Old 05-15-2021, 09:25   #226 (permalink)
Member: 2947512
Sonork: 213123213
Running EasyJtag UFS Mode...
UFS ISP Mode: OFF
UFS Safe Mode: ON
Initialize UFS Engine Fail. Code: -51/ERROR_UFS_BOX_INIT_NO_SOCKET
Scanner Thread Terminated
Elapsed: 00:00:00:227
Found 0 Partition(s)..
Search Partitions Fail..
Check Socket/UFS Chip and Try Again..
Old 05-15-2021, 11:07   #227 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
you socket not-licensed, without cryptochip
you need buy licensed socket
Old 05-29-2021, 01:06   #228 (permalink)
Member: 2270536
i have this problem
can't open link, code: -51, reason: box: socket not detected
Old 06-19-2021, 11:32   #229 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Originally Posted by mauriciou View Post
i have this problem
please, read my previous answer:
https://forum.gsmhosting.com/vbb/f67...l#post14393380
Old 06-21-2021, 09:30   #230 (permalink)
Member: 2982753
Hello My Friend
I need vcc and vccq2 for this model (n960f)
please help me.
now i have a error: Can't init device. Error: -1. Reason: CMD Timeout Error - z3x easy jtag
Old 06-25-2021, 21:25   #231 (permalink)
SeharH's Avatar
Member: 2753718
Sonork: FB : MH Unlocker Pro
Thanks Meter: 811
Originally Posted by strefagsm1 View Post
Hello My Friend
please help me.
this is UFS device bro use ufs connections and configuration for connect this device...and no need vcc and vccq for it while usb inserted
BR.
SeharH
Old 07-11-2021, 18:10   #232 (permalink)
Member: 1763808
Thanks Meter: 2
I repaired many G935f (S7 Edge) phones with easyjtag+ufs adaptor but one of them has unknown baseband and i try everything for that then i decide change to a new dump but only lun0 is writable and all other LUNs are PROTECTED.
Is there any way to wipe and write those LUNs ?
Is this chip okay to use on another phone or its wasted ?
Before turning on phone chip was not OTP and phone makes chip OTP
Like EMMCs that after turning on phone RPMB will program
Am i right ?
Old 07-12-2021, 11:38   #233 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Am i right ?
for repair basebnd you need use orirgignal EFS partition or use Slmsung TGool SW to path IMEI, if this function abailable for this device
OTP config is closed on many chips, and this chips can not be reconfigured LUN size or type
some UFS chips have configured at WLUN partition read only areas at LUNs
The Following User Says Thank You to layder For This Useful Post:
Old 07-16-2021, 14:36   #234 (permalink)
Mehdi mohamadi's Avatar
Member: 652684
Thanks Meter: 20
is there any way to unlock otp config close on some ufs chip
i have 20 secend hand chip with otp lock and i cant confiq again for use another phone
fw ufs on new update can not help me.
Is there a solution in the future?
Old 07-16-2021, 14:36   #235 (permalink)
Member: 652684
Thanks Meter: 20
It was typed twice
Why
Old 07-18-2021, 18:15   #236 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
OTP - One Time Programmed function
you can not change it
Old 07-18-2021, 19:51   #237 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
Source: EasyJtag Port [EMMC/SD/MMC]
Generation: GPT [QC/SAMS/BCM/INTEL/MTK]
Box Voltage set to: 2800 mV
Scanner Thread Created..
Config: 1001111111101111
Setup HiPower CLK: OFF
Connecting To EasyJtag Plus Box: 2800mV/36MHz/1BIT
EasyJtag Plus Box Found! Result: 0/OK
CMD Pullup Level: 2041 mV
CMD Active Level: 2215 mV
EasyJtag Plus S/N: 2EA1BDB9B5F74404
EasyJtag Plus Box FirmWare: 2.53.2
Box Bus Width = 1 BIT
Box Hardware = EasyJtag 2nd Generation
Search Emmc Chip...
EMMC Chip Found! 0/OK
EMMC CID: 150100444836444142027904C4B1C541
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D
EMMC VENDOR: SAMSUNG
EMMC NAME: DH6DAB
EMMC DATE: 12/2018
EMMC SERIAL: 7904C4B1
EMMC REVISION: 02
EMMC ROM1 Size: 122142720 Block(s)/59640 MB
EMMC ROM2/3 Size: 8192 Block(s)/4096 KB
EMMC RPMB Size: 32768 Block(s)/16384 KB
EMMC RPMB Counter: 463, State: Dirty
EMMC RPMB Answer: 0/OK
Switch To ROM1 Part: 0/OK
EMMC REV: 1.8 (for MMC v5.1)
EMMC VER: MMC 5.1
EMMC DEV Life Time: 0x01 -> Normal
EMMC MLC Life Time: 0x01 -> 0% - 10% Life Time Used
EMMC SLC Life Time: 0x01 -> 0% - 10% Life Time Used
EMMC Boot Config: 0x48/0x01/0x01
ExtCSD Automatically Saved..
