCT: File C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\product.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2172 mV CMD Active Level:2270 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2172 mV CMD Active Level:2270 mV Length limit is enabled! Input file : C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\product.img Writing 0006400000 bytes to 009F500000... ROM1 (USER ROM) Done, time taken: 74 sec. Average Write Speed: 1413 kB/s Partition RECOVERY: File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\recovery.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2172 mV CMD Active Level:2271 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2172 mV CMD Active Level:2271 mV Length limit is enabled! Input file : C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\recovery.img Writing 0002300000 bytes to 0000C00000... ROM1 (USER ROM) Done, time taken: 26 sec. Average Write Speed: 1408 kB/s Partition SYSTEM: File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\system.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2171 mV CMD Active Level:2269 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2171 mV CMD Active Level:2269 mV Length limit is enabled! Input file : C:\Users\MD_GSM\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\system.img Writing 0076C00000 bytes to 000C700000... ROM1 (USER ROM) Done, time taken: 1404 sec. Average Write Speed: 1418 kB/s Partition VBMETA: File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vbmeta.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2171 mV CMD Active Level:2271 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2171 mV CMD Active Level:2271 mV Length limit is enabled! Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vbmeta.img Writing 0000100000 bytes to 00A6D00000... ROM1 (USER ROM) Done, time taken: 1 sec. Average Write Speed: 1048 kB/s Partition VENDOR: File C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vendor.img successefuly loaded! Checking security ... Z3X EasyJtag Software ver. 3.7.0.24 Loading eMMC GEN2 Firmware... IO: 2400 mV Box S/N: 3D0A23C809CC25C2, ,FW Ver.: 02.53 CMD Pullup Level:2170 mV CMD Active Level:2269 mV Box IO Level:2400 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 88010343434D3442384002B00500677D eMMC CSD : D0FFFF329F5903FFFFFFFFEF9640002D eMMC Manufacturer ID: 0088 , OEM ID: 0103 eMMC Date: 06/2020 Rev.0x40 eMMC NAME: CCM4B8 , S/N: 45090048 eMMC NAME (HEX): 43434D344238 EMMC ROM1 (Main User Data) Capacity: 14800 MB , 0x1CE8000 pages , 0x39D000000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 516 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x08. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Check GPT Table Found valid GPT with protective MBR; using GPT. CMD Pullup Level:2170 mV CMD Active Level:2269 mV Length limit is enabled! Input file : C:\Users\Desktop\HMDSW_Nebula-1100-0-00WW-B01_user_images\HMDSW_Nebula-1100-0-00WW-B01_user_updates\vendor.img Writing 0012C00000 bytes to 008C900000... ROM1 (USER ROM) Done, time taken: 221 sec. Average Write Speed: 1417 kB/s https://forum.gsmhosting.com/vbb/f67...-done-2986145/ MDxavi. Last edited by MDxavi; 10-14-2021 at 17:25. |
The Following User Says Thank You to MDxavi For This Useful Post: |
