05-15-2021, 09:25 | #226 (permalink) |
Junior Member Join Date: Feb 2020 Location: Turkmenistan
Member: 2947512 Status: Offline Sonork: 213123213 Thanks Meter: 0 | UFS ISP Mode: OFF UFS Safe Mode: ON Initialize UFS Engine Fail. Code: -51/ERROR_UFS_BOX_INIT_NO_SOCKET Scanner Thread Terminated Elapsed: 00:00:00:227 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
06-19-2021, 11:32 | #229 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
https://forum.gsmhosting.com/vbb/f67...l#post14393380 | |
06-21-2021, 09:30 | #230 (permalink) |
Junior Member Join Date: Mar 2021 Location: Wroclaw
Member: 2982753 Status: Offline Thanks Meter: 0 | Hello My Friend I need vcc and vccq2 for this model (n960f) please help me. now i have a error: Can't init device. Error: -1. Reason: CMD Timeout Error - z3x easy jtag |
06-25-2021, 21:25 | #231 (permalink) | |
Product Supporter Join Date: Sep 2017 Location: MH Unlocker Pro
Member: 2753718 Status: Offline Sonork: FB : MH Unlocker Pro Thanks Meter: 811 | Quote:
BR. SeharH | |
07-11-2021, 18:10 | #232 (permalink) |
Junior Member Join Date: May 2012
Member: 1763808 Status: Offline Thanks Meter: 2 | I repaired many G935f (S7 Edge) phones with easyjtag+ufs adaptor but one of them has unknown baseband and i try everything for that then i decide change to a new dump but only lun0 is writable and all other LUNs are PROTECTED. Is there any way to wipe and write those LUNs ? Is this chip okay to use on another phone or its wasted ? Before turning on phone chip was not OTP and phone makes chip OTP Like EMMCs that after turning on phone RPMB will program Am i right ? |
07-12-2021, 11:38 | #233 (permalink) | |
OTP config is closed on many chips, and this chips can not be reconfigured LUN size or type some UFS chips have configured at WLUN partition read only areas at LUNs | |
The Following User Says Thank You to layder For This Useful Post: |
07-16-2021, 14:36 | #234 (permalink) |
Freak Poster Join Date: Dec 2007 Location: iran Age: 45
Member: 652684 Status: Offline Thanks Meter: 20 | is there any way to unlock otp config close on some ufs chip i have 20 secend hand chip with otp lock and i cant confiq again for use another phone fw ufs on new update can not help me. Is there a solution in the future? |
07-18-2021, 18:15 | #236 (permalink) | |
you can not change it | |
07-18-2021, 19:51 | #237 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Colombia
Member: 614683 Status: Offline Sonork: 100.1605379 Thanks Meter: 370 | Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Box Voltage set to: 2800 mV Scanner Thread Created.. Config: 1001111111101111 Setup HiPower CLK: OFF Connecting To EasyJtag Plus Box: 2800mV/36MHz/1BIT EasyJtag Plus Box Found! Result: 0/OK CMD Pullup Level: 2041 mV CMD Active Level: 2215 mV EasyJtag Plus S/N: 2EA1BDB9B5F74404 EasyJtag Plus Box FirmWare: 2.53.2 Box Bus Width = 1 BIT Box Hardware = EasyJtag 2nd Generation Search Emmc Chip... EMMC Chip Found! 0/OK EMMC CID: 150100444836444142027904C4B1C541 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC VENDOR: SAMSUNG EMMC NAME: DH6DAB EMMC DATE: 12/2018 EMMC SERIAL: 7904C4B1 EMMC REVISION: 02 EMMC ROM1 Size: 122142720 Block(s)/59640 MB EMMC ROM2/3 Size: 8192 Block(s)/4096 KB EMMC RPMB Size: 32768 Block(s)/16384 KB EMMC RPMB Counter: 463, State: Dirty EMMC RPMB Answer: 0/OK Switch To ROM1 Part: 0/OK EMMC REV: 1.8 (for MMC v5.1) EMMC VER: MMC 5.1 EMMC DEV Life Time: 0x01 -> Normal EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used EMMC Boot Config: 0x48/0x01/0x01 ExtCSD Automatically