Old 07-12-2019, 06:25   #31 (permalink)
Member: 2902578
Thanks Meter: 151
Easy UFS BGA 153 Also need some re-design Release, like MOORC Socket ? or its already fixed from the start ? or such Change only for BGA254 In Moorc Socket to more support like UFS CH1 & CH2 For some speed ?
Old 07-12-2019, 08:57   #32 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
No, current revisions are work is good. We will released next revision later with another power stabilizator
OLD MOORC soket use olny 1 channel, MOORC is replaced it to new revision.
NEW revision of MOORC is at testing now, and work good
Old 07-12-2019, 20:43   #33 (permalink)
Member: 1608151
Sonork: dxfg
read and write speed with too slow ufs
Old 07-12-2019, 22:17   #34 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Read this:
http://forum.gsmhosting.com/vbb/f672.../#post13726765
Old 07-14-2019, 11:02   #35 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,450
Is Easy Adapter Support Emmc + UFS Both Chip Or UFS Only...?
Old 07-14-2019, 13:09   #36 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
emmc and UFS is different technology
sockets is differents
Old 07-15-2019, 08:20   #37 (permalink)
Member: 1834832
Thanks Meter: 1,450
According To This Image Txt ICFriend Socket Support UFS + EMMC Both ...While Easy Socket Only Support UFS Right...?
Old 07-15-2019, 08:29   #38 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
this socket support only UFS chips
maybe if use another bottom basem, upper socket can use for eMMC BGA 153/254, but I can't know this
At photo I see complect only with UFS bottom plate
Old 07-15-2019, 08:44   #39 (permalink)
Member: 2639224
when will your next revision be released (with another power stabilizer) for UFS BGA 153? Current revision has any limitation without another stabilizer?
Old 07-15-2019, 08:59   #40 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
current Moork and our revision is work good
Old 07-16-2019, 10:21   #41 (permalink)
Member: 1911593
Sonork: 100.1645151
Thanks Meter: 130
Pls help me ! I buy UFS socket ICFriend 2in1 (Ver new) by Moorc but speed read and write very slow. (6xxkB/s to 7xxkB/s) How to solve the problem ?
Old 07-16-2019, 13:14   #42 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
You need read 7-th post of this thread
Old 07-16-2019, 23:35   #43 (permalink)
MOORC's Avatar
Member: 1737647
Sonork: 100.1645466
Thanks Meter: 278
We have no add adapter. So don’t support emcp bga254. If you have eMate x. Why you need ?
从我的 iPhone 发送,使用 Tapatalk
Old 07-17-2019, 07:49   #44 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
can handle ufs like emmc test point? or need to chip off
The Following User Says Thank You to Gsmbizz For This Useful Post:
Old 07-17-2019, 18:15   #45 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
emmc 5.1 and somr 5.0 have signed eMMC firmware, not wiped eMMC
we can't have info about UFS firmware.
But if it are exist, we can't restore dead IC, becouse it not wipe internal NAND after it run
Page generated in 0.24065 seconds with 10 queries