Scanning Data From EMMC. Please wait..
Scanning GUID Partition Table from ROM1
GUID Partition Table is Found. Max Parts: 128
GPT: GPT [000000000000 - 000000004400] Size: 17,00 KB
GPT: EFS [000000400000 - 000001400000] Size: 20,00 MB
GPT: SEC_EFS [000001800000 - 000001400000] Size: 20,00 MB
GPT: RESERVED [000002C00000 - 000000400000] Size: 4,00 MB
GPT: CPEFS [000003000000 - 000000800000] Size: 8,00 MB
GPT: STEADY [000003800000 - 000000400000] Size: 4,00 MB
GPT: PARAM [000003C00000 - 000000800000] Size: 8,00 MB
GPT: BOTA [000004400000 - 000002400000] Size: 36,00 MB
GPT: LDFW [000006800000 - 000000800000] Size: 8,00 MB
GPT: TZSW [000007000000 - 000000180000] Size: 1,50 MB
GPT: TZAR [000007180000 - 000000680000] Size: 6,50 MB
GPT: KEYSTORAGE [000007800000 - 000000080000] Size: 512,00 KB
GPT: NAD_REFER [000007880000 - 000000100000] Size: 1,00 MB
GPT: UP_PARAM [000007980000 - 000000800000] Size: 8,00 MB
GPT: MISC [000008180000 - 000000200000] Size: 2,00 MB
GPT: UH [000008380000 - 000000200000] Size: 2,00 MB
GPT: UHCFG [000008580000 - 000000400000] Size: 4,00 MB
GPT: BLCMD [000008980000 - 000000080000] Size: 512,00 KB
GPT: BOOT [000008A00000 - 000002400000] Size: 36,00 MB
GPT: RECOVERY [00000AE00000 - 000003500000] Size: 53,00 MB
GPT: DTB [00000E300000 - 000000800000] Size: 8,00 MB
GPT: DTBO [00000EB00000 - 000000800000] Size: 8,00 MB
GPT: RADIO [00000F300000 - 000003200000] Size: 50,00 MB
GPT: PERSISTENT [000012500000 - 000000080000] Size: 512,00 KB
GPT: VBMETA [000012580000 - 000000080000] Size: 512,00 KB
GPT: VBMETA_SAMSUNG [000012600000 - 000000080000] Size: 512,00 KB
GPT: KEYREFUGE [000012680000 - 000001000000] Size: 16,00 MB
GPT: KEYDATA [000013680000 - 000001000000] Size: 16,00 MB
GPT: METADATA [000014680000 - 000002000000] Size: 32,00 MB
GPT: RESERVED2 [000016680000 - 000000180000] Size: 1,50 MB
GPT: SUPER [000016800000 - 00014B400000] Size: 5,18 GB
GPT: PRISM [000161C00000 - 000032000000] Size: 800,00 MB
GPT: OPTICS [000193C00000 - 000001400000] Size: 20,00 MB
GPT: CACHE [000195000000 - 00000C800000] Size: 200,00 MB
GPT: OMR [0001A1800000 - 000001400000] Size: 20,00 MB
GPT: CP_DEBUG [0001A2C00000 - 000000500000] Size: 5,00 MB
GPT: SPU [0001A3100000 - 000003200000] Size: 50,00 MB
GPT: USERDATA [0001A6300000 - 000CE9000000] Size: 51,64 GB
GPT: BACKUP_GPT [000E8F7FBE00 - 000000004200] Size: 16,50 KB
Reading Table Completed
Scanning GUID Partition Table from ROM2
GPT Signature Not Found. Break..
Scanning GUID Partition Table from ROM3
Reading Initial Data. Please Wait..