Saved.. Scanning Data From EMMC. Please wait.. Scanning GUID Partition Table from ROM1 GUID Partition Table is Found. Max Parts: 128 GPT: GPT [000000000000 - 000000004400] Size: 17,00 KB GPT: EFS [000000400000 - 000001400000] Size: 20,00 MB GPT: SEC_EFS [000001800000 - 000001400000] Size: 20,00 MB GPT: RESERVED [000002C00000 - 000000400000] Size: 4,00 MB GPT: CPEFS [000003000000 - 000000800000] Size: 8,00 MB GPT: STEADY [000003800000 - 000000400000] Size: 4,00 MB GPT: PARAM [000003C00000 - 000000800000] Size: 8,00 MB GPT: BOTA [000004400000 - 000002400000] Size: 36,00 MB GPT: LDFW [000006800000 - 000000800000] Size: 8,00 MB GPT: TZSW [000007000000 - 000000180000] Size: 1,50 MB GPT: TZAR [000007180000 - 000000680000] Size: 6,50 MB GPT: KEYSTORAGE [000007800000 - 000000080000] Size: 512,00 KB GPT: NAD_REFER [000007880000 - 000000100000] Size: 1,00 MB GPT: UP_PARAM [000007980000 - 000000800000] Size: 8,00 MB GPT: MISC [000008180000 - 000000200000] Size: 2,00 MB GPT: UH [000008380000 - 000000200000] Size: 2,00 MB GPT: UHCFG [000008580000 - 000000400000] Size: 4,00 MB GPT: BLCMD [000008980000 - 000000080000] Size: 512,00 KB GPT: BOOT [000008A00000 - 000002400000] Size: 36,00 MB GPT: RECOVERY [00000AE00000 - 000003500000] Size: 53,00 MB GPT: DTB [00000E300000 - 000000800000] Size: 8,00 MB GPT: DTBO [00000EB00000 - 000000800000] Size: 8,00 MB GPT: RADIO [00000F300000 - 000003200000] Size: 50,00 MB GPT: PERSISTENT [000012500000 - 000000080000] Size: 512,00 KB GPT: VBMETA [000012580000 - 000000080000] Size: 512,00 KB GPT: VBMETA_SAMSUNG [000012600000 - 000000080000] Size: 512,00 KB GPT: KEYREFUGE [000012680000 - 000001000000] Size: 16,00 MB GPT: KEYDATA [000013680000 - 000001000000] Size: 16,00 MB GPT: METADATA [000014680000 - 000002000000] Size: 32,00 MB GPT: RESERVED2 [000016680000 - 000000180000] Size: 1,50 MB GPT: SUPER [000016800000 - 00014B400000] Size: 5,18 GB GPT: PRISM [000161C00000 - 000032000000] Size: 800,00 MB GPT: OPTICS [000193C00000 - 000001400000] Size: 20,00 MB GPT: CACHE [000195000000 - 00000C800000] Size: 200,00 MB GPT: OMR [0001A1800000 - 000001400000] Size: 20,00 MB GPT: CP_DEBUG [0001A2C00000 - 000000500000] Size: 5,00 MB GPT: SPU [0001A3100000 - 000003200000] Size: 50,00 MB GPT: USERDATA [0001A6300000 - 000CE9000000] Size: 51,64 GB GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16,50 KB Reading Table Completed Scanning GUID Partition Table from ROM2 GPT Signature Not Found. Break.. Scanning GUID Partition Table from ROM3 GPT Signature Not Found. Break.. Reading Initial Data. Please Wait.. Partition #3 - [SEC_EFS] mount as [/efs] -> 20,00 MB, Type: EXT4 Partition #27 - [KEYREFUGE] mount as [/keyrefuge] -> 16,00 MB, Type: EXT4 Partition #28 - [KEYDATA] mount as [/keydata] -> 16,00 MB, Type: EXT4 Partition #29 - [METADATA] mount as [/metadata] -> 32,00 MB, Type: EXT4 Partition #32 - [PRISM] mount as [/prism] -> 800,00 MB, Type: EXT4 Partition #33 - [OPTICS] mount as [/optics] -> 20,00 MB, Type: EXT4 Partition #34 - [CACHE] mount as [/cache] -> 200,00 MB, Type: EXT4 Partition #35 - [OMR] mount as [/omr] -> 20,00 MB, Type: EXT4 Partition #38 - [USERDATA] mount as [/USERDATA] -> 51,64 GB, Type: F2FS EmptyCheck: EMPTY -> ROM_1 -> Part #2 - [EFS] EMPTY -> ROM_1 -> Part #4 - [RESERVED] EMPTY -> ROM_1 -> Part #5 - [CPEFS] EMPTY -> ROM_1 -> Part #8 - [BOTA] EMPTY -> ROM_1 -> Part #13 - [NAD_REFER] EMPTY -> ROM_1 -> Part #15 - [MISC] EMPTY -> ROM_1 -> Part #16 - [UH] EMPTY -> ROM_1 -> Part #17 - [UHCFG] EMPTY -> ROM_1 -> Part #18 - [BLCMD] EMPTY -> ROM_1 -> Part #21 - [DTB] EMPTY -> ROM_1 -> Part #30 - [RESERVED2] EMPTY -> ROM_1 -> Part #37 - [SPU] EmptyCheck: Done Samsung S/N = RF8R31QE96W Scanner Thread Terminated Elapsed: 00:00:06:695 Found 39 Partition(s).. Scan Done. Init Main Engine... Resetting EasyJtag Box. Wait.. CMD Pullup Level: 2039 mV CMD Active Level: 2214 mV Reader Engine Initialized.. 