Old 01-11-2022, 01:24   #241 (permalink)
Member: 2185549
Thanks Meter: 535
UFS FAILED TO WRITE ANY PARTITION VIA EMMC MODULE
Operation: Connect to Z3X EasyJtagPlus
Setting Interface to EasyJtag2/UFS-Socket
Setting IO Levels to High
Setting Frequence to 66 Mhz
Socket Information :
Socket Mark: EasyJTAG UFS Socket BGA-254 by EasyJTAG 28.01.21
Socket Serial: 0123B2BACF15DFB8EE
Socket Type: UFS_SOCKET_BGA_254
UFS Power Information :
Mode: High, VCC: 3320 mV, VCCQ2: 1921 mV
UFS Device Information :
UFS Manufacturer: SAMSUNG, UFS ProductName: KLUDG4UHDB-B2D1
UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x42711DDD3B197EBD8EE222C4E68153414B503230304B
Maximum Number of LUs: 8, Number of LUs found: 5, Number of WLUs found: 1, LUs Re-configure: Enabled
RPMB Counter: 13683
UFS LUN 0 Capacity: 122008 MB (001DC9800000)
UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000)
UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000)
UFS LUN 3 Capacity: 8 MB (000000800000)
UFS LUN 4 Capacity: 16 MB (000001000000)
UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000)
Device Life Time Estimation B: 0x02 10% - 20% device life time used
Device Life Time Estimation A: 0x02 10% - 20% device life time used
Pre EOL information: 0x01 Normal (Consumed less then 80% of reserved block)
Do not turn the socket before you press "Close Session" button
Connected successfully
Operation: Reading by Vendor (Binary Read/Write)
Output Directory: C:\Users\DROID\Desktop\G980F\DUMP\
Reading: LUN 1 (Boot A), Offset: 0x000000000000, Size: 0x000000400000 (4.00 MB)
Output file: LUN 1 (Boot A)_000000000000_000000400000.bin
Reading partition...
Error: Previous operation is not finished yet
Error reading at address: 000000000000 , error: -205, Unknown error: -205 ... Retry #1
Error reading at address: 000000000000 , error: -205, Unknown error: -205 ... Retry #2
Error reading at address: 000000000000 , error: -205, Unknown error: -205 ... Retry #3
Too many errors. Reading has been stopped
Disconnected
Mode: High, VCC: 3321 mV, VCCQ2: 1922 mV
RPMB Counter: 13683
Operation: Scan PartitionTable from Source (Vendor: Samsung)
Scanning soft partitions from LUN 0
GPT header is found
Stopped by User request...
Operation: Opening Firmware (Samsung)
Firmware: PICASSO3_EUR_OPEN.pit
LUN 0: The size of the "USERDATA" partition has been increased
LUN 3: The size of the "CPEFS" partition has been increased
Opening firmware completed
Operation: Adding firmware files (Samsung)
BL_G980FXXSCEUL7_G980FXXSCEUL7_SCL23182177_VCL2318 0807_MCL23346697_SQB47543609_VQB47543610_MQB475435 95_REV01_user_low_ship_MULTI_CERT.tar.md5
List of files in the firmware:
sboot.bin.lz4
up_param.bin.lz4
ldfw.img.lz4
tzsw.img.lz4
tzar.img.lz4
keystorage.bin.lz4
ssp.img.lz4
uh.bin.lz4
vbmeta.img.lz4
harx.bin.lz4
Operation: Writing by Vendor (Samsung)
Write/Erase check: Disabled
Unpacking files into: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\
Unpacking : up_param.bin.lz4
Unpacking : keystorage.bin.lz4
Unpacking : harx.bin.lz4
Unpacking : uh.bin.lz4
Unpacking : uh.bin
Unpacking : vbmeta.img.lz4
Unpacking : sboot.bin.lz4
Unpacking : ldfw.img.lz4
Unpacking : tzsw.img.lz4
Unpacking : tzar.img.lz4
Unpacking : ssp.img.lz4
Unpacking : ssp.img
Unpacking done
Repartitioning ...