Partition #3 - [SEC_EFS] mount as [/efs] -> 20,00 MB, Type: EXT4
Partition #27 - [KEYREFUGE] mount as [/keyrefuge] -> 16,00 MB, Type: EXT4
Partition #28 - [KEYDATA] mount as [/keydata] -> 16,00 MB, Type: EXT4
Partition #29 - [METADATA] mount as [/metadata] -> 32,00 MB, Type: EXT4
Partition #32 - [PRISM] mount as [/prism] -> 800,00 MB, Type: EXT4
Partition #33 - [OPTICS] mount as [/optics] -> 20,00 MB, Type: EXT4
Partition #34 - [CACHE] mount as [/cache] -> 200,00 MB, Type: EXT4
Partition #35 - [OMR] mount as [/omr] -> 20,00 MB, Type: EXT4
Partition #38 - [USERDATA] mount as [/USERDATA] -> 51,64 GB, Type: F2FS
EmptyCheck:
EMPTY -> ROM_1 -> Part #2 - [EFS]
EMPTY -> ROM_1 -> Part #4 - [RESERVED]
EMPTY -> ROM_1 -> Part #5 - [CPEFS]
EMPTY -> ROM_1 -> Part #8 - [BOTA]
EMPTY -> ROM_1 -> Part #13 - [NAD_REFER]
EMPTY -> ROM_1 -> Part #15 - [MISC]
EMPTY -> ROM_1 -> Part #16 - [UH]
EMPTY -> ROM_1 -> Part #17 - [UHCFG]
EMPTY -> ROM_1 -> Part #18 - [BLCMD]
EMPTY -> ROM_1 -> Part #21 - [DTB]
EMPTY -> ROM_1 -> Part #30 - [RESERVED2]
EMPTY -> ROM_1 -> Part #37 - [SPU]
EmptyCheck: Done
Samsung S/N = RF8R31QE96W
Elapsed: 00:00:06:695
Found 39 Partition(s)..
Scan Done. Init Main Engine...
Resetting EasyJtag Box. Wait..
CMD Pullup Level: 2039 mV
CMD Active Level: 2214 mV
Reader Engine Initialized.. 0/OK
Bus Mode: 1BIT
Operation Done: [Init Engine], Elapsed: 00:00:01:500
Start Writing 0x000001400000 Bytes to Partition #2 -> 'EFS'
File: ROM1_DUMP_EFS_0x000000400000_0x000001400000.bin
Path: C:\Users\jmr\Desktop\EmmcManager-1.20-19-03-2021\EmmcManager-1.20-19-03-2021\A21s new\
Write All Blocks Done! Count: 40960
Operation Done: [Write Partition], Elapsed: 00:00:05:079
Start Writing 0x000001400000 Bytes to Partition #3 -> 'SEC_EFS'
File: ROM1_DUMP_SEC_EFS_0x000001800000_0x000001400000.bi n
Operation Done: [Write Partition], Elapsed: 00:00:05:032
Start Writing 0x000000800000 Bytes to Partition #5 -> 'CPEFS'
File: ROM1_DUMP_CPEFS_0x000003000000_0x000000800000.bin
Write All Blocks Done! Count: 16384
Operation Done: [Write Partition], Elapsed: 00:00:02:063
Session is Closed..
Source: EasyJtag Port [UFS]
UFS Power Mode: LOW
UFS ISP Mode: OFF
UFS Safe Mode: ON
Init UFS Engine: 0/OK
UFS: Socket Info:
S/N: 0x0123B31A4A89358BEE
Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 02.04.20
Type: EasyJtag UFS Socket BGA-254
UFS: Voltage Info:
Mode: LOW
VCC : 3204 mV, VCCQ2: 1912 mV
3v3 : 3320 mV, 1v2: 1207 mV
UFS: Memory Info:
Connection: Socket BGA-254
Vendor: SAMSUNG
S/N: 3caad1e4680c
OEM ID: SAMSUNG_OEM_ID
Firm Version: 9.00
UFS Version: 2.1
Max LUNs: 8
LUNs Cnt: 6
W-LUNs Cnt: 1
LUNs ReConfig: Enabled
UFS RPMB Info:
RPMB Counter: 47444
UFS Health Info:
UFS Life Time A: 0x01 -> 0% - 10% Life Time Used
UFS Life Time B: 0x01 -> 0% - 10% Life Time Used
UFS Pre-EOL Info: 0x01 -> Used Less 80% of Reserved Blocks
UFS: LUNs Info:
LUN 0 -> Size: 30111744 Block(s)/114,87 GB
LUN 1 (Boot A) -> Size: 2048 Block(s)/8,00 MB
LUN 2 (Boot B) -> Size: 2048 Block(s)/8,00 MB
LUN 3 -> Size: 8192 Block(s)/32,00 MB
LUN 4 -> Size: 1048576 Block(s)/4,00 GB
LUN 5 -> Size: 65536 Block(s)/256,00 MB
W-LUN 0xC4 (RPMB) -> Size: 65536 Block(s)/16,00 MB
UFS Init OK
Scanning Data From UFS Chip. Please wait..