0/OK Source: EasyJtag Port [EMMC/SD/MMC] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1001111111101111 Bus Mode: 1BIT Operation Done: [Init Engine], Elapsed: 00:00:01:500 Start Writing 0x000001400000 Bytes to Partition #2 -> 'EFS' File: ROM1_DUMP_EFS_0x000000400000_0x000001400000.bin Path: C:\Users\jmr\Desktop\EmmcManager-1.20-19-03-2021\EmmcManager-1.20-19-03-2021\A21s new\ Write All Blocks Done! Count: 40960 Operation Done: [Write Partition], Elapsed: 00:00:05:079 Start Writing 0x000001400000 Bytes to Partition #3 -> 'SEC_EFS' File: ROM1_DUMP_SEC_EFS_0x000001800000_0x000001400000.bi n Path: C:\Users\jmr\Desktop\EmmcManager-1.20-19-03-2021\EmmcManager-1.20-19-03-2021\A21s new\ Write All Blocks Done! Count: 40960 Operation Done: [Write Partition], Elapsed: 00:00:05:032 Start Writing 0x000000800000 Bytes to Partition #5 -> 'CPEFS' File: ROM1_DUMP_CPEFS_0x000003000000_0x000000800000.bin Path: C:\Users\jmr\Desktop\EmmcManager-1.20-19-03-2021\EmmcManager-1.20-19-03-2021\A21s new\ Write All Blocks Done! Count: 16384 Operation Done: [Write Partition], Elapsed: 00:00:02:063 Session is Closed.. Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: OFF UFS Safe Mode: ON Init UFS Engine: 0/OK EasyJtag Plus S/N: 2EA1BDB9B5F74404 EasyJtag Plus Box FirmWare: 2.53.2 Box Hardware = EasyJtag 2nd Generation UFS: Socket Info: S/N: 0x0123B31A4A89358BEE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 02.04.20 Type: EasyJtag UFS Socket BGA-254 ID: 1625 UFS: Voltage Info: Mode: LOW VCC : 3204 mV, VCCQ2: 1912 mV 3v3 : 3320 mV, 1v2: 1207 mV UFS: Memory Info: Connection: Socket BGA-254 Vendor: SAMSUNG Name: KM5V7001DM-B621 S/N: 3caad1e4680c OEM ID: SAMSUNG_OEM_ID Firm Version: 9.00 UFS Version: 2.1 Size: 0x001DCC800000/119,20 GB Max LUNs: 8 LUNs Cnt: 6 W-LUNs Cnt: 1 LUNs ReConfig: Enabled UFS RPMB Info: RPMB Counter: 47444 UFS Health Info: UFS Life Time A: 0x01 -> 0% - 10% Life Time Used UFS Life Time B: 0x01 -> 0% - 10% Life Time Used UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks UFS: LUNs Info: LUN 0 -> Size: 30111744 Block(s)/114,87 GB LUN 1 (Boot A) -> Size: 2048 Block(s)/8,00 MB LUN 2 (Boot B) -> Size: 2048 Block(s)/8,00 MB LUN 3 -> Size: 8192 Block(s)/32,00 MB LUN 4 -> Size: 1048576 Block(s)/4,00 GB LUN 5 -> Size: 65536 Block(s)/256,00 MB W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16,00 MB UFS Init OK Scanning Data From UFS Chip. Please wait.. Scanning GUID Partition Table from LUN 0 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB GPT: SSD [000000006000 - 000000002000] Size: 8,00 KB GPT: PERSIST [000000008000 - 000002000000] Size: 32,00 MB GPT: MISC [000002008000 - 000000100000] Size: 1,00 MB GPT: KEYSTORE [000002108000 - 000000080000] Size: 512,00 KB GPT: FRP [000002188000 - 000000080000] Size: 512,00 KB GPT: CACHE [000002208000 - 000010000000] Size: 256,00 MB GPT: SYSTEM [000012208000 - 00018FC00000] Size: 6,25 GB GPT: METADATA [0001A1E08000 - 000001000000] Size: 16,00 MB GPT: ODM [0001A2E08000 - 000010000000] Size: 256,00 MB GPT: USERDATA [0001B2E08000 - 001B049F3000] Size: 108,07 GB GPT: BACKUP_GPT [001CB77FB000 - 000000005000] Size: 20,00 KB Reading Table Completed Scanning GUID Partition Table from LUN 1 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB