10-01-2019, 00:51 | #76 (permalink) | |
No Life Poster Join Date: Mar 2012 Location: china
Member: 1737647 Status: Offline Sonork: 100.1645466 Thanks Meter: 278 | Quote:
change 9K1 on the box. Don’t use 2.8V VCCQ2 从我的 iPhone 发送,使用 Tapatalk | |
10-04-2019, 20:17 | #79 (permalink) | ||
Freak Poster Join Date: Mar 2010 Location: Earth Age: 39
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | hi i have g930 in hand with H28U64222MMR easy jtag plus cannot read info now i want raplease with KLUBG4G1CE-B0B1 info after write lun0 and 1,2 Quote:
why easy jtag plus cannot config it? when easy jtag support H28U64222MMR (skynix ufs)? thanks | ||
10-07-2019, 11:28 | #81 (permalink) | |
Member: 1265640 Status: Offline Sonork: 100.1622602 Thanks Meter: 51 | Quote:
30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/UFS Setting interface to EasyJtag2/UFS Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-153 by EasyJTAG 19.05.19 Socket Serial: ****************** UFS Power Information : Mode: Low, VCC: 3312mV, VCCQ2: 1835mV UFS Device Information : UFS Manufacturer: SAMSUNG, UFS ProductName: KLUBG4G1CE-B0B1 UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x1C61FBD531027EE39E042ACEFD8143534A33333147464231 Maximum Number of LUs: 8, Number of LUs found: 3, Number of WLUs found: 1, LUs Re-configure: Enabled UFS LUN 0 Capacity: 30508 MB (000772C00000) UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000) UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000) UFS W-LUN 0xC4 (REPORT LUNS) Capacity: 4 MB (000000400000) UFS Init completed. Scanning soft partitions UFS LUN 0 GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: PARAM, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: BOOT, [000002800000 - 000005000000], size: 000002800000 (40.0 MB) Partition: RECOVERY, [000005000000 - 000007E00000], size: 000002E00000 (46.0 MB) Partition: OTA, [000007E00000 - 000008600000], size: 000000800000 (8.00 MB) Partition: RADIO, [000008600000 - 00000B000000], size: 000002A00000 (42.0 MB) Partition: TOMBSTONES, [00000B000000 - 00000B100000], size: 000000100000 (1.00 MB) Partition: DNT, [00000B100000 - 00000B200000], size: 000000100000 (1.00 MB) Partition: PERSISTENT, [00000B200000 - 00000B2C0000], size: 0000000C0000 (768. KB) Partition: STEADY, [00000B2C0000 - 00000B300000], size: 000000040000 (256. KB) Partition: PERSDATA, [00000B300000 - 00000BC00000], size: 000000900000 (9.00 MB) Partition: SYSTEM, [00000BC00000 - 000118800000], size: 00010CC00000 (4.20 GB) Partition: CACHE, [000118800000 - 000125000000], size: 00000C800000 (200. MB) Partition: HIDDEN, [000125000000 - 000128C00000], size: 000003C00000 (60.0 MB) Partition: CP_DEBUG, [000128C00000 - 000129100000], size: 000000500000 (5.00 MB) Partition: USERDATA, [000129100000 - 000771D00000], size: 000648C00000 (25.1 GB) GPT header successfully parsed UFS LUN 1 (Boot A) GPT header is not found UFS LUN 2 (Boot B) GPT header is not found Get firmware version Brand = samsung Manufacturer = samsung Device = herolte Model = SM-G930F Phone platform = exynos5 CPU Abi = arm64-v8a Android release = 8.0.0 Firmware version = R16NW.G930FXXS4ESC3 Firmware date = Thu Mar 7 20:45:18 KST 2019 Last edited by parsa_dig; 10-07-2019 at 11:34. | |
10-07-2019, 11:47 | #82 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | We not added Read-Write UFS config to last Plus software. To read-write UFS config need use Classic Software Re-Configure zone not write to UFS (always Enables when config write) |
10-11-2019, 19:59 | #86 (permalink) |
Junior Member Join Date: Nov 2008
Member: 913338 Status: Offline Thanks Meter: 6 | hi bro Z3X EasyJtag Software ver. 3.6.1.15 UFS Safe Mode is disabled... UFS Socket Info. Serial: 0123C582B06729FDEE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 15.05.19 Identify UFS Chip. UFS Chip Voltage: High Can't init device, Code: -112, Reason: Can't boot device VCC: 3300mV VCCQ2: 2803mV Manufacturer: SKHYNIX ProductName: HBG4a SerialNumber: 0x03A8B4110307 OemID: 01AD Done. i cant read info or img ufs bga 153 with other ufs hinix not work |
10-30-2019, 17:16 | #87 (permalink) |
Junior Member Join Date: Sep 2019 Location: lithuania
Member: 2929551 Status: Offline Thanks Meter: 0 | hi one problem UFS Chip Voltage: High Can't init device, Code: -118, Reason: This chip is temporary unsupported. You could disable UFS Safe Mode in options tab. VCC: 3310mV VCCQ2: 2802mV Manufacturer: SKHYNIX ProductName: HBG4a SerialNumber: 0x03C8D3CD92C1 OemID: 01AD Done. |
11-03-2019, 07:33 | #89 (permalink) | |
Freak Poster Join Date: Mar 2019 Location: Bahawal Nagar Age: 34
Member: 2902578 Status: Offline Thanks Meter: 151 | Found Same Chip on Samsung G S Quote:
"already dead IC " in both cases . | |