Scanning GUID Partition Table from LUN 0
GUID Partition Table is Found. Max Parts: 32
GPT: GPT [000000000000 - 000000006000] Size: 24,00 KB
GPT: SSD [000000006000 - 000000002000] Size: 8,00 KB
GPT: PERSIST [000000008000 - 000002000000] Size: 32,00 MB
GPT: MISC [000002008000 - 000000100000] Size: 1,00 MB
GPT: KEYSTORE [000002108000 - 000000080000] Size: 512,00 KB
GPT: FRP [000002188000 - 000000080000] Size: 512,00 KB
GPT: CACHE [000002208000 - 000010000000] Size: 256,00 MB
GPT: SYSTEM [000012208000 - 00018FC00000] Size: 6,25 GB
GPT: METADATA [0001A1E08000 - 000001000000] Size: 16,00 MB
GPT: ODM [0001A2E08000 - 000010000000] Size: 256,00 MB
GPT: USERDATA [0001B2E08000 - 001B049F3000] Size: 108,07 GB
GPT: BACKUP_GPT [001CB77FB000 - 000000005000] Size: 20,00 KB
Scanning GUID Partition Table from LUN 1
GPT: XBL [000000006000 - 000000380000] Size: 3,50 MB
GPT: XBL_CONFIG [000000386000 - 000000020000] Size: 128,00 KB
GPT: LAST_PARTI [0000003A6000 - 000000455000] Size: 4,33 MB
GPT: BACKUP_GPT [0000007FB000 - 000000005000] Size: 20,00 KB
Scanning GUID Partition Table from LUN 2
GPT: XBLBAK [000000006000 - 000000380000] Size: 3,50 MB
GPT: XBL_CONFIGBAK [000000386000 - 000000020000] Size: 128,00 KB
Scanning GUID Partition Table from LUN 3
GPT: ALIGN_TO_128K_1 [000000006000 - 00000001A000] Size: 104,00 KB
GPT: CDT [000000020000 - 000000020000] Size: 128,00 KB
GPT: DDR [000000040000 - 000000100000] Size: 1,00 MB
GPT: LAST_PARTI [000000140000 - 000001EBB000] Size: 30,73 MB
GPT: BACKUP_GPT [000001FFB000 - 000000005000] Size: 20,00 KB
Scanning GUID Partition Table from LUN 4
GUID Partition Table is Found. Max Parts: 64
GPT: RPM [000000006000 - 000000080000] Size: 512,00 KB
GPT: TZ [000000086000 - 000000400000] Size: 4,00 MB
GPT: HYP [000000486000 - 000000800000] Size: 8,00 MB
GPT: MODEM [000000C86000 - 000010000000] Size: 256,00 MB
GPT: BLUETOOTH [000010C86000 - 000000100000] Size: 1,00 MB
GPT: MDTPSECAPP [000010D86000 - 000000400000] Size: 4,00 MB
GPT: MDTP [000011186000 - 000002000000] Size: 32,00 MB
GPT: ABL [000013186000 - 000000100000] Size: 1,00 MB
GPT: DSP [000013286000 - 000004000000] Size: 64,00 MB
GPT: KEYMASTER [000017286000 - 000000080000] Size: 512,00 KB
GPT: BOOT [000017306000 - 000006000000] Size: 96,00 MB
GPT: CMNLIB [00001D306000 - 000000080000] Size: 512,00 KB
GPT: CMNLIB64 [00001D386000 - 000000080000] Size: 512,00 KB
GPT: DEVCFG [00001D406000 - 000000020000] Size: 128,00 KB
GPT: QUPFW [00001D426000 - 000000014000] Size: 80,00 KB
GPT: VENDOR [00001D43A000 - 000064400000] Size: 1,57 GB
GPT: VBMETA [00008183A000 - 000000010000] Size: 64,00 KB
GPT: DTBO [00008184A000 - 000001800000] Size: 24,00 MB
GPT: IMAGEFV [00008304A000 - 000000200000] Size: 2,00 MB
GPT: UEFISECAPP [00008324A000 - 000000200000] Size: 2,00 MB
GPT: RECOVERY [00008344A000 - 000004000000] Size: 64,00 MB
GPT: OPPO_SEC [00008744A000 - 000000A00000] Size: 10,00 MB
GPT: RPMBAK [000087E4A000 - 000000080000] Size: 512,00 KB
GPT: TZBAK [000087ECA000 - 000000400000] Size: 4,00 MB
GPT: HYPBAK [0000882CA000 - 000000800000] Size: 8,00 MB
GPT: BLUETOOTHBAK [000088ACA000 - 000000100000] Size: 1,00 MB
GPT: MDTPSECAPPBAK [000088BCA000 - 000000400000] Size: 4,00 MB