GPT: XBL [000000006000 - 000000380000] Size: 3,50 MB GPT: XBL_CONFIG [000000386000 - 000000020000] Size: 128,00 KB GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4,33 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20,00 KB Reading Table Completed Scanning GUID Partition Table from LUN 2 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB GPT: XBLBAK [000000006000 - 000000380000] Size: 3,50 MB GPT: XBL_CONFIGBAK [000000386000 - 000000020000] Size: 128,00 KB GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4,33 MB GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20,00 KB Reading Table Completed Scanning GUID Partition Table from LUN 3 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104,00 KB GPT: CDT [000000020000 - 000000020000] Size: 128,00 KB GPT: DDR [000000040000 - 000000100000] Size: 1,00 MB GPT: LAST_PARTI [000000140000 - 000001EBB000] Size: 30,73 MB GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20,00 KB Reading Table Completed Scanning GUID Partition Table from LUN 4 GUID Partition Table is Found. Max Parts: 64 GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB GPT: RPM [000000006000 - 000000080000] Size: 512,00 KB GPT: TZ [000000086000 - 000000400000] Size: 4,00 MB GPT: HYP [000000486000 - 000000800000] Size: 8,00 MB GPT: MODEM [000000C86000 - 000010000000] Size: 256,00 MB GPT: BLUETOOTH [000010C86000 - 000000100000] Size: 1,00 MB GPT: MDTPSECAPP [000010D86000 - 000000400000] Size: 4,00 MB GPT: MDTP [000011186000 - 000002000000] Size: 32,00 MB GPT: ABL [000013186000 - 000000100000] Size: 1,00 MB GPT: DSP [000013286000 - 000004000000] Size: 64,00 MB GPT: KEYMASTER [000017286000 - 000000080000] Size: 512,00 KB GPT: BOOT [000017306000 - 000006000000] Size: 96,00 MB GPT: CMNLIB [00001D306000 - 000000080000] Size: 512,00 KB GPT: CMNLIB64 [00001D386000 - 000000080000] Size: 512,00 KB GPT: DEVCFG [00001D406000 - 000000020000] Size: 128,00 KB GPT: QUPFW [00001D426000 - 000000014000] Size: 80,00 KB GPT: VENDOR [00001D43A000 - 000064400000] Size: 1,57 GB GPT: VBMETA [00008183A000 - 000000010000] Size: 64,00 KB GPT: DTBO [00008184A000 - 000001800000] Size: 24,00 MB GPT: IMAGEFV [00008304A000 - 000000200000] Size: 2,00 MB GPT: UEFISECAPP [00008324A000 - 000000200000] Size: 2,00 MB GPT: RECOVERY [00008344A000 - 000004000000] Size: 64,00 MB GPT: OPPO_SEC [00008744A000 - 000000A00000] Size: 10,00 MB GPT: RPMBAK [000087E4A000 - 000000080000] Size: 512,00 KB GPT: TZBAK [000087ECA000 - 000000400000] Size: 4,00 MB GPT: HYPBAK [0000882CA000 - 000000800000] Size: 8,00 MB GPT: BLUETOOTHBAK [000088ACA000 - 000000100000] Size: 1,00 MB GPT: MDTPSECAPPBAK [000088BCA000 - 000000400000] Size: 4,00 MB GPT: MDTPBAK [000088FCA000 - 000002000000] Size: 32,00 MB GPT: ABLBAK [00008AFCA000 - 000000100000] Size: 1,00 MB GPT: DSPBAK [00008B0CA000 - 000004000000] Size: 64,00 MB GPT: KEYMASTERBAK [00008F0CA000 - 000000080000] Size: 512,00 KB GPT: BOOTBAK [00008F14A000 - 000006000000] Size: 96,00 MB GPT: CMNLIBBAK [00009514A000 - 000000080000] Size: 512,00 KB GPT: CMNLIB64BAK [0000951CA000 - 000000080000] Size: 512,00 KB GPT: DEVCFGBAK [00009524A000 - 000000020000] Size: 128,00 KB GPT: QUPFWBAK [00009526A000 - 000000014000] Size: 80,00 KB GPT: VBMETABAK [00009527E000 - 000000010000] Size: 64,00 KB GPT: DTBOBAK [00009528E000 - 000001800000] Size: 24,00 MB GPT: IMAGEFVBAK [000096A8E000 - 000000200000] Size: 2,00 MB GPT: UEFISECAPPBAK [000096C8E000 - 000000200000] Size: 2,00 MB GPT: RECOVERYBAK [000096E8E000 - 000004000000] Size: 64,00 MB GPT: DEVINFO [00009AE8E000 - 