Rom: LUN 0, Part: PrimaryGPT, Address: 000000000000, Filename: From Memory
Rom: LUN 0, Part: BackupGPT, Address: 001DC97FB000, Filename: From Memory
Rom: LUN 3, Part: PrimaryGPT, Address: 000000000000, Filename: From Memory
Rom: LUN 3, Part: BackupGPT, Address: 0000007FB000, Filename: From Memory
Rom: LUN 0, Part: Pit, Address: 000000006000
Old 02-06-2022, 17:17   #242 (permalink)
gsmali40's Avatar
Member: 2707726
Sonork: 100.1675740
Thanks Meter: 132
Ashuganj Telecom contact with me 01749630640
iPhone Sim/Carrier Unlock (Gsm/Meid) iPhone 5S To X IOS To 14.8 Supported
Old 02-27-2022, 22:56   #243 (permalink)
alamgarh's Avatar
Member: 358694
Sonork: 100.1597323
Thanks Meter: 994
Originally Posted by layder View Post
you socket not-licensed, without cryptochip
you need buy licensed socket
Dear Sir where I can buy this socket with crypto chip
Old 03-10-2022, 07:26   #244 (permalink)
murad6229's Avatar
Member: 987131
Sonork: 100.1614852
Thanks Meter: 25
UFS Init Failed, error: 0
eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021)
Microsoft Windows 10 (64 bit) build 19044 (10.0.19041.1503)
Looking for EasyJTAG box...
EasyJTAG API ver. 3403
EasyJTAG Box Serial = XXXXXXXXXXX
Card Serial = XXXXXXXX
EasyJTAG Box Firmware = 2.5302
Changelog:
05.05.2021 (ver 1.6.6.0)
Add: New keys for Oppo unpack
Fix: Bugs that have been found through your crash report
05.05.2021 (ver 2.0.1.0)
Add: Vendor LG
Add: Mediatek Preloader Parser
Add: OnePlus Unpacker
Add: Xiaomi Custom EDL Authorization
Add: Xiaomi Remove Mi Account (only Qualcomm)
Setting interface to EasyJtag2/UFS
Old 03-10-2022, 07:29   #245 (permalink)
murad6229's Avatar
Member: 987131
Sonork: 100.1614852
Thanks Meter: 25
Initialize UFS Engine Fail. Code: -57/ERROR_UFS_BOX_INIT_LINK_T1
Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.09.20
Type: EasyJtag UFS Socket BGA-254
Scanner Thread Terminated
Elapsed: 00:00:00:704
Found 0 Partition(s)..
Search Partitions Fail..
Check Socket/UFS Chip and Try Again..
Old 03-10-2022, 07:30   #246 (permalink)
murad6229's Avatar
Member: 987131
Sonork: 100.1614852
Thanks Meter: 25
Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.09.20
Can't open link, Code: -57, Reason: BOX: Chip not connected
Done.
Old 04-09-2022, 20:28   #247 (permalink)
Member: 2723061
i need g973u isp pinout
Old 05-27-2022, 09:08   #248 (permalink)
Member: 2466919
Thanks Meter: 5
Can't open link, Code: -56, Reason: BOX: Chip not connected
easyjtag plus ufs socket isp error.
please solve this
Old 05-30-2022, 12:28   #249 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
please solve this
post logs, please, and describe situation
Old 06-01-2022, 09:52   #250 (permalink)
Member: 2466919
Thanks Meter: 5
BGA 254 UFS ISP connecting error
Done.
please splve this
Old 06-24-2022, 07:05   #251 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
Socket Mark: EasyJTAG UFS Socket 3 in 1 by MOORC 08.11.20
Socket Serial: 01237D77621C8B75EE
Socket Type: UFS_SOCKET_3_IN_1
Can't init device. Error: -57. Reason: BOX: UFS Box init link T1
Old 08-05-2022, 20:12   #252 (permalink)
Member: 2863121
Thanks Meter: 8
hello mr layder
you said you gonna make a post about ufs programing instructions we are waiting for it
please do it
thank you.
Old 08-05-2022, 22:54   #253 (permalink)
Member: 2863121
Thanks Meter: 8
Can't init device, Code: -112, Reason: Can't boot device
hello easy jtag team
there are many easy jtag users ask you the reason for getting the following error
when trying to identify ufs chip
please tell us what is the problem?
error log is below
Z3X EasyJtag Software ver. 3.7.0.24
UFS Safe Mode is disabled...
UFS Socket Info.
Serial: 01236612C25E4885EE
Description: EasyJTAG UFS Socket BGA-153 by EasyJTAG 22.05.21
Identify UFS Chip.
UFS Chip Voltage: Low
VCC: 3259mV
VCCQ2: 1837mV
Done.
Old 08-06-2022, 07:45   #254 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
error log is below
UFS Socket Info.
Identify UFS Chip.
VCC: 3259mV
VCCQ2: 1837mV
Done.
try to set High voltage, reball chip pins
at same log - chip is dead.
Old 08-06-2022, 09:53   #255 (permalink)
Member: 2863121
Thanks Meter: 8
i have done all you said and when i resolder this ufs the device turns on completely ufs chip is ok bro
and sometimes after pressing identify button several times it passes over this error which i mentioned but it gives new error(reading at adrress 0000000000 error)
Page generated in 0.29550 seconds with 10 queries