GPT: MDTPBAK [000088FCA000 - 000002000000] Size: 32,00 MB
GPT: ABLBAK [00008AFCA000 - 000000100000] Size: 1,00 MB
GPT: DSPBAK [00008B0CA000 - 000004000000] Size: 64,00 MB
GPT: KEYMASTERBAK [00008F0CA000 - 000000080000] Size: 512,00 KB
GPT: BOOTBAK [00008F14A000 - 000006000000] Size: 96,00 MB
GPT: CMNLIBBAK [00009514A000 - 000000080000] Size: 512,00 KB
GPT: CMNLIB64BAK [0000951CA000 - 000000080000] Size: 512,00 KB
GPT: DEVCFGBAK [00009524A000 - 000000020000] Size: 128,00 KB
GPT: QUPFWBAK [00009526A000 - 000000014000] Size: 80,00 KB
GPT: VBMETABAK [00009527E000 - 000000010000] Size: 64,00 KB
GPT: DTBOBAK [00009528E000 - 000001800000] Size: 24,00 MB
GPT: IMAGEFVBAK [000096A8E000 - 000000200000] Size: 2,00 MB
GPT: UEFISECAPPBAK [000096C8E000 - 000000200000] Size: 2,00 MB
GPT: RECOVERYBAK [000096E8E000 - 000004000000] Size: 64,00 MB
GPT: DEVINFO [00009AE8E000 - 000000001000] Size: 4,00 KB
GPT: DIP [00009AE8F000 - 000000100000] Size: 1,00 MB
GPT: APDP [00009AF8F000 - 000000040000] Size: 256,00 KB
GPT: SPUNVM [00009AFCF000 - 000000800000] Size: 8,00 MB
GPT: SPLASH [00009B7CF000 - 0000020A4000] Size: 32,64 MB
GPT: LIMITS [00009D873000 - 000000001000] Size: 4,00 KB
GPT: TOOLSFV [00009D874000 - 000000100000] Size: 1,00 MB
GPT: LOGFS [00009D974000 - 000000800000] Size: 8,00 MB
GPT: CATELOADER [00009E174000 - 000000200000] Size: 2,00 MB
GPT: RAWDUMP [00009E374000 - 000008000000] Size: 128,00 MB
GPT: LOGDUMP [0000A6374000 - 000004000000] Size: 64,00 MB
GPT: STORSEC [0000AA374000 - 000000020000] Size: 128,00 KB
GPT: MULTIIMGOEM [0000AA394000 - 000000008000] Size: 32,00 KB
GPT: MULTIIMGQTI [0000AA39C000 - 000000008000] Size: 32,00 KB
GPT: UEFIVARSTORE [0000AA3A4000 - 000000080000] Size: 512,00 KB
GPT: SECDATA [0000AA424000 - 000000007000] Size: 28,00 KB
GPT: CATEFV [0000AA42B000 - 000000080000] Size: 512,00 KB
GPT: CATECONTENTFV [0000AA4AB000 - 000000100000] Size: 1,00 MB
GPT: LAST_PARTI [0000AA5AB000 - 000055A50000] Size: 1,34 GB
GPT: BACKUP_GPT [0000FFFFB000 - 000000005000] Size: 20,00 KB
Scanning GUID Partition Table from LUN 5
GPT: ALIGN_TO_128K_2 [000000006000 - 00000001A000] Size: 104,00 KB
GPT: OPPODYCNVBK [000000020000 - 000000A00000] Size: 10,00 MB
GPT: OPPOSTANVBK [000000A20000 - 000000A00000] Size: 10,00 MB
GPT: MODEMST1 [000001420000 - 000000200000] Size: 2,00 MB
GPT: MODEMST2 [000001620000 - 000000200000] Size: 2,00 MB
GPT: OPPORESERVE1 [000001820000 - 000000800000] Size: 8,00 MB
GPT: OPPORESERVE2 [000002020000 - 000004000000] Size: 64,00 MB
GPT: OPPORESERVE3 [000006020000 - 000004000000] Size: 64,00 MB
GPT: DRIVER [00000A020000 - 000002000000] Size: 32,00 MB
GPT: FSG [00000C020000 - 000000200000] Size: 2,00 MB
GPT: FSC [00000C220000 - 000000020000] Size: 128,00 KB
GPT: LAST_PARTI [00000C240000 - 000003DBB000] Size: 61,73 MB
GPT: BACKUP_GPT [00000FFFB000 - 000000005000] Size: 20,00 KB
Error Reading Sector: 320, Count: 64, Err: -108/UNKN_ERR
Try Again #1
Error Reading Sector: 320, Count: 64, Err: -102/UNKN_ERR
Try Again #2
Try Again #3
Too Many Errors. Stopped. Err: -102/UNKN_ERR
Error While Reading Data. Code: -102/UNKN_ERR
Error While Scan Partitions. Scanner Shutdown..