000000001000] Size: 4,00 KB GPT: DIP [00009AE8F000 - 000000100000] Size: 1,00 MB GPT: APDP [00009AF8F000 - 000000040000] Size: 256,00 KB GPT: SPUNVM [00009AFCF000 - 000000800000] Size: 8,00 MB GPT: SPLASH [00009B7CF000 - 0000020A4000] Size: 32,64 MB GPT: LIMITS [00009D873000 - 000000001000] Size: 4,00 KB GPT: TOOLSFV [00009D874000 - 000000100000] Size: 1,00 MB GPT: LOGFS [00009D974000 - 000000800000] Size: 8,00 MB GPT: CATELOADER [00009E174000 - 000000200000] Size: 2,00 MB GPT: RAWDUMP [00009E374000 - 000008000000] Size: 128,00 MB GPT: LOGDUMP [0000A6374000 - 000004000000] Size: 64,00 MB GPT: STORSEC [0000AA374000 - 000000020000] Size: 128,00 KB GPT: MULTIIMGOEM [0000AA394000 - 000000008000] Size: 32,00 KB GPT: MULTIIMGQTI [0000AA39C000 - 000000008000] Size: 32,00 KB GPT: UEFIVARSTORE [0000AA3A4000 - 000000080000] Size: 512,00 KB GPT: SECDATA [0000AA424000 - 000000007000] Size: 28,00 KB GPT: CATEFV [0000AA42B000 - 000000080000] Size: 512,00 KB GPT: CATECONTENTFV [0000AA4AB000 - 000000100000] Size: 1,00 MB GPT: LAST_PARTI [0000AA5AB000 - 000055A50000] Size: 1,34 GB GPT: BACKUP_GPT [0000FFFFB000 - 000000005000] Size: 20,00 KB Reading Table Completed Scanning GUID Partition Table from LUN 5 GUID Partition Table is Found. Max Parts: 32 GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104,00 KB GPT: OPPODYCNVBK [000000020000 - 000000A00000] Size: 10,00 MB GPT: OPPOSTANVBK [000000A20000 - 000000A00000] Size: 10,00 MB GPT: MODEMST1 [000001420000 - 000000200000] Size: 2,00 MB GPT: MODEMST2 [000001620000 - 000000200000] Size: 2,00 MB GPT: OPPORESERVE1 [000001820000 - 000000800000] Size: 8,00 MB GPT: OPPORESERVE2 [000002020000 - 000004000000] Size: 64,00 MB GPT: OPPORESERVE3 [000006020000 - 000004000000] Size: 64,00 MB GPT: DRIVER [00000A020000 - 000002000000] Size: 32,00 MB GPT: FSG [00000C020000 - 000000200000] Size: 2,00 MB GPT: FSC [00000C220000 - 000000020000] Size: 128,00 KB GPT: LAST_PARTI [00000C240000 - 000003DBB000] Size: 61,73 MB GPT: BACKUP_GPT [00000FFFB000 - 000000005000] Size: 20,00 KB Reading Table Completed Reading Initial Data. Please Wait.. Error Reading Sector: 320, Count: 64, Err: -108/UNKN_ERR Try Again #1 Error Reading Sector: 320, Count: 64, Err: -102/UNKN_ERR Try Again #2 Error Reading Sector: 320, Count: 64, Err: -102/UNKN_ERR Try Again #3 Too Many Errors. Stopped. Err: -102/UNKN_ERR Error While Reading Data. Code: -102/UNKN_ERR Error While Scan Partitions. Scanner Shutdown.. Scanner Thread Terminated Elapsed: 00:02:01:284 Found 104 Partition(s).. Scan Done. Init Main Engine... Use EasyJtag UFS Device: KM5V7001DM-B621 Reader Engine Initialized.. 0/OK Source: EasyJtag Port [UFS] Power Mode: LOW Generation: GPT [QC/SAMS/BCM/INTEL/MTK] Config: 1001111111101111 Operation Done: [Init Engine], Elapsed: 00:00:00:078 Error While Switch LUN: -102 Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR Try Again #1 Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR Try Again #2 Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR Try Again #3 Too Many Errors. Stopped. Err: -700/UNKN_ERR Error While Switch LUN: -102 Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR Try Again #1 Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR Try Again #2 Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR Try Again #3 Too Many Errors. Stopped. Err: -700/UNKN_ERR |
10-29-2021, 07:50 | #238 (permalink) |
Freak Poster Join Date: Apr 2012 Location: KU.mahabad
