01-11-2022, 01:24 | #241 (permalink) |
No Life Poster Join Date: May 2014 Location: UGANDA
Member: 2185549 Status: Online Thanks Meter: 535 | Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to High Setting Frequence to 66 Mhz Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-254 by EasyJTAG 28.01.21 Socket Serial: 0123B2BACF15DFB8EE Socket Type: UFS_SOCKET_BGA_254 UFS Power Information : Mode: High, VCC: 3320 mV, VCCQ2: 1921 mV UFS Device Information : UFS Manufacturer: SAMSUNG, UFS ProductName: KLUDG4UHDB-B2D1 UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x42711DDD3B197EBD8EE222C4E68153414B503230304B Maximum Number of LUs: 8, Number of LUs found: 5, Number of WLUs found: 1, LUs Re-configure: Enabled RPMB Counter: 13683 UFS LUN 0 Capacity: 122008 MB (001DC9800000) UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000) UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000) UFS LUN 3 Capacity: 8 MB (000000800000) UFS LUN 4 Capacity: 16 MB (000001000000) UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000) Device Life Time Estimation B: 0x02 10% - 20% device life time used Device Life Time Estimation A: 0x02 10% - 20% device life time used Pre EOL information: 0x01 Normal (Consumed less then 80% of reserved block) Do not turn the socket before you press "Close Session" button Connected successfully Operation: Reading by Vendor (Binary Read/Write) Output Directory: C:\Users\DROID\Desktop\G980F\DUMP\ Reading: LUN 1 (Boot A), Offset: 0x000000000000, Size: 0x000000400000 (4.00 MB) Output file: LUN 1 (Boot A)_000000000000_000000400000.bin Reading partition... Error: Previous operation is not finished yet Error: Previous operation is not finished yet Error reading at address: 000000000000 , error: -205, Unknown error: -205 ... Retry #1 Error reading at address: 000000000000 , error: -205, Unknown error: -205 ... Retry #2 Error reading at address: 000000000000 , error: -205, Unknown error: -205 ... Retry #3 Too many errors. Reading has been stopped Disconnected Operation: Connect to Z3X EasyJtagPlus Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to High Setting Frequence to 66 Mhz Socket Information : Socket Mark: EasyJTAG UFS Socket BGA-254 by EasyJTAG 28.01.21 Socket Serial: 0123B2BACF15DFB8EE Socket Type: UFS_SOCKET_BGA_254 UFS Power Information : Mode: High, VCC: 3321 mV, VCCQ2: 1922 mV UFS Device Information : UFS Manufacturer: SAMSUNG, UFS ProductName: KLUDG4UHDB-B2D1 UFS OemID: SAMSUNG_OEM_ID, UFS SerialNumber: 0x42711DDD3B197EBD8EE222C4E68153414B503230304B Maximum Number of LUs: 8, Number of LUs found: 5, Number of WLUs found: 1, LUs Re-configure: Enabled RPMB Counter: 13683 UFS LUN 0 Capacity: 122008 MB (001DC9800000) UFS LUN 1 (Boot A) Capacity: 4 MB (000000400000) UFS LUN 2 (Boot B) Capacity: 4 MB (000000400000) UFS LUN 3 Capacity: 8 MB (000000800000) UFS LUN 4 Capacity: 16 MB (000001000000) UFS W-LUN 0xC4 (RPMB) Capacity: 16 MB (000001000000) Device Life Time Estimation B: 0x02 10% - 20% device life time used Device Life Time Estimation A: 0x02 10% - 20% device life time used Pre EOL information: 0x01 Normal (Consumed less then 80% of reserved block) Do not turn the socket before you press "Close Session" button Connected successfully Operation: Scan PartitionTable from Source (Vendor: Samsung) Scanning soft partitions from LUN 0 GPT header is found Stopped by User request... Operation: Opening Firmware (Samsung) Firmware: PICASSO3_EUR_OPEN.pit LUN 0: The size of the "USERDATA" partition has been increased LUN 3: The size of the "CPEFS" partition has been increased Opening firmware completed Operation: Adding firmware files (Samsung) BL_G980FXXSCEUL7_G980FXXSCEUL7_SCL23182177_VCL2318 0807_MCL23346697_SQB47543609_VQB47543610_MQB475435 95_REV01_user_low_ship_MULTI_CERT.tar.md5 List of files in the firmware: sboot.bin.lz4 up_param.bin.lz4 ldfw.img.lz4 tzsw.img.lz4 tzar.img.lz4 keystorage.bin.lz4 ssp.img.lz4 uh.bin.lz4 vbmeta.img.lz4 harx.bin.lz4 Operation: Writing by Vendor (Samsung) Write/Erase check: Disabled Unpacking files into: C:\Program Files\Z3X\EASYJTAGPLUS\Temp\ Unpacking : up_param.bin.lz4 Unpacking : up_param.bin