Elapsed: 00:02:01:284
Found 104 Partition(s)..
Use EasyJtag UFS Device: KM5V7001DM-B621
Power Mode: LOW
Operation Done: [Init Engine], Elapsed: 00:00:00:078
Error While Switch LUN: -102
Error Reading Sector: 0, Count: 57, Err: -700/UNKN_ERR
Try Again #1
Try Again #2
Try Again #3
Too Many Errors. Stopped. Err: -700/UNKN_ERR
Error Reading Sector: 0, Count: 1, Err: -700/UNKN_ERR
Try Again #1
Try Again #2
Try Again #3
Old 10-29-2021, 07:50   #238 (permalink)
iArkAt8's Avatar
Member: 1744310
Sonork: 100.1617232
Thanks Meter: 43
Sbl_sw
hello! I have problem with cpu of ufs phone ,after flashing in 9008
After wrong firmware flash SBL_SW changed and now stuck at 9008 and eng or stock firmware not any change.
before :SBL_SW: 0x0000000000000001
after :SBL_SW: 0x0000000000000003
Xiaomi Poco X3 nfc(surya)
some log in easyjtag
Connection with Sahara was successful
Serial: 0x0000000026BB23BF
HW_ID: 0x000E60E100720000
HASH: 0x1BEBE3863A6781DB4B01086063007334DE9E5CA14971C7C4 F4358EC9D79CDA46
CPU: Qualcomm Mobile Platform 730 (SM7150)
(Xiaomi Auth connect)
Operation: Connect to Qualcomm HS-USB QDLoader 9008
Search Qualcomm HS-USB QDLoader 9008 devices ...
Qualcomm HS-USB QDLoader 9008 (COM68) is found
Connect to Sahara ...
Did not receive Sahara hello packet from device
Sahara not responding
Trying to connect with Firehose
UFS NAME: KM2V8001CM-B707 Vendor: SAMSUNG Serial: 4D53554E
UFS LUN0 Capacity: 117656 MB (0x001CB9800000)
UFS LUN1 Capacity: 8192 KB (0x000000800000)
UFS LUN2 Capacity: 8192 KB (0x000000800000)
UFS LUN3 Capacity: 128 MB (0x000008000000)
UFS LUN4 Capacity: 4096 MB (0x000100000000)
UFS LUN5 Capacity: 128 MB (0x000008000000)
Connected successfully
Operation: Scan PartitionTable from Source (Vendor: Binary Read/Write)
10/29/2021 6:12:41 AM> Scanning soft partitions from LUN0
10/29/2021 6:12:41 AM> GPT header is found
Partition: PrimaryGPT, [000000000000 - 000000006000], Size: 000000006000 (24.00 KB), Type: GPT
Partition: ssd, [000000006000 - 000000008000], Size: 000000002000 (8.00 KB), Type: Raw
Partition: persist, [000000008000 - 000002008000], Size: 000002000000 (32.00 MB), Type: Linux (/persist)
Partition: misc, [000002008000 - 000002108000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: keystore, [000002108000 - 000002188000], Size: 000000080000 (512.00 KB), Type: Blank
Partition: frp, [000002188000 - 000002208000], Size: 000000080000 (512.00 KB), Type: Blank
Partition: minidump, [000002208000 - 00000A208000], Size: 000008000000 (128.00 MB), Type: Raw
Partition: cust, [00000A208000 - 00004A208000], Size: 000040000000 (1.00 GB), Type: Linux (/cust)
Partition: recovery, [00004A208000 - 000052208000], Size: 000008000000 (128.00 MB), Type: Boot
Partition: vbmeta_system, [000052208000 - 000052218000], Size: 000000010000 (64.00 KB), Type: Raw
Partition: metadata, [000052218000 - 000053218000], Size: 000001000000 (16.00 MB), Type: Linux (/metadata)
Partition: cache, [000053218000 - 00006B218000], Size: 000018000000 (384.00 MB), Type: Linux (/cache)
Partition: exaid, [00006B218000 - 000083218000], Size: 000018000000 (384.00 MB), Type: Blank
Partition: gsort, [000083218000 - 000084218000], Size: 000001000000 (16.00 MB), Type: Raw
Partition: ffu, [000084218000 - 000084A18000], Size: 000000800000 (8.00 MB), Type: Blank
Partition: super, [000084A18000 - 000284A18000], Size: 000200000000 (8.00 GB), Type: Super
Partition: system, [000084B18000 - 0000C3F3B000], Size: 00003F423000 (1012.14 MB), Type: Linux
Partition: product, [0000C4018000 - 0000DCE34000], Size: 000018E1C000 (398.11 MB), Type: Linux
Partition: vendor, [0000DCF18000 - 000103892000], Size: 00002697A000 (617.48 MB), Type: Linux