Member: 1744310 Status: Offline Sonork: 100.1617232 Thanks Meter: 43 | Sbl_sw hello! I have problem with cpu of ufs phone ,after flashing in 9008 After wrong firmware flash SBL_SW changed and now stuck at 9008 and eng or stock firmware not any change. before :SBL_SW: 0x0000000000000001 after :SBL_SW: 0x0000000000000003 Xiaomi Poco X3 nfc(surya) some log in easyjtag Connection with Sahara was successful Serial: 0x0000000026BB23BF HW_ID: 0x000E60E100720000 HASH: 0x1BEBE3863A6781DB4B01086063007334DE9E5CA14971C7C4 F4358EC9D79CDA46 SBL_SW: 0x0000000000000003 CPU: Qualcomm Mobile Platform 730 (SM7150) (Xiaomi Auth connect) Operation: Connect to Qualcomm HS-USB QDLoader 9008 Search Qualcomm HS-USB QDLoader 9008 devices ... Qualcomm HS-USB QDLoader 9008 (COM68) is found Connect to Sahara ... Did not receive Sahara hello packet from device Sahara not responding Trying to connect with Firehose UFS NAME: KM2V8001CM-B707 Vendor: SAMSUNG Serial: 4D53554E UFS LUN0 Capacity: 117656 MB (0x001CB9800000) UFS LUN1 Capacity: 8192 KB (0x000000800000) UFS LUN2 Capacity: 8192 KB (0x000000800000) UFS LUN3 Capacity: 128 MB (0x000008000000) UFS LUN4 Capacity: 4096 MB (0x000100000000) UFS LUN5 Capacity: 128 MB (0x000008000000) Connected successfully Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write) 10/29/2021 6:12:41 AM> Scanning soft partitions from LUN0 10/29/2021 6:12:41 AM> GPT header is found Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT Partition: ssd, [000000006000 - 000000008000], Size: 000000002000 (8.00 KB), Type: Raw Partition: persist, [000000008000 - 000002008000], Size: 000002000000 (32.00 MB), Type: Linux (/persist) Partition: misc, [000002008000 - 000002108000], Size: 000000100000 (1.00 MB), Type: Blank Partition: keystore, [000002108000 - 000002188000], Size: 000000080000 (512.00 KB), Type: Blank Partition: frp, [000002188000 - 000002208000], Size: 000000080000 (512.00 KB), Type: Blank Partition: minidump, [000002208000 - 00000A208000], Size: 000008000000 (128.00 MB), Type: Raw Partition: cust, [00000A208000 - 00004A208000], Size: 000040000000 (1.00 GB), Type: Linux (/cust) Partition: recovery, [00004A208000 - 000052208000], Size: 000008000000 (128.00 MB), Type: Boot Partition: vbmeta_system, [000052208000 - 000052218000], Size: 000000010000 (64.00 KB), Type: Raw Partition: metadata, [000052218000 - 000053218000], Size: 000001000000 (16.00 MB), Type: Linux (/metadata) Partition: cache, [000053218000 - 00006B218000], Size: 000018000000 (384.00 MB), Type: Linux (/cache) Partition: exaid, [00006B218000 - 000083218000], Size: 000018000000 (384.00 MB), Type: Blank Partition: gsort, [000083218000 - 000084218000], Size: 000001000000 (16.00 MB), Type: Raw Partition: ffu, [000084218000 - 000084A18000], Size: 000000800000 (8.00 MB), Type: Blank Partition: super, [000084A18000 - 000284A18000], Size: 000200000000 (8.00 GB), Type: Super Partition: system, [000084B18000 - 0000C3F3B000], Size: 00003F423000 (1012.14 MB), Type: Linux Partition: product, [0000C4018000 - 0000DCE34000], Size: 000018E1C000 (398.11 MB), Type: Linux Partition: vendor, [0000DCF18000 - 000103892000], Size: 00002697A000 (617.48 MB), Type: Linux Partition: userdata, [000284A18000 - 000DD47FB000], Size: 000B4FDE3000 (45.25 GB), Type: Raw Partition: BackupGPT, [001CB97FB000 - 001CB9800000], Size: 000000005000 (20.00 KB), Type: BackupGPT GPT header successfully parsed Scanning soft partitions from LUN1 GPT header is found Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT Partition: xbl, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw Partition: xbl_config, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT GPT header successfully parsed