04-16-2021, 14:37 | #1 (permalink) |
Insane Poster Join Date: Feb 2006
Member: 237022 Status: Offline Thanks Meter: 4 | UFS BGA 254/ISP 2in1 Dont dedect any Chip İn socket : not dedect. Isp wired : not dedect. Im try R3-R4 jumper but not change anythink. here is log eMMC_tool ver. 2.0.0.0 (release date: 30.12.2020) Microsoft Windows 10 (64 bit) build 19041 (10.0.19041.980) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = --------650A1B Card Serial = -------4FF EasyJTAG Box Firmware = 2,5301 30.12.2020 (ver 1.6.4.0) Add: New keys for Oppo unpack Fix: Fix LG Parser Fix: Bugs that have been found through your crash report Add: new version 2.0.0.0 (qualcomm, samsung) Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to Low Setting Frequence to 66 Mhz Can't init device. Error: -51. Reason: BOX: Socket not detected --------------------------------------------------------------------- Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/UFS ISP Setting IO Levels to Low Setting Frequence to 66 Mhz Can't init device. Error: -51. Reason: BOX: Socket not detected |
04-17-2021, 14:00 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
-51 eroor - you use not licanced socket without protection cryptochip you need return this socket to seller | |
The Following User Says Thank You to layder For This Useful Post: |
09-23-2021, 10:11 | #3 (permalink) |
Freak Poster Join Date: Oct 2014 Location: Arusha,Tanzania
Member: 2267293 Status: Offline Thanks Meter: 78 | Hello, before i bought UFS BGA 254 Socket i accidentally bought IC FRIEND CHEAP SOCKET THINKING IT WOULD WORK and not since it does not have encryption chip, because i don't have the resistors 22R resistors for replacements, so my question is can i remove the encryption chip from Easy JTAG UFS Adapter and use it on IC FRIEND ADAPTER?? Thanks. |
The Following User Says Thank You to madcom5 For This Useful Post: |
09-25-2021, 10:18 | #4 (permalink) |
No Life Poster Join Date: Sep 2004 Location: POLAND Age: 43
Member: 82759 Status: Offline Thanks Meter: 153 | You are connecting the adpter and it should be detected Code: Z3X EasyJtag Software ver. 3.7.0.24 UFS Socket Info. Serial: 01236****D3EBE**** Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 08.06.21 Identify UFS Chip. UFS Chip Voltage: High VCC: 3303mV VCCQ2: 1949mV Chip Info: Manufacturer: SAMSUNG ProductName: KLUDG4UHDB-B2D1 SerialNumber: 0x4B933500F93F7EB46CCAFF06C0814C5455313030394D OemID: SAMSUNG_OEM_ID Firmware Version: 0.90 UFS Version: 3.1 |
05-03-2023, 13:46 | #10 (permalink) |
No Life Poster Join Date: Dec 2013 Location: England Manchester
Member: 2081860 Status: Offline Sonork: 100.1608350 Thanks Meter: 128 | Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to High Setting Frequence to 66 Mhz Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-254 by EasyJTAG 26.02.23 Socket Serial: 01232A1F4CD14F99EE Socket Type: UFS_SOCKET_BGA_254 Can't init device. Error: -56. Reason: BOX: UFS Box init link T0 |
07-04-2023, 21:19 | #11 (permalink) | |
Insane Poster Join Date: Jan 2008 Location: California USA
Member: 693376 Status: Offline Thanks Meter: 5 | have you solved the issue?thanks have you managed to solve it? Quote:
The Following User Says Thank You to giaguaro For This Useful Post: |