Partition: userdata, [000284A18000 - 000DD47FB000], Size: 000B4FDE3000 (45.25 GB), Type: Raw
Partition: BackupGPT, [001CB97FB000 - 001CB9800000], Size: 000000005000 (20.00 KB), Type: BackupGPT
GPT header successfully parsed
Scanning soft partitions from LUN1
GPT header is found
Partition: xbl, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw
Partition: xbl_config, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: last_parti, [000000726000 - 0000007FB000], Size: 0000000D5000 (852.00 KB), Type: Blank
Partition: BackupGPT, [0000007FB000 - 000000800000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Scanning soft partitions from LUN2
GPT header is found
Partition: xblbak, [000000006000 - 000000706000], Size: 000000700000 (7.00 MB), Type: Raw
Partition: xbl_configbak, [000000706000 - 000000726000], Size: 000000020000 (128.00 KB), Type: Raw
Scanning soft partitions from LUN3
GPT header is found
Partition: ALIGN_TO_128K_1, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Blank
Partition: cdt, [000000020000 - 000000040000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: ddr, [000000040000 - 000000140000], Size: 000000100000 (1.00 MB), Type: Raw
Partition: last_parti, [000000140000 - 000007FFB000], Size: 000007EBB000 (126.73 MB), Type: Blank
Partition: BackupGPT, [000007FFB000 - 000008000000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Scanning soft partitions from LUN4
GPT header is found
Partition: aop, [000000006000 - 000000086000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: tz, [000000086000 - 000000486000], Size: 000000400000 (4.00 MB), Type: Raw
Partition: hyp, [000000486000 - 000000506000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: modem, [000000506000 - 000010506000], Size: 000010000000 (256.00 MB), Type: Fat16
Partition: bluetooth, [000010506000 - 000010606000], Size: 000000100000 (1.00 MB), Type: Fat16
Partition: mdtpsecapp, [000010606000 - 000010A06000], Size: 000000400000 (4.00 MB), Type: Blank
Partition: mdtp, [000010A06000 - 000012A06000], Size: 000002000000 (32.00 MB), Type: Blank
Partition: abl, [000012A06000 - 000013206000], Size: 000000800000 (8.00 MB), Type: Raw
Partition: dsp, [000013206000 - 000015206000], Size: 000002000000 (32.00 MB), Type: Linux
Partition: keymaster, [000015206000 - 000015286000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: cmnlib, [000015286000 - 000015306000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: cmnlib64, [000015306000 - 000015386000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: devcfg, [000015386000 - 0000153A6000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: qupfw, [0000153A6000 - 0000153B6000], Size: 000000010000 (64.00 KB), Type: Raw
Partition: imagefv, [0000153B6000 - 0000155B6000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: uefisecapp, [0000155B6000 - 0000157B6000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: aopbak, [0000157B6000 - 000015836000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: tzbak, [000015836000 - 000015C36000], Size: 000000400000 (4.00 MB), Type: Raw
Partition: hypbak, [000015C36000 - 000015CB6000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: mdtpsecappbak, [000015CB6000 - 0000160B6000], Size: 000000400000 (4.00 MB), Type: Blank
Partition: mdtpbak, [0000160B6000 - 0000180B6000], Size: 000002000000 (32.00 MB), Type: Blank
Partition: ablbak, [0000180B6000 - 0000188B6000], Size: 000000800000 (8.00 MB), Type: Raw
