04-03-2021, 22:25 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | Team help with A530F working eMMC file Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 36 MHz CMD Pullup Level: 445 mV CMD Active Level: 1195 mV EMMC Device Information : EMMC CID: 150100424A5444345200523F424BB5A7 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: BJTD4R , HEX: 424A54443452 , S/N: 523F424B , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) Counter: 0 , Response: Maybe not clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: BJTD4R_523F424B_20210403_232150.extcsd EMMC Init completed. Scanning soft partitions Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #1 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #2 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #3 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #4 Error reading at address: 000000000000 , error: -4, DATA RCV CRC Error ... Retry #5 Too many errors. Reading has been stopped |