Unpacking : keystorage.bin.lz4 Unpacking : keystorage.bin Unpacking : harx.bin.lz4 Unpacking : harx.bin Unpacking : uh.bin.lz4 Unpacking : uh.bin Unpacking : vbmeta.img.lz4 Unpacking : vbmeta.img Unpacking : sboot.bin.lz4 Unpacking : sboot.bin Unpacking : ldfw.img.lz4 Unpacking : ldfw.img Unpacking : tzsw.img.lz4 Unpacking : tzsw.img Unpacking : tzar.img.lz4 Unpacking : tzar.img Unpacking : ssp.img.lz4 Unpacking : ssp.img Unpacking done Repartitioning ... Rom: LUN 0, Part: PrimaryGPT, Address: 000000000000, Filename: From Memory Rom: LUN 0, Part: BackupGPT, Address: 001DC97FB000, Filename: From Memory Rom: LUN 3, Part: PrimaryGPT, Address: 000000000000, Filename: From Memory Rom: LUN 3, Part: BackupGPT, Address: 0000007FB000, Filename: From Memory Rom: LUN 0, Part: Pit, Address: 000000006000 |
03-10-2022, 07:26 | #244 (permalink) |
Freak Poster Join Date: Mar 2009 Location: 75.BAITUN NOOR SHOPPING CENTER
Member: 987131 Status: Offline Sonork: 100.1614852 Thanks Meter: 25 | UFS Init Failed, error: 0 eMMC_tool Suite ver. 1.6.6.0 (release date: 05.05.2021) Microsoft Windows 10 (64 bit) build 19044 (10.0.19041.1503) Looking for EasyJTAG box... EasyJTAG API ver. 3403 EasyJTAG Box Serial = XXXXXXXXXXX Card Serial = XXXXXXXX EasyJTAG Box Firmware = 2.5302 Changelog: 05.05.2021 (ver 1.6.6.0) Add: New keys for Oppo unpack Fix: Bugs that have been found through your crash report 05.05.2021 (ver 2.0.1.0) Add: Vendor LG Add: Mediatek Preloader Parser Add: OnePlus Unpacker Add: Xiaomi Custom EDL Authorization Add: Xiaomi Remove Mi Account (only Qualcomm) Setting interface to EasyJtag2/UFS UFS Init Failed, error: 0 Setting interface to EasyJtag2/UFS UFS Init Failed, error: 0 Setting interface to EasyJtag2/UFS Setting interface to EasyJtag2/UFS UFS Init Failed, error: 0 Setting interface to EasyJtag2/UFS UFS Init Failed, error: 0 |
03-10-2022, 07:29 | #245 (permalink) |
Member: 987131 Status: Offline Sonork: 100.1614852 Thanks Meter: 25 | Initialize UFS Engine Fail. Code: -57/ERROR_UFS_BOX_INIT_LINK_T1 Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.09.20 Type: EasyJtag UFS Socket BGA-254 ID: 2959 Initialize UFS Engine Fail. Code: -57/ERROR_UFS_BOX_INIT_LINK_T1 Scanner Thread Terminated Elapsed: 00:00:00:704 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. |
03-10-2022, 07:30 | #246 (permalink) |
Member: 987131 Status: Offline Sonork: 100.1614852 Thanks Meter: 25 | Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 05.09.20 Can't open link, Code: -57, Reason: BOX: Chip not connected Done. |
06-24-2022, 07:05 | #251 (permalink) |
No Life Poster Join Date: Dec 2003 Location: Karachi Pakistan Age: 38
Member: 47321 Status: Offline Sonork: 100.54032 Thanks Meter: 497 | Setting Interface to EasyJtag2/UFS-Socket Setting IO Levels to High Setting Frequence to 66 Mhz Socket Information : Socket Mark: EasyJTAG UFS Socket 3 in 1 by MOORC 08.11.20 Socket Serial: 01237D77621C8B75EE Socket Type: UFS_SOCKET_3_IN_1 Can't init device. Error: -57. Reason: BOX: UFS Box init link T1 |
08-05-2022, 22:54 | #253 (permalink) |
Freak Poster Join Date: Sep 2018 Location: korea
Member: 2863121 Status: Offline Thanks Meter: 8 | Can't init device, Code: -112, Reason: Can't boot device hello easy jtag team there are many easy jtag users ask you the reason for getting the following error Can't init device, Code: -112, Reason: Can't boot device when trying to identify ufs chip please tell us what is the problem? error log is below Z3X EasyJtag Software ver. 3.7.0.24 UFS Safe Mode is disabled... UFS Socket Info. Serial: 01236612C25E4885EE Description: EasyJTAG UFS Socket BGA-153 by EasyJTAG 22.05.21 Identify UFS Chip. UFS Chip Voltage: Low Can't init device, Code: -112, Reason: Can't boot device VCC: 3259mV VCCQ2: 1837mV Done. |
08-06-2022, 07:45 | #254 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
at same log - chip is dead. | |
08-06-2022, 09:53 | #255 (permalink) | |
Member: 2863121 Status: Offline Thanks Meter: 8 | Quote:
and sometimes after pressing identify button several times it passes over this error which i mentioned but it gives new error(reading at adrress 0000000000 error) | |