Partition: keymasterbak, [0000188B6000 - 000018936000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: cmnlibbak, [000018936000 - 0000189B6000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: cmnlib64bak, [0000189B6000 - 000018A36000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: imagefvbak, [000018A36000 - 000018C36000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: uefisecappbak, [000018C36000 - 000018E36000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: devinfo, [000018E36000 - 000018E37000], Size: 000000001000 (4.00 KB), Type: Raw
Partition: dip, [000018E37000 - 000018F37000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: apdp, [000018F37000 - 000018F77000], Size: 000000040000 (256.00 KB), Type: Blank
Partition: spunvm, [000018F77000 - 000019777000], Size: 000000800000 (8.00 MB), Type: Blank
Partition: splash, [000019777000 - 00001B81B000], Size: 0000020A4000 (32.64 MB), Type: Blank
Partition: limits, [00001B81B000 - 00001B81C000], Size: 000000001000 (4.00 KB), Type: Raw
Partition: toolsfv, [00001B81C000 - 00001B91C000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: logfs, [00001B91C000 - 00001C11C000], Size: 000000800000 (8.00 MB), Type: Fat12
Partition: cateloader, [00001C11C000 - 00001C31C000], Size: 000000200000 (2.00 MB), Type: Blank
Partition: logdump, [00001C31C000 - 00002031C000], Size: 000004000000 (64.00 MB), Type: Blank
Partition: storsec, [00002031C000 - 00002033C000], Size: 000000020000 (128.00 KB), Type: Raw
Partition: multiimgoem, [00002033C000 - 000020344000], Size: 000000008000 (32.00 KB), Type: Raw
Partition: multiimgqti, [000020344000 - 00002034C000], Size: 000000008000 (32.00 KB), Type: Raw
Partition: uefivarstore, [00002034C000 - 0000203CC000], Size: 000000080000 (512.00 KB), Type: Raw
Partition: secdata, [0000203CC000 - 0000203D3000], Size: 000000007000 (28.00 KB), Type: Raw
Partition: catefv, [0000203D3000 - 000020453000], Size: 000000080000 (512.00 KB), Type: Blank
Partition: catecontentfv, [000020453000 - 000020553000], Size: 000000100000 (1.00 MB), Type: Blank
Partition: vbmeta, [000020553000 - 000020563000], Size: 000000010000 (64.00 KB), Type: Raw
Partition: boot, [000020563000 - 000028563000], Size: 000008000000 (128.00 MB), Type: Boot
Partition: dtbo, [000028563000 - 000029D63000], Size: 000001800000 (24.00 MB), Type: Raw
Partition: last_parti, [000029D63000 - 0000FFFFB000], Size: 0000D6298000 (3.35 GB), Type: Raw
Partition: BackupGPT, [0000FFFFB000 - 000100000000], Size: 000000005000 (20.00 KB), Type: BackupGPT
Scanning soft partitions from LUN5
GPT header is found
Partition: ALIGN_TO_128K_2, [000000006000 - 000000020000], Size: 00000001A000 (104.00 KB), Type: Raw
Partition: modemst1, [000000020000 - 000000220000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: modemst2, [000000220000 - 000000420000], Size: 000000200000 (2.00 MB), Type: Raw
Partition: fsg, [000000420000 - 000000E20000], Size: 000000A00000 (10.00 MB), Type: Raw
Partition: fsc, [000000E20000 - 000000E40000], Size: 000000020000 (128.00 KB), Type: Blank
Partition: last_parti, [000000E40000 - 000007FFB000], Size: 0000071BB000 (113.73 MB), Type: Blank
Old 11-26-2021, 21:38   #239 (permalink)
Member: 925389
Thanks Meter: 32
Hi. I want to change lg H860 and H990 ufs chip.i didnt finde same skhinix chip.now i want to use samsung chip.please helpe me how can i config new ufs chip.thanks
Old 12-09-2021, 06:57   #240 (permalink)
Member: 2243017
Thanks Meter: 29
hi team i bought z3x jtag plus lite package.i am trying to connect emmc with isp.it always give me error .cant init cmd error.i try 5 working phones but i still get sam cmd error.i want to know if it jtag adopter or something else .5 adopters cam with box.please help me to solve problem
Page generated in 0.33386 seconds with 9 queries
