Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | [ Easy-JTAG ] | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #181 (permalink) | |
Product Supporter ![]() ![]() ![]() Join Date: Jun 2002 Location: Belarus Age: 46
Member: 13148 Status: Offline Thanks Meter: 2,806 | Quote:
to remove mdm you need use readed binary dump from device with combination firmware and write it (without efs) to you device | |
The Following 3 Users Say Thank You to layder For This Useful Post: |
![]() | #182 (permalink) |
Junior Member Join Date: Sep 2018
Member: 2866741 Status: Offline Thanks Meter: 0 | Thanks, is kinda hard to find n970f dump with the combination file, i gonna keep looking for it, if somebody has it or knows who sell those files, please help me, thanks. Last edited by mr.ralvaroa; 08-18-2020 at 16:30. |
![]() | #184 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2006 Location: ************
Member: 412097 Status: Offline Thanks Meter: 56 | Hi, i try to remove passcode on SM-A515F which is no have access to DM and recovery I use moorch socket and ISP jig, phone was good connect to software But when i do wipe userdata, phone become bootlooping Is there any tricky method just to remove phonelock? Thanks |
![]() | #186 (permalink) | |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2007 Location: Romania
Member: 467437 Status: Offline Thanks Meter: 30 | Quote:
and BTW , can you please point to a picture with moorc icfriend ufs v1 adapter pinout in order to link it to isp ? | |
![]() | #189 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Mar 2004 Age: 40
Member: 56948 Status: Offline Thanks Meter: 15 | hello! i need some help! i want to conect through ISP UFS on a samsung A515f, but i have only Emmc adapters, can anybody help me about which adapter i need for connect ISP on UFS chip without desoldering the chip from the board! I have found only Adapters for BGA ufs chip UFS BGA153 UFS BGA95 UFS BGA254 but i don't see any pinouts for connect ISP. I need all 3 adapters for ISP??? i don't think that it will be one adapter ISP connection for each BGA adapters! please help me! |
![]() | #190 (permalink) | |
only BGA254 UFS/eMMC 2in1 have UFS ISP pins | |
![]() | #192 (permalink) |
Junior Member ![]() ![]() Join Date: Nov 2017 Location: Netherlands
Member: 2774165 Status: Offline Thanks Meter: 4 | UFS chip is defective, can it be repaired? Identification, writing, etc., writes red errors, it is not possible to work with it. Can it be repaired or is the chip dead? Chip Info: Manufacturer: TOSHIBA ProductName: THGBF7G9L4LBATRA SerialNumber: F5661Y006G00 Firmware Version: 5.00 UFS Version: 2.0 |
![]() | #193 (permalink) |
Member: 2774165 Status: Offline Thanks Meter: 4 | Found 1 serial devices COM4 USB\VID_1781&PID_AAAC&REV_0100&MI_00 USB Serial Device (COM4) Selected pinout: GEN2 ISP Pinout Change EasyJTAG Pinout OK Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 01235187A747BA89EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 16.05.19 Identify UFS Chip. UFS Chip Voltage: Low VCC: 3298mV VCCQ2: 1810mV Chip Info: Manufacturer: TOSHIBA ProductName: THGBF7G9L4LBATRA SerialNumber: F5661Y006G00 Firmware Version: 5.00 UFS Version: 2.0 Maximum Number of LUs: 8 Number of LUs found: 4 LUN 0: Block size: 0x1000 Size: 0xEE5000000 / 59,592,000,000B / 59GB LUN 1 (Boot A): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 2 (Boot B): Block size: 0x1000 Size: 0x400000 / 0,004,000,000B / 4MB LUN 3: Block size: 0x1000 Size: 0x800000 / 0,008,000,000B / 8MB Number of W-LUs found: 1 W-LUN 0xC4 (REPORT LUNS): Block size: 0x100 Size: 0x400000 / 0,004,000,000B / 4MB Full size: 0xEE6800000 / 59,616,000,000B / 59GB Health: Device life time method A: 0x01 (0%-10% device life time used) Device