KLUEG8UHDC-B0E1 |
ufs SAMSUNG-KM2V8001CM-B707 firmware update error hello easy jtag team i came across error when i wanned to write ufs firmware for SAMSUNG-KM2V8001CM-B707 chip here is the log: Write UFS Firmware. Input file :C:\Program Files\Z3X\EASYJTAG\UFS Firmware\SAMSUNG-KM2V8001CM-B707.bin Getting Firmware information from file name Update Firmware Can't write firmware to chip, Code: -405, Reason: UAP SCSI: Command sense: ILLEGAL_REQUEST Done. thanks in advanced |
Easy jtag plus ufs chip connection error Ufs init failed. Error : -112. Reason: can't boot device |
support for samsung micron UFS will be released soon ? |
ufs 2.2 need help Health: Device life time method A: 0x03 (20%-30% device life time used) Device life time method B: 0x04 (30%-40% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Write UFS Chip Config. Can't write Configuration from file, Code: -2303, Reason: UTP: UPIU QUERY result fail: General failure Done. |
its 2.5 MBPS On Moorc 3 in 1 UFS Socket |
help guys Z3X Card Serial: AADDE0C9 EasyJtag Plus Box Found at: COM27 EasyJtag Plus Box Firmware: 2.53.2 Source: EasyJtag Port [UFS] Generation: GPT [QC/SAMS/BCM/INTEL/MTK] UFS Power Mode: LOW Scanner Thread Created.. Running EasyJtag UFS Mode... UFS ISP Mode: ON UFS Safe Mode: ON UFS: Socket Info: S/N: 0x0123D1B3252FDFB5EE Desc: EasyJTAG UFS Socket BGA-254 by EasyJTAG 27.09.22 Type: EasyJtag UFS Socket BGA-254 ID: 9697 Initialize UFS Engine Fail. Code: -60/ERROR_UFS_BOX_INIT_LINK_AFC Scanner Thread Terminated Elapsed: 00:00:00:676 Found 0 Partition(s).. Search Partitions Fail.. Check Socket/UFS Chip and Try Again.. help please http://ibb.co/VjKqFqf |
Hello! I need some help, on my easy jtag plus and easyjtag ufs254 isp adapter , on 3 from 5 phone with ufs 3.1 chip, first time identify chip works very nice, then if i press second time identify get error 113, then 3rd time works identify correct, 4th not work.....any ideea???? i will atach a video to show the problem better! thanks! kind regards! https://youtube.com/shorts/WKzQU9voe0Y?feature=share |
hallo data recovery from ufs 3.1 KLUEG8UHDC is possible? and what the best setup to buy easy jtag or mipi ? |
hallo data recovery from ufs 3.1 KLUEG8UHDC is possible? and what the best setup to buy ? |
Selected pinout: GEN2 High Speed Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.8.0.4 UFS Socket Info. Serial: 01235ED5408B79B5EE Description: EasyJTAG UFS Socket BGA-254 by EasyJTAG 22.05.21 Identify UFS Chip. UFS Chip Voltage: Low Can't init device, Code: -112, Reason: Can't boot device VCC: 3306mV VCCQ2: 1943mV Chip Info: Manufacturer: SKhynix ProductName: H9HQ21AFAMADAR SerialNumber: 0x2520B55CAB20 OemID: 01AD UFS Reference Clock: 19.2MHz UFS Version: 2.2 Done. |