Scanning soft partitions from LUN2 GPT header is found Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT Partition: xblbak, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw Partition: xbl_configbak, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT GPT header successfully parsed Scanning soft partitions from LUN3 GPT header is found Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT Partition: ALIGN_TO_128K_1, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank Partition: cdt, [000000020000 - 000000040000], Size: 000000020000 (128.00 KB), Type: Raw Partition: ddr, [000000040000 - 000000140000], Size: 000000100000 (1.00 MB), Type: Raw Partition: last_parti, [000000140000 - 000007FFB000], Size: 000007EBB000 (126.73 MB), Type: Blank Partition: BackupGPT, [000007FFB000 - 000008000000], Size: 000000005000 (20.00 KB), Type: BackupGPT GPT header successfully parsed Scanning soft partitions from LUN4 GPT header is found Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT Partition: aop, [000000006000 - 000000086000], Size: 000000080000 (512.00 KB), Type: Raw Partition: tz, [000000086000 - 000000486000], Size: 000000400000 (4.00 MB), Type: Raw Partition: hyp, [000000486000 - 000000506000], Size: 000000080000 (512.00 KB), Type: Raw Partition: modem, [000000506000 - 000010506000], Size: 000010000000 (256.00 MB), Type: Fat16 Partition: bluetooth, [000010506000 - 000010606000], Size: 000000100000 (1.00 MB), Type: Fat16 Partition: mdtpsecapp, [000010606000 - 000010A06000], Size: 000000400000 (4.00 MB), Type: Blank Partition: mdtp, [000010A06000 - 000012A06000], Size: 000002000000 (32.00 MB), Type: Blank Partition: abl, [000012A06000 - 000013206000], Size: 000000800000 (8.00 MB), Type: Raw Partition: dsp, [000013206000 - 000015206000], Size: 000002000000 (32.00 MB), Type: Linux Partition: keymaster, [000015206000 - 000015286000], Size: 000000080000 (512.00 KB), Type: Raw Partition: cmnlib, [000015286000 - 000015306000], Size: 000000080000 (512.00 KB), Type: Raw Partition: cmnlib64, [000015306000 - 000015386000], Size: 000000080000 (512.00 KB), Type: Raw Partition: devcfg, [000015386000 - 0000153A6000], Size: 000000020000 (128.00 KB), Type: Raw Partition: qupfw, [0000153A6000 - 0000153B6000], Size: 000000010000 (64.00 KB), Type: Raw Partition: imagefv, [0000153B6000 - 0000155B6000], Size: 000000200000 (2.00 MB), Type: Raw Partition: uefisecapp, [0000155B6000 - 0000157B6000], Size: 000000200000 (2.00 MB), Type: Raw Partition: aopbak, [0000157B6000 - 000015836000], Size: 000000080000 (512.00 KB), Type: Raw Partition: tzbak, [000015836000 - 000015C36000], Size: 000000400000 (4.00 MB), Type: Raw Partition: hypbak, [000015C36000 - 000015CB6000], Size: 000000080000 (512.00 KB), Type: Raw Partition: mdtpsecappbak, [000015CB6000 - 0000160B6000], Size: 000000400000 (4.00 MB), Type: Blank Partition: mdtpbak, [0000160B6000 - 0000180B6000], Size: 000002000000 (32.00 MB), Type: Blank Partition: ablbak, [0000180B6000 - 0000188B6000], Size: 000000800000 (8.00 MB), Type: Raw Partition: keymasterbak, [0000188B6000 - 000018936000], Size: 000000080000 (512.00 KB), Type: Raw Partition: cmnlibbak, [000018936000 - 0000189B6000], Size: 000000080000 (512.00 KB), Type: Raw Partition: cmnlib64bak, [0000189B6000 - 000018A36000], Size: 000000080000 (512.00 KB), Type: Raw Partition: imagefvbak, [000018A36000 - 000018C36000], Size: 000000200000 (2.00 MB), Type: Raw Partition: uefisecappbak, [000018C36000 - 000018E36000], Size: 000000200000 (2.00 MB), Type: Raw Partition: devinfo, [000018E36000 - 000018E37000], Size: 