life time method B: 0x01 (0%-10% device life time used) Pre End of Life: 0x01 (Used less then 80% of reserved blocks) Chip config is OTP Checking LU0 for partitioning EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 LUN0 Have 23 partitions Can't stop LUN0, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT LUN1 Have no partitions Can't stop LUN1, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT LUN2 Have no partitions Can't stop LUN2, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT LUN3 Have 1 partitions Can't stop LUN3, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT ------ Detected 24 partitions ------ LUN0 (BOTA0) [0x400000 0x400000] Size: 4.0MB LUN0 (BOTA1) [0x800000 0x400000] Size: 4.0MB LUN0 (EFS) [0xc00000 0x1400000] Size: 20.0MB LUN0 (PARAM) [0x2000000 0x800000] Size: 8.0MB LUN0 (UP_PARAM) [0x2800000 0x800000] Size: 8.0MB LUN0 (BOTA2) [0x3000000 0x800000] Size: 8.0MB LUN0 (BOOT) [0x3800000 0x2800000] Size: 40.0MB LUN0 (RECOVERY) [0x6000000 0x2e00000] Size: 46.0MB LUN0 (OTA) [0x8e00000 0x800000] Size: 8.0MB LUN0 (RADIO) [0x9600000 0x2a00000] Size: 42.0MB LUN0 (TOMBSTONES) [0xc000000 0x100000] Size: 1.0MB LUN0 (DNT) [0xc100000 0x100000] Size: 1.0MB LUN0 (PERSISTENT) [0xc200000 0xc0000] Size: 768.0KB LUN0 (STEADY) [0xc2c0000 0x100000] Size: 1.0MB LUN0 (PERSDATA) [0xc3c0000 0x900000] Size: 9.0MB LUN0 (SYSTEM) [0xccc0000 0x16a800000] Size: 5.664GB LUN0 (CACHE) [0x1774c0000 0xfa00000] Size: 250.0MB LUN0 (HIDDEN) [0x186ec0000 0x500000] Size: 5.0MB LUN0 (OMR) [0x1873c0000 0xa00000] Size: 10.0MB LUN0 (CP_DEBUG) [0x187dc0000 0x500000] Size: 5.0MB LUN0 (NAD_FW) [0x1882c0000 0x1400000] Size: 20.0MB LUN0 (NAD_REFER) [0x1896c0000 0x100000] Size: 1.0MB LUN0 (USERDATA) [0x1897c0000 0xd5b400000] Size: 53.425GB LUN3 (CPEFS) [0x6000 0x600000] Size: 6.0MB ------------------------------------ Read SYSTEM from LUN0. EFI Table seems to be corrupted (sizeOfPartitionEntries!=128) sizeOfPartitionEntries = 0 ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x000CCC0000 (5.664GB) Unable to mount SYSTEM , code : 95 --------------------------------------------- Can't stop LUN-407, Code: 122053072, Reason: ------------------------------------ Done. UFS Socket Info. Serial: 01235187A747BA89EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 16.05.19 Write UFS LUN0, Address: 0x0 ,Length: 0xEE5000000 Input file ![]() Start Can't write address 0x0, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Can't stop LU, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Done. Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 01235187A747BA89EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 16.05.19 Write UFS LUN1, Address: 0x0 ,Length: 0x400000 Input file ![]() Start Can't write address 0x0, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Can't stop LU, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Done. Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 01235187A747BA89EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 16.05.19 Write UFS LUN2, Address: 0x0 ,Length: 0x400000 Input file ![]() Start Can't write address 0x0, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Can't stop LU, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Done. Z3X EasyJtag Software ver. 3.7.0.20 UFS Socket Info. Serial: 01235187A747BA89EE Description: EasyJTAG UFS Socket 3 in 1 by MOORC 16.05.19 Write UFS LUN3, Address: 0x0 ,Length: 0x800000 Input file ![]() Start Can't write address 0x0, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Can't stop LU, Code: -407, Reason: UAP SCSI: Command sense: DATA_PROTECT Done. Last edited by mario.mj; 10-22-2020 at 12:20. |
![]() | #194 (permalink) | |
it's may be prroblem with first moorc revisions ufs socket - it's no so good | |