000000001000 (4.00 KB), Type: Raw Partition: dip, [000018E37000 - 000018F37000], Size: 000000100000 (1.00 MB), Type: Blank Partition: apdp, [000018F37000 - 000018F77000], Size: 000000040000 (256.00 KB), Type: Blank Partition: spunvm, [000018F77000 - 000019777000], Size: 000000800000 (8.00 MB), Type: Blank Partition: splash, [000019777000 - 00001B81B000], Size: 0000020A4000 (32.64 MB), Type: Blank Partition: limits, [00001B81B000 - 00001B81C000], Size: 000000001000 (4.00 KB), Type: Raw Partition: toolsfv, [00001B81C000 - 00001B91C000], Size: 000000100000 (1.00 MB), Type: Blank Partition: logfs, [00001B91C000 - 00001C11C000], Size: 000000800000 (8.00 MB), Type: Fat12 Partition: cateloader, [00001C11C000 - 00001C31C000], Size: 000000200000 (2.00 MB), Type: Blank Partition: logdump, [00001C31C000 - 00002031C000], Size: 000004000000 (64.00 MB), Type: Blank Partition: storsec, [00002031C000 - 00002033C000], Size: 000000020000 (128.00 KB), Type: Raw Partition: multiimgoem, [00002033C000 - 000020344000], Size: 000000008000 (32.00 KB), Type: Raw Partition: multiimgqti, [000020344000 - 00002034C000], Size: 000000008000 (32.00 KB), Type: Raw Partition: uefivarstore, [00002034C000 - 0000203CC000], Size: 000000080000 (512.00 KB), Type: Raw Partition: secdata, [0000203CC000 - 0000203D3000], Size: 000000007000 (28.00 KB), Type: Raw Partition: catefv, [0000203D3000 - 000020453000], Size: 000000080000 (512.00 KB), Type: Blank Partition: catecontentfv, [000020453000 - 000020553000], Size: 000000100000 (1.00 MB), Type: Blank Partition: vbmeta, [000020553000 - 000020563000], Size: 000000010000 (64.00 KB), Type: Raw Partition: boot, [000020563000 - 000028563000], Size: 000008000000 (128.00 MB), Type: Boot Partition: dtbo, [000028563000 - 000029D63000], Size: 000001800000 (24.00 MB), Type: Raw Partition: last_parti, [000029D63000 - 0000FFFFB000], Size: 0000D6298000 (3.35 GB), Type: Raw Partition: BackupGPT, [0000FFFFB000 - 000100000000], Size: 000000005000 (20.00 KB), Type: BackupGPT GPT header successfully parsed Scanning soft partitions from LUN5 GPT header is found Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT Partition: ALIGN_TO_128K_2, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Raw Partition: modemst1, [000000020000 - 000000220000], Size: 000000200000 (2.00 MB), Type: Raw Partition: modemst2, [000000220000 - 000000420000], Size: 000000200000 (2.00 MB), Type: Raw Partition: fsg, [000000420000 - 000000E20000], Size: 000000A00000 (10.00 MB), Type: Raw Partition: fsc, [000000E20000 - 000000E40000], Size: 000000020000 (128.00 KB), Type: Blank Partition: last_parti, [000000E40000 - 000007FFB000], Size: 0000071BB000 (113.73 MB), Type: Blank Partition: BackupGPT, [000007FFB000 - 000008000000], Size: 000000005000 (20.00 KB), Type: BackupGPT GPT header successfully parsed |
11-26-2021, 21:38 | #239 (permalink) |
Freak Poster Join Date: Dec 2008 Location: iran
Member: 925389 Status: Offline Thanks Meter: 32 | Hi. I want to change lg H860 and H990 ufs chip.i didnt finde same skhinix chip.now i want to use samsung chip.please helpe me how can i config new ufs chip.thanks |
12-09-2021, 06:57 | #240 (permalink) |
Freak Poster Join Date: Aug 2014 Location: south africa
Member: 2243017 Status: Offline Thanks Meter: 28 | hi team i bought z3x jtag plus lite package.i am trying to connect emmc with isp.it always give me error .cant init cmd error.i try 5 working phones but i still get sam cmd error.i want to know if it jtag adopter or something else .5 adopters cam with box.please help me to solve problem |
